Question about GE Profile JKP56 Electric Double Oven
Flashing locking door light
I have a GE double oven JKP56. The "locking door" light just started flashing today and the latch continues to lock and unlock the oven door. I did not use the oven nor use self clean. I attempted to push buttons on the control panel (start, stop, clear) all to no avail. I turned off the circuit breaker and back on, no change. I took off the panel, detached and reattached pin from lock motor. No change. The motor continues to run, so the motor is good. Problem with the relay? Control panel? Thanks in advance!
  • 13 more comments
  • wega2 May 17, 2009
    hi
    the switch is in the upper RH corner, seems to functioning well. Is there another switch near the hinge?
    panel continues to flash "locking door", the latch moves continuously from lock to unlock and back to lock.
    Doesn't stop moving unless door is open. When I press the black post switch in, the latch just continues to move.
    I tried resetting but it just continues to flash....
    thanks!
    did not see any switches near the hinges...
    is it hidden under the trim?
    I see the black dowel/post in the upper RH corner, pushed it in and the latch starts moving....After pushing "clean" and then "clear/off" the "locking door" continues to flash
    i tried it couple times, will try again later as I turned off the power because when the power is on the latch locks and unlocks incessantly.
  • wega2 May 20, 2009
    did not find the "safe switch" you are referring to. There is nothing near the hinges.
    I have the manual, no mention of the safe switch, you must be referring to the black dowel in the upper right hand corner
    It is the GE Profile JKP56 double wall oven. The oven works fine. Just the latch is locking/unlocking incessantly.
  • wega2 May 21, 2009
    Tried again to no avail.
    With door closed, the "locked door" continues to flash with the latch locking then unlocking then locking then unlocking....
    pushing clean then clear/off doesn't stop the flashing light at all.
    the only way to stop the latch from moving is to leave door open. when i push the dowel in to simulate closed door, the latch just moves left to right and back.
    nothing is in the way, door is completely shut.
    so strange. I can't figure it out.
    thanks
  • wega2 May 22, 2009
    thanks
    Are any error messages displaying on the control?
    * no error messages at all.
    Within
    the electrical enclosure exposed by removing the control panel, Look
    for a small silver and black device with 2 wires attached to the back.
    The device is about .5" wide by 1" long and is attached with 2 screws
    to the sheet metal on the bottom of the electrical enclosure. Mine was
    located nearly in the middle of the electrical enclosure.
    * then enclosure surface is covered with foil & insulation. Wires from control panel go to lock motor, ground, fan, and most wires continue on and go behind sheet metal wall. Don't see anything with a button. I do see small black cylinder about .5 " x .5" on a metal base about 1" long. But no button on top.
    thanks
  • wega2 May 23, 2009
    thanks for the info and the heads up on the previous info. I thought i was just stupid. I will definitely try your method in the next few days.
    I will let you know how it works.
  • wega2 May 27, 2009
    will do, thanks
    fuse is ok.
  • wega2 May 28, 2009
    control board is unattainable at the moment
  • wega2 May 30, 2009
    Hi Ginko
    thanks for the info. So you recommend me to replace the control panel and see what happens?
    Just want to double check before I spend $250+ on the control panel.
  • 77 Answers
The flashing light means that you have a definite problem on the circuit board for the circuit that controls the door latch and light. You have a short. The only way to find it is to remove the board and bench test each circuit.
Replacing the board will cost but it will solve your issue.
Posted on May 31, 2009
  • 3,741 Answers
But its the control board problem.that has to be replaced to solve the issue in this case.
get the board at
www.repairclinic.com
or at
www.partselect.com
Posted on May 28, 2009
  • GE Master
  • 19,396 Answers
Re : Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back.
That cames from an old thread and is a generic explanation of how it works. Here original reference
GE Profile Electric.
There is no electrical cylinder because the solution was referring to a different model and a different problem. In case linked above the door was locked, in your case door is clicking continuously, showing that there is a contact or a faulty door lock motor control.
