The bottom of the screen pulls up 2 inches approx. when cold. After it warms up the screen fills in ok,but the TOP then becomes "stretched and distorted". Some of the text is also sometimes missing due to this problem . I found 1 vertical size control on the chassis,but adjusting that did not fix the problem.
SOURCE: screen distortion
Is it a clean vertical line or a fuzzy vertical line? It could be as simple as a cleaning.
SOURCE: Panasonic PT-47X54
This is the vertical problem,it is a bad capacitor you must replaced all electrolytic capacitor in vertical section and resolder all associated parts there,so it works better again.
Hope it will helps you;
Regards,
VOTIT
