Question about HP Pavilion dv1000 Notebook
White vertical line on screen ? hp pavilion
Corkyewing@cox.net
  • audrenetom May 20, 2009
    how do i remove a vertical line from my PC
I have a hp pavilion 17 inch laptop and the screen is starting to get white vertical lines. I have 2 lines now. How to I fix this problem? Mrs. O'rourke
you have to first diagnose if the issue is with the hardware or the software.
You can do that by checking if you are getting the lines in BIOS or at the HP logo. if yes you have to get the screen replaced
Else you can simply reinstall the drivers
Jul 05, 2010 | HP Pavilion zd8000 Notebook
HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Dec 08, 2009 | HP Pavilion zd8000 Notebook
Vertical multicolored lines appear. Sometimes there are couple of vertical white stips and vertical lines
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor in the same time that means the video card is ok and the problem could be : the screen of the laptop or the invertor or the cable that attaches the screen to the mainboard. Have it checked by a professional.
Oct 05, 2009 | HP Pavilion zd8000 Notebook
White vertical line on monitor screen
The vertical line is because the screen is going, it needs to be replaced fix the problem. Try searching on Ebay if your laptop isn't under warranty.
Aug 30, 2009 | HP Pavilion zd8000 Notebook
Same problem with my zd8000 HP Pavilion laptop
what has happened with your notebook is a simple wear factor. on the LCD screen there are ribbon cables witch join the main PCB controller head to the LCD laminated portion (what you see) have begun to wear. i have just recently replaced a screen because of the same issue. try gently flexing the the screen and see if the lines dissappear. next open the screen up, and check the cable running to the back of the screen take care as to not damage anything.
Aug 12, 2009 | HP Pavilion zd8000 Notebook
Black screen with vertical lines through it
Could be faulty graphics chip or faulty screen. If you can hook up external monitor and picture is fine then probably faulty screen. If external monitor shows same problem the faulty graphics chip. Take to repair shop and let them have a look.
Jun 10, 2009 | Compaq Presario M2000 Notebook
Vertical white line on laptop display
Yes, this is a defective screen. The only fix is to replace the screen. It's called a column of dead pixels. Since it is under warranty, contact HP to have them warranty it out or take it back to the place you purchased it from for an exchange. Please take a moment and give this answer a good rating of fixya. Thank you.
Dec 26, 2008 | HP Pavilion dv7-1130us laptop
Vertical lines o my desktop
uninstall video driver reboot it should start on windows basic video drivers if it does and screen is good try reinstalling your original card drivers. or search on the net for updated ones
Jul 20, 2008 | Sis 6326, (4 MB) Graphic Card
Video freezes up to vertical lines or blue or white screen
Clean the CPU cooler and everithing else from the dust!
Turn off,open the case, use air spray to clean.
(I use vacom cleaner and a small brush, but you risk your component if you do the same! I'm professional.)
Nov 27, 2007 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
HP Pavilion dv1000 Notebook Logo
1,943 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