If I was doing the repair I would start reading voltages on lock motor motor harness with motor wiring cut, this will tell you if contact is inside lock motor assembly or on control. The test can be done either from control side (easier access) or from lock motor, after disconnecting the harness.
If the control actuator keeps turning on and off , then replace the box in there, otherwise work on wiring harness and on lock motor.
This is not an easier repair, and tests with live power in there may be riskyd if you have not enough experience. If you are a beginner just inspect wiring with power off first, then replace control, and if that does not fix the problem replace wiring harness.
Here parts that must be tested, and relative diagrams:
LOCK MOTOR WIRE HARNESS (LCK MTR HARN) connects to part 999 on diagram.
LIMIT SWITCH(LOCK)
Part 158 on diagram.
If problem is not in control or wiring harness, then check if there is a contact inside door lock assembly or on LOCK MOTOR connectors. If two connectors on picture below are making contact, that is the problem:
As a matter of principle , do not forget to leave feedback, or you may end up rewarding the person that copied and pasted a solution for the wrong problem.
Thanks, and thanks for asking Fixya.
Ginko.
Sonce the proble
Posted on May 22, 2009
  • 1 more comment
  • Ginko
    Ginko May 22, 2009
    Let me know how it goes, and let me know if you found the fault.
    Many thanks.
    G.
  • Ginko
    Ginko May 23, 2009
    Ok, Let us know the outcomes of your repair.
    Many thanks.
    G.
  • Ginko
    Ginko May 24, 2009
    Ok,
    please leave feedback after your problem is solved.
    I repost the solution below:
    If I was
    the harness.
    motor.
    LIMIT SWITCH(LOCK)
    Regards.
  • 744 Answers
Hi...
mostly they have a thermal fuse in them that blows if too much of heat builds up in them and they have an improved blower moter thermal fuze kit for them i suspect thats the promblem....if thats the problem try to replace the thermal fuse or else contact GE for improved kit and installation process...
thank u
rate me!!!
Posted on May 27, 2009
  • Prakash Ram
    Prakash Ram May 27, 2009
    It's most likely the switch in the door stuck in the closed position. Or it has failed/broken in the closed position.
    Sometimes the switch is just a button sticking out of the cabinet where the door pushes on it when closed -- sometimes the door latch pushes on a switch inside the latch receiver in the cabinet.
    If cleaning around that switch doesn't solve the problem, you should take it to a repair shop.
  • 15,935 Answers
Please let us know if you have additional questions.
Thanks for using FixYa!
Posted on May 24, 2009
    Novelist:
  • 130 Answers
The manual says this can be cleared by following this ------------ there was information regarding unlocking the oven door. The instructions said press the "clear/off" button FOR 3 SECONDS to unlock. you  press it again, this time hold it continuous  for 3 seconds. The light will start flashing and the door will get unlocked. if it does not help for the first time repeat it for more 3 to four times.also if as per the manual it says 3 seconds but if holding the clear /off  for 3 seconds does not helps then hold it for 10 seconds and also try.this will mostly solve the problem.
but if that does not solves then the light is flasing and door latch open and close .this is happenming because.you know that door is open .but the unit feels that door is still unlocked. so you have to unlock the door in the system of the unit. try this as follows:--- try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When the self cleanwill start , the door automatically will go  thru the auto lock and "locked" will appear in the display. you then hit "Off" to clear it and stop the cleaning cycle. The door will then get unlocked as normal in the system of machine.!
please do rate the solution.thank you for using fixya.keep updated.thanks.
Posted on May 23, 2009
  • 527 Answers
Sir,
Try to reset it:
TURN OFF THE POWER!
Open the door (if it is locked, turn the power back on and gently pull on the door every few seconds as the locking mechanism cycles until it is unlocked)
remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven)
pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. Mine was located nearly in the middle of the electrical enclosure.
