Question about Dryers
Dryer quit working - will not do anything when "start" button is pressed
My dryer just quit working. When I press the start button it doesn't do anything.
  • csbrown1 May 13, 2009
    The breaker is working. The model number is110 60724990.
  • Pataricia Nolte
    Pataricia Nolte May 11, 2010
    It would help to have the model number. the model number is on the front panel that the door shuts to. Have you checked your breaker? If your breaker is fine and you are getting power to the machine write back with your model number and I will try to help.
  • 62 Answers
Posted on May 12, 2009
  • Pataricia Nolte
    Pataricia Nolte May 13, 2009
    Unplug the dryer and turn it aroud and take the back off. you dont need to take off the cord just the back. after exposing the inside of the back you will see a white fuse. with the back off take the two lead and put them together by hooking them onto each other. they are not ment to be or stay this way but it will tell you if this is what needs to be replaced. once they are hooked together make sure they are not touching any metal and just kind of hanging there in a loop hooked together. plug the machine in and see if it starts to run. If it does you need to clean out the machine this is a safety fuse and usually goes out when the dryer needs cleaned out and is building up too much heat. it is part 59 in the diagram you will see if you follow the link i am sending you at the end of this comment. the factory part number is 3392519. you will see that in the parts list below the diagram. please get back with me if it doesnt help....good luck and let me know...here is the link
    http://www.searspartsdirect.com/partsdir...
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: dryer won't start. it doesn't do anything
Hi wawhitlock20...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Posted on Sep 18, 2011
How can I get my dryer running?
You need a new machine control board
Oct 02, 2016 | Whirlpool Dryers
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
I own a FP dryer model number DE08-US1, serial number VF740275A. Recently the dryer has been automatically starting when I turn the drying dial to any of the drying options (Automatic cottons, automatic...
I really hope the problem is the start button is defective, it is stuck on. You would need to get a new one. Bad news is, that is a little bit more rare than the timer itself being messed up . Those are quite expensive.
Be blessed.
Sep 01, 2013 | Fisher and Paykel DEGX1 Electric Dryer
Frigidaire dryer faqe7001lw blinking lights
Try resetting the computer like a cars e.c.m. by turning the dryer on and plugging it from the outlet. It worked for me once w our new Malta front loaders
Apr 07, 2012 | Frigidaire FAQE7001LW Dryer
When I shut the door then press the button it doesn't feel write but I can hear the other part ticking like it is working. It sounds like it is int he button.Please help me if there is anything I can...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 20, 2011 | Dryers
My dryer is a whirlpool, 5 cycle, 3 temp and does not come on, when you go to trun it on, it does not make any noise or anything.
check to make you have 220 volts of electricity,if you do make sure door is closed all the way,try to start dryer,still not working look at the door switch press it with your fingers while holding it down reach and press start button,still not working there are 2 wires that go to that switch you either have to pop the top up or take the front of dryer off to get to them you can tape the 2 wires togeher press start it should work,if not you have a thermal fuse in the back of the dryer under back panel next to dryer vent its white with two wires hooked to it you can tie these two wires together press start should work kenny 832 620 8626 i use a tester for all this
Jan 23, 2011 | Whirlpool LER4634J Electric Dryer
Dryer seems to run fine but not getting hot?
It is most likely the reset button. I hate that reset button. It is a pain to get to located in the front of the dryer it looks like a screw press it and it gets hot. I have to press mine all the time because I have the dryer vented with a flexible dryer vent and if it isn't far enough away from the wall it overheats, trips the button and continues to run without drying the clothes. I think it would have been a better design to just have the dyer turn off but oh well too late now. So try pressing the button on the front of the dyer under it you may need a screw driver to press it. it doesn't click or anything so you really don't know if you have pressed it. I just press mine a hole bunch of times to make sure. Oh and unplug the dryer before you work on it.
Dec 25, 2010 | Fisher and Paykel AeroSmart DE62T27D Dryer
Dryer won't start
http://laundry.manualsonline.com/ex/thread/view/idThread/1746462 and check the lint trap just a hunch hope this helps and good luck
Jul 07, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Jan 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
380 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
