Question about Sony Car Audio & Video
Radio cuts off and back on seems to be vol related
Radio cuts off and back on ,seems to be vol related, sony cdx-gt11w when you turn volume up radio starts cutting off then back on when you turn vol. down it may quit cutting off then it may not
  • skchum May 13, 2009
    have not tried the fix yet, but will soon thnx
  • 150 Answers
This is cause by many things one of which is a faulty speaker that is going short when operated at high volume. Another is the wiring supply the power to the radio is not "thick" enough hence not able to supply the demand for extra current. Had this same problem with Golf II which I replaced the main supply wire and after that it went to full volume with no cutting off.
Posted on May 12, 2009
  • 435 Answers
I HAD THE SAME ISSUE AND SOLVED IT BY INCREASING THE GROUND WIRE SIZE & SOLVED IT. IT WAS CUTTING OUT WHEN THE VOLUME WAS OVER 25.
Posted on Apr 27, 2010
I need operator's manual / instructions for Sony CDX-GT11W
The operating instructions and installation guide for the CDW-GT11W are available from the manufacturer's support site: https://esupport.sony.com/US/p/model-home.pl?mdl=CDXGT11W&template_id=1®ion_id=1&tab=manuals#/manualsTab . Click on the Manuals, Specs & Warranty tab. I needed to refresh the next page to download the manual (click on the circle with the arrow going clockwise). The direct link to the manual is currently https://docs.sony.com/release//CDXGT11W.pdf .
I hope this helps.
Jan 09, 2017 | Sony Car Audio & Video
Audio to speakers from tuner but not from cd?
Are you using an amplifier? If so, you are probably using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). The blue wire is turned off when leaving tuner mode, thus turning the amplifier off.
Oct 23, 2011 | Sony CDX-GT11W Car CD Player
Sony CDX-5005 factory installed in a Bryant boat... no out put in any mode to speakers. What replacement unit will fit and hook up to existing harness?
Any DIN style radio will fit onto the existing cut out.
Stay with Sony CDX family. The connect and color code will be the same.
Do you still has the remote control for this Sony CDX-C5005?
This remote has an "ATT" (almost like mute) //// lower left hand button.
Aim the remote to the radio and press the ATT button and see is the volume restore to normal.
Click HERE (skip to page 6) for a sample picture of the remote.
Jul 28, 2011 | Sony CDX-C5005 CD Player
Hi I have a sony CDX-GT500U car radio. The problem is that when i turn the volume up over 20 it cuts out. What can i do to fix this problem?
Check pos and neg wires on speakers and radio they may be crossed.Does the radio have bass to it or sound like tweeter
Mar 20, 2011 | Car Audio & Video
I need a wiring diagram for the Sony explod CDX-GT11W cd player so I can hook it up to my car
You can download the complete instruction manual in PDF format from Sony CDX-GT11W support website by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Jul 01, 2010 | Sony CDX-GT11W Car CD Player
After a battery malfunction, my CDX-GT11W unit is totally dead... The fuse seems to be fine & I trying to see if my head unit could be dead or if another issue could exist.
Have you check the fuse to the constant and the fuse for the accessory (usually separately fused)... you can also check the back of the radio, on that model i believe there is a fuse built in under/behind the harness... Hope this helps!
May 01, 2010 | Sony CDX-GT11W Car CD Player
My CDX-GT11W punked out, am replacing it w/ an
OK, click Sony Support to download installation guide of CDX-GT11W player that has connection info.
Hope this will help you.
Nov 05, 2009 | Sony CDX-GT11W Car CD Player
Sony cdx m610 resets itself at half volume
You have a shorted speaker or speaker wire. If a wire is touching metal lightly it may not have full continuity (short) and will work until more voltage (volume) is sent to the speaker and causes the short. Disconnect all speakers at the radio then turn the unit back on. Turn up the volume and see if it cuts out. If it stays on, re-connect speakers one at a time and test. Once you find the problem speaker, disconnect the wire at the speaker then test again. This will eliminate the speaker itself as the problem. Test again. If it still shorts, trace the wire from dash to speaker and look for a cut in the sheathing exposing the wire. Repair or replace the wire and you should be good to go. If the unit cuts out with all speakers disconnected, the problem is internal and will need to be serviced. Before you repair/ or replace the unit either check all the wiring and the speakers or have someone do it for you so it does not give you a repeat performance. Hope this helps.
Oct 01, 2009 | Sony CDX-M610 CD Player
Clock set
try turning the radio off and hold down one the buttons until it blinks then adjust
Dec 29, 2008 | Sony CDX-R3000 CD Player
Lost instructions for sony cdx-gt11w car cd receiver
Press and hold the volume knob until the display shows clock adjust.
use the forward and rewind serch buttons (the small arrow buttons next to the volume nob) to switch hour and minute.
use the volume knob to adjust the time. When done press the volume knob to return to normal operation.
HTH
Apr 22, 2008 | Car Audio & Video
Car Audio & Video Logo
671 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
