Back to:
Tags:
Amana AFD2535DES French Door Refrigerator
Temperature Problem - Amana (Maytag) Refrigerator... (by 5 users)
posted by billyballs on Oct 13, 2007
Serial # 10939246EX.  The temperature in the 2 door upper compartment is not holding.  I normally set it at 4 (medium temp) but had to turn it up to the coldest - 7.  Still not functioning.  Having to throw out milk, dairy products, etc.  This unit is not 2 years old. The freezer section is working just fine. I called Amana Customer Service and a recorded message came on telling me to call back Mon thru Friday.  This is Saturday morning and I have been looking for the service manuals that came with the refrigerator, but still can't locate them.  Any suggestions on what I need to do?  I think the refrig is still under warranty.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by althera, posted on Aug 06, 2008
My Amana AFD2535DES French Door refrigerator has the same problem. The freezer works but there is no refrigeration. The repair person said the motor that runs the fan to cool the fridge blew out. I bought it January 2006 and it broke down 3 months later. It was still under warranty then so it didn't cost me. Now 2 1/2 yrs later, I have the same problem. This time the repairman said the part will cost $200 plus labor. I just can't afford it and I will just have to do without until I can...
Comment by mattkor, posted on Jun 18, 2008
Amana AFD2535DES. Same problem as described - Freezer & Ice Maker functioning as normal, but the refrigerator was warm with no cold air blowing through the vent mounted on the back wall of the refrigerator.
The Repair man replaced the Evaporator fan with Maytag Part number: 12002744 labeled as "Motor Kit - Evap Fan". To install remove freezer door (Lift), freezer baskets and un-screw the back interior wall of the freezer. The new fan motor, that is about the size of a fish-tank pump, will plug in and mount on the existing brackets.
I paid $143.20 total for the repair, $45.00 for the part, $55.00 service fee $35.00 labor + 6% tax. Looked like a simple do-it-yourself job for those who are having the same problem. Needless to say, I'm not thrilled that I had this problem on a refrigerator that is 2 years old, especially after reading on the web that this is a very common problem. Maytag/Amana won't be considered for my next appliance
Comment by aardwizzo, posted on Apr 23, 2008
Very similar problem but my model number is AFD2535DEB. Freezer is freezing just fine. No cooling air going to the fridge compartment. Damper is open. Not sure where the evaporator fan is but there is a fan on the back at the bottom which seems to run continuously....at least continuously since this problem was discovered.
Comment by jdale2000, posted on Nov 11, 2007
Damper door is open - no ice - fan next to compressor is running - no cold air in frig part - - ?? Thanks
Best Solution
posted on Oct 14, 2007
Helpful (85)
fridgetech
Rank:Guru Guru
Rating: 88%, 808 votes
This comes with a 1 yr warranty from date of purchase.  Look and see if there is a thick frost buildup on the back panel in the freezer section.  If no frost, shut the freezer door and feel for air flow out of the top middle vent in the fridge section.  I would remove that vent cover to make sure the damper is open.  If the damper is closed push it open then feel for air flow.  If no air flow is detected then the evaporator fan motor is bad which is a very commom problem on this model, in fact the most common problem.  If the damper is shut and when you hold it open you do feel air flow then the damper is bad.  Let me know what you find.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Temperature Problem - Amana (Maytag) Refrigerator Model AFD2535DES:
I don't want to Accept this solution
Solution #2
posted on Jan 23, 2008
Helpful (85)
Psalms
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
Check the heater for the refridgerater, if you put the defrost into manual mode (turn the freezer switch to zero several times 2 ) it should go into defrost mode, the heater is located at the bottom of the evaporator (inside the freezer door). If it doesn't go on then the heater or the bimetalic unit are bad.
Thank You!
Can you Help with these Refrigerators problems?
Both the freezer and refrigerator stopped cooling. The...
I have the same problem with the refregerator, after he...
Same problem as described by others. Fridge suddenly...
Sigh. Had to replace the relay overload just 2 months...
Our unit is three years old. the freezer and ice maker are...
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
