Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
My model ksrd25fkst15 is making ice very slowly.
I have recently changed the filter. I have also checked the line and did not find a clog or blockage.
  • 62 Answers
Have you checked the water valve? It is in the back of the refrig to the bottom. Check that, if it is not bad you may need a new icemaker. No icemaker will make Ice unless the freezer is below 15 degrees.
Posted on May 12, 2009
Freezing Water line
Hello
The problem here is your water valve. It does not shut off all the way and allows very slow water flow through the water line. It is so small that it freezes in the supply tube causing a blockage. When your ice maker calls for water the pressure from the blockage pops the line out causing your leak.
You need to replace your water valve. Dual valve at the back of the fridge.."water inlet valve")
Jul 18, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/water and cooler issues
Your problem is defected defrost heater is burn already,that cause clogging up of ice at the back of ice maker box that cause abnormal circulation,click below for more information blue letter word....
clip_image001.jpgHeavy Frost on the Coils
This is good! This indicates a defrosting system failure which is a simple control problem. It also means that the sealed system (compressor, evaporator coil, and all associated tubing) is fine as wine in summertime. Defrost system problems are easy fixes that anyone with a pulse can do with maybe just a little help from their friends. The problem will either be the defrost timer (or Adaptive Defrost Control board, if so equipped), the defrost thermostat, or the defrost heater. To locate these parts in your fridge, check out these cool, interactive parts diagrams
Jul 12, 2008 | Kenmore Refrigerators
Frigidaire ice maker
My Samsung would freeze up periodically especially when I didn't change the filter. Contaminants will cause frost or freezing in the line. The result was a tiny frozen blockage near the solenoid.
UNPLUG the fridge and run a hair dryer directed at the ice maker. Being careful to not allow plastic parts to overheat.
Sometimes you may even hear the tiniest crack when it lets loose. probably only take 20 minutes or so. depending how much of line is frozen.
Oct 28, 2017 | Refrigerators
How to make the ice maker work
Problems with Ice Maker/Water Dispenser
If you are not getting ice, make sure the water valve is open and the ice shutoff switch or arm is not in the "Off"
position. Inspect the ice ejector arm for blockage and remove any trapped ice with a plastic spoon. If you recently
emptied the ice container, remember that it takes your refrigerator up to 24 hours to produce ice.
Low water pressure is the major cause of problems with the water/ice door dispenser. Low water pressure can cause
inadequate water flow and small or hollow ice cubes. Check the water line for kinks that may interfere with water
flow and make sure the water valve is open. A dirty water filter can color the water and ice cubes, impede water
flow or cause water to have an off taste so remove, clean and replace it.
If water is leaking from the door dispenser, make sure the water glass remains under the spout until the water
shuts off completely. If you recently changed the water filter, air that was left in the line may cause water to
spurt from the dispenser. To flush the water line, let water run from the dispenser for approximately three minutes
or until you draw out 1.5 gallons of water. Try to find a container that will fit under the dispenser spout so you
do not have to start and stop to empty the container.
Have a nice day my friend : )
Sep 04, 2011 | Kenmore Side by Side Refrigerator
Water dispensor is not working. ice maker does work. new filter
If the filter is the only change made.. look at the new filter.. are all the 'seals' etc removed? so water can flow through it? is it installed in the proper direction? .. .. or did you replace the filter because no water was flowing? If that is the case.. and the filter is installed correctly.. something is blocking water flow.. maybe a frozen water line or clogged water line follow the water line from the dispenser end in the door, back to it's source. If the line is white- try to run a thin wire into it to see if it is clogged if it is clear, look for a blockage. If no blockage.. then it is blocked in the 'pump' or valve area or the pump/valve for the water dispenser is bad. there is some kind of lever to tell the water to flow when you put a glass under spigot.. check that- to see if it is stuck ( my ref door light switch likes to get stuck) .. good luck.
Dec 26, 2010 | Samsung RFG297AARS (285 cu ft) Bottom...
My bosch ice maker/water filter no water dispensed
if there is ice build up in the freezer the line may be frozen . May be a defrost heater coil issue
Dec 08, 2009 | Kitchen Ranges
Cold water dispenses very slowly. I checked the water line for bent or kink but none is visible. Why is the water dispense slowly.
your unit should have a water filter, check to make sure it is in correct or also it could be clogged and needs to be replace.
Sep 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker in my Jenn Air refrigerator stopped working.
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Sep 10, 2009 | Jenn-Air JCD2389G Side by Side...
Water not coming out of fridge
First, I'm not a Whirlpool Tech.
*** Following is for information only.***
* Sputtering or no water from Ice machine and tap indicates a clog on the water line.
* Most of the newer (last 15 years) refrigerators come with a built in filter. It's probably clogged. Check the link below for changing out filter or type in "Whirlpool refrigerator water filter replacement'
* There could be ice blockage in water line if you have a very low temperature setting on your fridge. Most are set in the middle of the dial. If your set at maximum could then this setting may be too cold for the water line (it's coiled in the back of the refrigerator and may have frozen up.) Back the temperature a bid and give it a day or two to melt.
* The ice tray is missing a cover.
* Ice tray "Ice Full" lever is stuck in the Full position. Check if the Ice level (usually a stiff wire) is in the down or empty position. (some lock in the full position to turn off ice maker manually.)
* Check the water line to the refrigerator (or In-Line water filter) for water pressure. Turn off water supply. Remove water line from refrigerator and place end of line in empty bucket. Hold line down and have someone turn water back on then off after a few seconds (they may be too far to hear you yell "turn it off?!") If it just sputters then the line needs to be cleared. Check the needle valve for clogging. Close it off and re-open it several times. Otherwise this valve needs to be replaced.
* Follow the flow of water through each part: Supply line, supply valve, Water filter, Refrigerator inner filter, Tap point and Ice maker.
* Final, Check your warranty as any work (other than a MFR recommended customer water filter change out.) will void it. Call your vendor for service to be safe. (Have them do an annual maintenance while they are servicing your unit.)
Aloha, ukeboy57
Whirlpool link; https://www.bing.com/videos/search?q=whirlpool+refrigerator+water+filter&&view=detail&mid=B5D436DFC162C03FB4FAB5D436DFC162C03FB4FA&&FORM=VRDGAR
Feb 21, 2018 | Whirlpool Refrigerators
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
110 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
