Question about Dryers
Dryer was running and just stopped now will not start back up
When you turn it to timed dry you can hear the timer clicking but the dryer does nothing took panels off all wires look good nothing looks burnt up and belt is still in place when i turn the fan everything turns freely could use some help ... THANKS
  • 2 more comments
  • rickylogan May 13, 2009
    kenmore heavy duty 70 series model # 65732
  • rickylogan May 14, 2009
    model #110.96573220 65732 hope this helps thank you
  • rickylogan May 15, 2009
    That was the problem thank-you very much it is very appreciated
  • Pataricia Nolte
    Pataricia Nolte May 11, 2010
    It would help to have a model number. But before you send one, make sure you turn off the breaker to the dryer all the way off then turn it back on and see if it starts heating. If that does not work write back with your model number.
  • 62 Answers
Posted on May 12, 2009
  • 1 more comment
  • Pataricia Nolte
    Pataricia Nolte May 13, 2009
    this is not a full model number...open the dryer door and read the model number from left to right all the way...it should start with 110.6...., there are numbers your are leaving out please try again so that I can help...
  • Pataricia Nolte
    Pataricia Nolte May 14, 2009
    Look at the diagram I am sending you a link to it is an exploded view of the back of your dyer. Try this first take the back off the dryer and you will see a white fuse aprox at the middle closer to the bottom of the unit. # 59 in the diagram. take the two wires...with the unit unplugged and put them together...make sure they will stay together and none of the connection metal comming off the two leads is touching any other part of the dryer. Maybe even temporarily tape them together with electrical tape...and then with the back still off see if your dryer will start working again. This is a safety switch and needs to be replaced and so don't use it this way. I you can get this part at any appliance part store and It goes out usually when you need to clean out your dryer...if that doesnt work write me back and let me know...I will help you further...here is the link to the diagram...good luck...click on the link.
    http://www.searspartsdirect.com/partsdir...
  • Pataricia Nolte
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
Whirlpool estate teds840jq2 dryer just stopped working. I can hear a clicking sound from the timer when the timer is turned to a setting but when I press the start button, nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Estate TEDS840JQ Electric Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Frigidaire Model FSE446RHS0 Dryer won't start.
its sound like the belt could have broken off or overheated normally when a belt breaks the machine no longer runs except for the timer noise you hear remove clotche from dyer turn the drum manually if it turns freely by hand that meens your belt is broken thanks from gilles
Mar 15, 2009 | Dryers
Amana LEA60AW dryer problem??
Check the door switch to see if it is engaging. This will shut down the motor. I usually do this with a plastic ink pen to see if I hear a clicking.
Feb 03, 2008 | Dryers
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Diagnostics and Repair Details
Check your door switch first. You should hear a click when you push it in and light should turn off.. If it clicks it is probably ok. If you need to know how to replace it or if it is ok, please reply back with model number so I can give you more detailed directions in troubleshooting.
Oct 12, 2007 | Dryers
Dryers Logo
210 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
