Question about Dryers
Kenmore Dryer F 26 fault code
Hello, I have a Kenmore electric dryer model 110.8656, and it has a flashing fault code F 26. What is this code? Thanks, Rob
  • 460 Answers
Code F26 Door switch error
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for 5 secondes.
==========The following information is for technitions only========
Possible Couses/Procedure
* Door not open during consecutive cycles.
1.- Open and close the door.
2.-Veryfy CCU operating by running a Diagnostic test or any cycle.
3.- Check door switches contacts.
4.- The resistenve of both door coils (between pin 1 nad 3) should be aprox 320_O_
hope this information will help U
Are you happy with my help?
Posted on May 12, 2009
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Kenmore he2 front load dryer
door switch error...implies the door is ajar..or that the switch is not working.
Feb 26, 2008 | Dryers
KENMORE DRYER # 110.67042600 CODE F1 , CAN THE THERMITER BE SHORTED OUT
F 1 error code flashes, when there is a primary control board failure. To fix, the "F 1" failure the machine control board will need to be replaced. Not cheap part.
press the helpful button and follow me on fixya for more info and tips
Kenmore Dryer Model 110 67042600 11067042600 110 67042600 Parts
http://www.appliancepartspros.com/parts-for-model-kenmore-11067042600.html
Kenmore Elite Oasis electric dryer problems Sears PartsDirect
Feb 03, 2016 | Kenmore Dryers
I have a 26-62512 dryer, what are the electrical requirements.
If this is a Kenmore model ELECTRIC dryer, you need a dedicated (220-240VAC) receptacle on a circuit capable of handling 30 to 35 amps.
If you need to know how to properly install your power cord, the following link explains how:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions or concerns, please post back with your complete MODEL NUMBER (located on a nameplate around the door opening) and let me know. I hope you find this information helpful.
Oct 06, 2010 | Kenmore 62602 Electric Dryer
I have a Kenmore Elite dryer. Model # 110.67082600. The dryer has not been used in two days and I noticed it beeping. I unpluged it and plugged it back in. It did the same. It seems to run but after...
If you have a little bit of knowledge mechanically you can unplug the dryer and pull the top off by removing the 3 screws across the back at the very top, slide it back and lift it off. Inside of the dryer, at least in mine, there was a plastic folder on the inside with tech instructions that list the fault codes and it also tells you how to run a diagnostics mode on your dryer. Hopefully this will help you at least determine if it is something you need to call a tech to fix.
Aug 06, 2010 | Kenmore Elite HE4 Electric Dryer
HI I HAVE A KENMORE ELITE OASIS ELECTRIC DRYER MODEL 110.6708 I KEEP GETTING A F44 FAULT CODE WHAT IS THIS FOR ?
44 flashes if the motor control detects a low voltage condition.
This error code could also be caused by poor air flow, loose wiring harness or a malfunction of the electronic control board.
You can disconnect the vent hose from the back of the dryer & compare that airflow to the airflow at the outside damper, they should be almost the same.
If you have a multimeter and the ability to safely check the voltage at the dryer outlet, you can check for 120 volts at the outlet for the dryer.
If the voltage is low or drops when the dryer is running, this is causing your problem.
You could have a loose wiring connection.
If the outlet voltage is okay, you could have a wiring connection problem between the outlet and the control board of the dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 04, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Sounds identical.
This is what the fault means:
Motor Drive System Failure F-26 flashes if there is a motor drive system
failure. See TEST #3 in manual
Aug 03, 2009 | Dryers
I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
May 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore He2 front load dryer
cant seem to find a fault code f 26, if you remove the top panel on your machine there should be a tech sheet explaining most f codes on the right side in an envelope, if not remove bottom panel (its in there somewhere)
Dryers Logo
688 people viewed this question
Top Dryers Experts
