Question about Toshiba 43H72 43" Rear Projection Television
Toshiba rear projection TV 43VH9UA
I bought 6 years ago, now no picture at all, but sounds works fine. Some days before this total picture broken, picture didn't come on for ages, sound worked fine, when picture finally come on it was snowy and had lines vertical and horizontal
Have toshiba 43vh9ua picture is purple to blue in colour does anyone have a fix... thanks nev
Posted on Oct 18, 2009
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
Have an 52HM95. Man.- 01-2006. Rent-a-center had the lamp (I believe) replaced when this happend the first time 3yrs ago. . It cost them around $200. Now 3 years later, its paid off, so, NEED HELP! (No...
The "LAMP" LED light indication on the front of the tv screen panel flashes or light up?The projection lamp was replaced 3 year ago u belive right?The average projection lamp life about 1 1/2 or 2 years.Withthin function in the tv and in used like 4 or 5 hours a day of tv viewing.Ur tv require a new projection lamp.
Sep 18, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
I have the Toshiba 61A61 TV. I am not sure what exactly happened, but when the TV was on, suddenly the picuter went black. I still receive the normal sound, but can't get any picture (totally black). I...
Check all connections?Unplug,replug the cable box about an hour later let it upgrade it software.The projection lamp has not been replaced in this tv the last 1 1/2 or 2 years?The tv been on and watches at lest 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Sep 03, 2010 | Toshiba 61A61 61" Rear Projection...
We replaced the red and blue convengence units on our Toshiba 50HX70 four years ago, the blue is out again is this worth repairing again? The TV is now nine years old
Yes,the tv still good.I rather spend 300-400 dollars.Than 1100-1200 for a new one.The average tv replacement about 15 years.Using 6-7 hours a day.
Feb 24, 2010 | Toshiba 50H72 50" Rear Projection...
Toshiba Rear Projection TV picture color is now a greenish hue
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Sep 12, 2009 | Toshiba 50H82 50" Rear Projection...
Sound went out!
Have the audio signal board replaced. Also make sure ur amplifier is set to the correft output, alth i am sure u have.
May 03, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba 43VH9UA Rear projection
When was the unit repaired last? If it is doing the same thing and is only 5 years old, it sound like a bigger problem than just what was repaired. I own a 56" projection TV and mine is 6 years old and I have yet to have a problem with it...(I shouldn't have said that...) If I were you, I'd call Toshiba and explain the situation and that it has been repaired once already under warranty. Chances are, they'll be able to help you to your satisfaction. I once purchased a JVC stereo receiver from Circuit City and had to take it in to be repaired 5 times and the warranty had expired after my second trip up there, but they were nice enough to repair it - free of charge - the other 3 times. Toshiba seems to be a company that stands behind their product. Good luck! Hope this was helpful...
Sep 08, 2008 | Toshiba 43H72 43" Rear Projection...
Picture is Dark on all stations
It sounds like a bulb. I would call toshiba and ask them what the replacement part is for that. I briefly googled for it but couldn't find the matching bulb for the 46H83
Dec 12, 2007 | Toshiba 46H83 46" Rear Projection...
Toshiba 53AX61/ have sound no picture
I have the same problem with the same Toshiba 53ax61 the picture does not work anyone,
Please email me at skyhawkbasketball@hotmail.com
Oct 09, 2007 | Toshiba 53AX61 53" Rear Projection...
TV picture shaking!!!
It sounds like the Hyper board is begining to fail....Does the menu shake too?
May 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 43H72 43" Rear Projection Television Logo
172 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
