Question about Kicker SX650.1 650W Mono-Block Amplifier w/Remote '04 Series
I cant get power to the amp, everything is hooked up right, i replaced the power cord fuse... what else could be wrong,...???
  • Tyson Strickland
    Tyson Strickland May 11, 2010
    have you checked the cable for power?
2 Suggested Answers
  • 87 Answers
SOURCE: I cant get power to the amp, everything is hooked
Check in this order:
  1. Battery connection
  2. Fuse at battery
  3. Ground wire at vehicle
  4. Bat. and ground at amp
  5. Remote turn on lead should read 12v
If you have no power at the turn on lead pull deck and see if it cam disconnected, should be blue w/ white strip.
Posted on Jun 02, 2009
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
Cant get the fuse out
The fuse is in a "boat" right next to where the power cord plugs. Pry outward on the tab of plastic where the power cord plugs in. The tabe is about 1/4 inch wide.
IF THE FUSE HAS BLOWN, better find out why as replacing it MAY cause further damage to internal components. If you do replace it and it blows again, take amp in for servicing.
Mar 06, 2011 | Ibanez Tbx150h Tone Blaster Xtreme Guitar...
I have a visonik 800watt amp and i got it from a friend for free and i hooked it up right and as soon as i turned it on the 2 fuses blew then i replaced them and tryed it again and it stoped again so i...
Its the amp, do not put any more fuses in it
you need to get it checked out by a technician.
Its probably a power supply fault or blown output devices.
Hope this helps
Thanks for using FixYa
Aug 02, 2010 | Visonik V2508 2-Channel Amplifier
My amp is flashing in and out of protect
you must likey just fryed the wires, try putting in bigger fuses, and unhooking everything and re hooking it up
Jun 13, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
Cant find a replacement fuse for the power cord
the fuse is located in the cigarette lighter plug, at the end you will see a silver cap and then the disk that goes over the top of it, that will turn and then you will have the front open to replace the glass fuse that is in it... to find the fuse size, after the fuse is out look at the silver ends it will have the size stamped on it... it might be a 40 amp fuse. or 20 amp. just look at the silver sides on the fuse you will find that there... hope this helps you out
Jun 03, 2009 | XRS-757 Radar Detector
I cant get power to the amp, everything is hooked up right, i replaced the power cord fuse... what else could be wrong,...??? the green led light is off and i tested to volts on the remote terminal and it...
  2. Fuse at battery
Jun 01, 2009 | Kicker SX650.1 650W Mono-Block Amplifier...
JVC KD-s34
and the speakers are hooked up right ?
then it should be working..
did you check the fuses ?
did you check if it comes on with the car started?
are the wires the correct amp ?
try connecting both wires directly to the battery ?
if all that is correct then by all means you got everything hooked up corectly and it should work, return it to the store and have them check if its working correctly
Jul 12, 2008 | Car Audio & Video
Dont know whats wrong
You can check the fuses if it has more than one. Or another thing that might be wrong is that you might have to big of a speaker hooked up. Or your power wire might be to small because if its two small then the amp cant get enough power to power a big speaker.
Jan 25, 2008 | Earthquake Sound PH-D3 Car Audio Amplifier
Kicker SX650.1 650W Mono-Block Amplifier w/Remote '04 Series Logo
66 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
