Question about HP Compaq Evo Notebook N410c
Notebook does not come on
Even though the power button is pressed, the notebook does not come one. I have taken it to Best Buy to have them look at it. It came on with no problem, so I took it home. It has not come on ever since. What can I do?
  • 233 Answers
Have you ckecked your power cord?
Try the simple things first.
Posted on Oct 13, 2007
Hp 2133 screen is blank when you turn on the power button and only the power button light works
I had the same thing with an MSI notebook. This is most likely a hardware issue and can only be fixed permanently by replacing the motherboard.
For me one trick worked though... when turning it on, instead of pressing once, press the power button rapidly multiple times. I've been using my notebook like this for half a year now, its quite tricky, doesn't always work, but cheaper than a new mobo.
Aug 08, 2011 | HP 2133 Notebook PC
Hello, I've left my notebook (Toshiba Tecra A9 running on Windows 7 enterprise) without using it and It went into sleep mode. When I've turned it back on it has taken me to a log-in screen and is asking...
Yes, this is a problem with the Toshiba laptop drivers not reloading correctly from a suspended state.
right click the battery icon on the lower right toolbar and select 'power options'
if you are in 'power saver' mode or sometimes even in 'balanced' mode, the system will throttle back enough memory to keep basic functions from preforming properly.
you can go to the advanced options and change how long it will take for the system to sleep, hibernate, what happens when you close the lid and many more.
I recommend 15 mins digging through and reading these settings to become familiar with what they do.
you never know when they will make a difference :D
Nov 16, 2010 | Toshiba Tecra A9-S9012X Notebook
Battery Wont Charge on my Acer Aspire One Notebook, Orange light flashes when power on button is pressed, I have checked that the charger is working fine but notebook won't come on as battery is so flat. I...
Hi there as per your information there is a chance of battery damaged. So i suggest you use your battery in others laotop for confirmation. If your found the same problem then buy a new battery . Thanks & waiting for your feedback.
Mar 17, 2010 | Acer Aspire One PC Notebook
My dell precision m65 battery does not get charged at all... Even though i charge it, it shows only 12% of charge n says low battery... Kindly advice me what could be done...
If your battery is not charging there could be two reasons for the same . First the battery has exceeded its lifetime and requires a change or is faulty
Second your ac adapter is not giving enough charge to charge the battery.
Open the battery health meter , by pressing the Fn+ F3 key on the keyboard . check if battery reports any error message.
Shutdown the computer and disonnect the Ac adapter and the battery and press the power button for 10 seconds
Reconnect both the Ac adapter and the battery
power on the system and tap on the f2 key slowly on the left side of the screen , look for the option that says battery info.
Check what is the status of the Ac adapter and is the battery showing charging.
if the Ac adpater shows as none, then adapter needs a replacement otherwise the battery.
Thanks for using fixya
Aug 15, 2009 | Dell Precision M65 Notebook
Dead sleep
happened to us many times, the sleep to death error
logic board problem. buy a new mac realy.
try this, reset prom
take out the power cord. press hold the power button
and plug the power then takeoff power button and press it again.
try this, press hold P and I and power on
Feb 21, 2009 | Apple iBook G3 Mac Notebook
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
This is straight from the manual:
Occasionally, Windows or the notebook might stop responding, so that you cannot turn the notebook off. If this happens, try the following in the order listed. Press the power button to restart.
• If possible, shut down Windows: press ctrl+alt+del, and then select Shut Down > Restart.
If the system will not allow a software shutdown, press and hold down the power button until the display shuts down (about 4 seconds) and then release the power button. Press the power button again to restart.
• Use a ballpoint pen or a straightened paper clip to press the reset button on the bottom of the notebook.
In other words: You will not loose any saved data if you reboot your laptop this way. All unstored information (open documents etc.) might be lost though.
Dec 20, 2008 | Computers & Internet
Toshiba laptop
open the back case and put away your cos cell for reset bios .
after 15 minutes refix cmos cell to its position .then try.
best of luck dear.
Nov 01, 2008 | Toshiba Satellite A135-S2276 Notebook
Compaq Presario 700 PC Notebook keyboard locking out
Check that your notebook power settings are correct, it may be that when you press off or shutdown it's actually going into hibernation or standby, this is only correct when you close the lid without shutting down through Windows. As for Windows Media Player, you cannot remove it as it's a Windows component, you can only dissable it through Add/Remove programmes>Add/Remove Windows Components.
Dec 17, 2006 | Compaq Presario 700 470024-192 Notebook
HP Compaq Evo Notebook N410c Logo
26 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