Push the tiny button on top of the switch.
Check this link and go through the site
click this link for parts
Thanks Good Luck
Appreciate to rate as "Fixya"
  • 355 Answers
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
Posted on May 20, 2009
  • 1 more comment
  • Rohit  Asthana
    Rohit Asthana May 20, 2009
    It was a "reset" switch in behind the control panel that went off when
    the self clean cycle increased the temperature in the area behind the
    control panel got too hot. After flipping the breaker, and then
    flipping it back on the oven finally unlocked. I pulled the control
    panel off and pushed the reset switch. Everything fired back up great.
    I just won't use the Self-Clean ever again.
  • Rohit  Asthana
    or check it
    Open the oven door. Press and hold the light switch. You will hear the
    door lock move back into the correct position. Hope this fixes your
    problem. This has happened to me twice and holding the light switch
    always works.
  • Rohit  Asthana
    here take a look at this one:
    i know it can help u.
    What
    is wrong with your Range/Stove/Oven?
    regards
  • 952 Answers
Its not a relay problem, the latch will not lock and unlock if its the relay.. it will either keep locking or keep unlocking if its a relay problem... its possible that the circuit board is damaged. check for blown capacitors. if you are unsure what to do with the circuit board. try to take the circuit board out and bring it to a local electrician. Have a great day...
  • 102 Answers
If your not getting any heat from the bake or broil elements, its a good chance the control board has gone out.
Its a pretty costly board, and on some models the wiring will have to be changed quite abit, which is very difficult. A appliance repair tech. is recommended on this part.
Posted on May 17, 2009
  • AJAY YADAV
    AJAY YADAV May 20, 2009
    ummm can u give me more detail about ur model
    cos i am a bit confuse
    thanks
    Brigadier General:
  • 8,619 Answers
Hi
If “LOC DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737)
Please do accept the solution and revert for further assistance.
Thanks
Rylee
  • 1 more comment
  • Rylee Smith
    Rylee Smith May 17, 2009
    It should be under the trim if not then you need to follow these steps:
    2. Close the door.
    5. Unlock the door.
    Thanks
    Rylee
  • Rylee Smith
    Did you follow the step by step instructions if not then please do repeat the above instructions. However as advised earlier if the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737)
    Thanks
    Rylee
  • Rylee Smith
    I hope its working now if not then a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737)
    Thanks
    Rylee
    Genius:
  • 1,689 Answers
Hi wega,
the door's locking mechanism is controlled by a switch when you shut the door down. much like the light switch on your refrigerator. when you initial closing the switch for locking the door will be triggered does locking the door.
there is a possibility that this switch on your oven is press / stuck that is why it keeps on saying "locking door" which will eventually never be completed.
Find the switch on your door panel, this is usually near the hinge of the door. it can also be safely located with in the hinge assembly, if this is true, there will be no buttons or holes visible.
if you can open the door panel up or remove the casing you will be able to locate the switch on the door hinge and its assembly.
hope this helps.
voodoo
Posted on May 16, 2009
  • marlon john madrid
    marlon john madrid May 17, 2009
    thanks for replying
    if you still have the service manual for the unit it is called "Safe Switch", this switch makes sure that the oven does not turn on while the door is opened.
    were you able to locate the door safety switch?
  • 6,784 Answers
This is a failed logic chip on the control board. replacing the control board will fix this issue.
Oven lock motor frigidaire stove close and open continuously- flashing door lock light
Hi Chris -- if I am understanding you correctly, your door lock is stuck with the door open. If this is the case, locate the oven door light switch that is typically in the top left corner of the unit. Press and hold the switch button in for about 30-60 seconds. While you're doing so, look for a flashing light on the control panel next to the word, "lock". If the latch hook is in the locked position, continue holding the button and press the CLEAR/OFF key on the control panel. Hold the button in until the flashing light goes off. If this does not resolve the issue, please supply your unit's model number and any additional symptoms it was experiencing prior to this event so that I can be of more assistance to you. - Best of Luck!
