Question about Dishwashers
Dishwasher slowly fills up with water after wash cycle completed
My Simpson 860 Dishwasher works well, but recently it has started to fill up slowly with water after the cycle is complete.Turning off the water supply at the tap is required to prevent this happening. Thanks, Mike
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Inside the bottom of the dishwasher under the lower rack to the side there is a float that regulates water level. jiggle it up and down a few times , it will be OK. Vitally
Posted on May 12, 2009
Recently had a leak in our water pipe between mains and house.We had the pipe replaced.Then the washing machine wouldn't fill so we replaced solenoid valve-it works now. The dishwasher won't fill now
when the pipe was repaired , there is every possibility that dirt got into the pipe and will affect all solenoid operations and taps
remove all hoses and flush the pipe out well
Oct 21, 2016 | Simpson Washing Machines
Recently had leak in water between mains and house. Pipe replaced.Then washing machine wouldn't fill.Replaced solenoid valve -works now.The dishwasher Simpson EZISET 52B850WJ*03 won't fill.Same?
Could be dirt in the water lines after you repaired. You should always run your taps for a while before running machines that use water. I like to run water from my out side taps if I have outside repairs.
Oct 21, 2016 | Dishwashers
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
My simpson ezi sensor will not fill on wash cycle, the water enters very slowly
Check the pressure on the incoming water pipe (make sure stopcock/isolation valve) fully open then check that valve opening fully (this may be able to be removed) will be one or the other :)
Nov 05, 2014 | Washing Machines
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water not emptying in dishwasher model simpson silencio 850
How long does it take to wash dishes completely in a ASimpson dishwasher
Apr 18, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does n
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
Apr 16, 2009 | Dishwashers
GE Nautilus Soap does not dissolve
What is happening, is that your dishes are washing dry. Start the dishwasher and slowly turn the timer till it starts to fill. Let it go and see how they are after
Jun 20, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
362 people viewed this question
Top Dishwashers Experts
