Question about Soyo DYLT032D 32 in. LCD Television
Tv not working
I have a scott lcd37 tv it won't turn on, not by the remote r the side button i think a surge hit it, the light on the front just flashes. what can i do to get it to work r who can i call. still almost new like to get it fix if i can work good other wise thank for your help ivan
5 Suggested Answers
Vish2
  • 74 Answers
SOURCE: remote control
Does your remote have a button called TV. Press this first and then hit the power button and the TV should turn on. Remotes these days control multiple devices like DVD players and VCRs and you need to ensure that you have selected the right mode. Hope this solves your problem.
Posted on Aug 21, 2007
SOURCE: Scott LCD won't turn on with remote or with on button
Do not shut off the TV. Put cardboard in front of screen when not watching.
MY THEORY
The power serge when the TV is turned on puts a stress on the caps (ac to dc volts) .
Continued off -on weakens the caps until failure.
Posted on Jun 24, 2009
  • 7 Answers
SOURCE: tv will not turn on without remote, buttons on
there may be a short circut in the t.v. if your handy with electronics open it and check the buttons if not call your t.v provider
Posted on Nov 04, 2009
SOURCE: I have a Scott 37" lcd tv that started refusing to
i have a 37 inch also and had the same problem if i unpluged it it would turn on. some suggested that i leave it unplugged and than try it i did and now all i have is a blinking red light and it won't turn on at all , what do i do
Posted on Jun 16, 2010
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Tv will not turn on with remote or botton on side
the tv was on a surge protector line, what i notice that i had it plug in a cheap surge protector when i pull from wall i notice the adapter were burn and the cheap surge was burn at that time when i go to cut tv on i could hear a surge like sound. i tried to put it in another plug it wont come on, i open back of tv looking for fuse i could not find it or reset button can solve this problem i hit input button on side it still wont come on. i do not think there is any problem with picture it has something to do with power.
Aug 17, 2011 | iLO LCT32HA36 Television
When the power is turned on, the screen stays black (nothing is displayed-totally dead). Then it won't turn back off unless I unplug it. The model is DX-LCD37. It doesn't matter if I use the pannel...
Had a very similar problem with mine - not sure if this will help or not, but it seems to be doing the trick (channels scanning as I type).
I unplugged the tv for about an hour. I unplugged the cable, and all the components. Then I turned the tv on, and was able to get to the menu screen. Previously, I couldn't change channels or even power off from the buttons on the side of the unit either...
Once there, I plugged the coaxial cable directly into the side of the set, then ran the auto-scan.
I know it's not a techincal answer, and a bit strange, but as I mentioned, it seems to be working for my issue.
Nov 26, 2010 | Dynex DX-LCD37 TV
Green picture
i dont think it the color wheel - to make it green the glass would of come off and the tv would be vibrating badly. to check pull the lamp out and with a flash light look at the color wheel -
you most likely got a surge that glitched the eeprom - you will need the service remote to adj the white balance
thanks
scott
Aug 01, 2008 | LG 52SX4D 52" HDTV
Soyo DYLT032D 32 in. LCD Television Logo
109 people viewed this question
Top Soyo Televison & Video Experts
Jaime Hernandez
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