Aug 27, 2012 | Frigidaire Ovens
DOOR Locked Flashing
check the interlock switch, can be some object has stuck to it...
Sep 06, 2008 | GE Profile JTP18 Electric Single Oven
Ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Aug 26, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
JTP56 Self Cleaning issue
It sounds like you need to replace the door latch assembly. One of the switches on it is not working properly so the control is not getting the correct signal for the door latch position. It could be an oven control problem, but most likely it is the latch.
Post back with the complete model number from the oven if you need more help and I will answer as soon as I can.
Thanks, Mike
May 06, 2008 | GE Profile JTP56 Electric Double Oven
Oven door will not close because the door lock is on and flashing, also the oven light won't go off. how do I fix the door lock flashing so I can close the oven door completly?
is not actuallly physically closing??? perhaps the lock/ latch has partially engaged prevetning door from closing, and with the door oopen it cannot do anything for safety reasons. can you see a door /light switch thtyou can depress by hand??? if so push and hold it in the light should go out, and at this point continue to hold in switch and try starting a self clean cycle ( dont worry it wont actually start cleaning right away)it then should activet the latch assy to fully engage and suppoedly lock door, still depressing the button then press thecancel button and the latch should return to the normal resting position and you can close the door
Apr 03, 2008 | Ovens
"Door Locked" keeps flashing
Was able to get the lock to go in on the door and then turned off the power which reset the system.
Mar 31, 2008 | GE Profile JTP56 Electric Double Oven
After self cleaning ge oven, door won't unlock
I turned off circuit breaker to the oven and tried to open it. It did not. I did it again and waited for a few minutes, it worked and I was able to open the door.
Dec 24, 2007 | GE Profile JKP56 Electric Double Oven
Ge oven problem
door lock is not work check wires motor and switchs.. you may have to replace the door lock
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Open Questions:
The convection fan comes on intermittently, starts smoking then goes off. Temperature on the display doesn't move from 100F (then it did). My wife left the door closed while it was on broil last night (not sure how long), and this morning I woke up to the smell of burnt electrical and something (one of the fans...? not sure as it was far earlier than I usually get up) running that stopped when I opened the oven door and restarted when I closed it (I'm thinking it was probably running all night). While at work, I turned the breaker off, then pulled the oven out this evening. After taking some of the metal plates off, I put the power back on and turned the oven on for a 450F bake. I don't know if the little cooling fan at the top of the unit is supposed to go on when I have the top exposed and getting plenty of air; it wasn't and it also had a faint burnt electrical smell. After disconnecting then plugging the fan power connector to the circuit board the fan ran for 10-15 seconds before it started smoking and quit. I checked voltage across the fan leads and there wasn't any. I shut the oven off, tripped the breaker, and let it cool. I then tried testing the fan motor directly i.e. bypassing the oven and using a regular outlet since the motor is rated for 120V. It ran for ~1 minute, then smoked and quit. The smoke is definitely coming from the fan rather than any adjoining wires. Is this a case of the fan AND the control board going south or one contributing to the other's demise? I should add that the clock display has been dimming for a couple of years. UPDATE (2/20): I tried just baking (as opposed to convection baking) and the bottom element did come on (I'd reported earlier that it hadn't... that was because I was using convection baking and that does only heat around the fan... just my ignorance on that one). However, the temperature readout on the display did not move from 100F though it was clearly hotter than that in the oven. I then stopped the baking mode and started convection baking. This time the temperature gauge immediately went to 141F and kept climbing. Resistance at the (room temp) temperature sensor (and at the end of the wiring harness plugged into the control board was ~1100 ohms at room temp (as its supposed to be).
Feb 19, 2016 | GE Profile JKP56 Electric Double Oven
See all GE Profile JKP56 Electric Double Oven Questions
GE Profile JKP56 Electric Double Oven Logo
1,491 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
