When i put my computer on is telling me no cable signal and it will not come on and all my connection are all in place
    Problem Solver:
  • 15 Answers
1 possibility is that it might be conflicting with either an onboard graphics card or a graphics card you have installed. Try taking out the graphics card (if you have put one in) and plug it into the onboard graphics card and see if it still gives the same prob. If it works, go into the bios and look for something that lets you choose between intgrated graphics or agp/pciX.
If you cant find it, email me and ill do the best i can to help you further.
markmayo@axxess.co.za
suchhotness@gmail.com
Im more likely to reply to the axxess email.
Posted on May 12, 2009
SOURCE:
How do I get out of no input signal
Hello
The video signal is not getting into your display.
Check the connections on both sides of your cable (display side and display card side). If that didn't help, switch off your PC, make sure youre display card is in its correct place (try taking it out and putting it back again). Switch on your PC and check again. If the problem continues, try replacing your display card.
Aug 11, 2014 | Sony VAIO Computers & Internet
Not detecting right channel audio input
First make sure the connections are on the correct places. Audio is white and red, not yellow, right channel is red. Then swap the left and right cables, to see if the signal on the left cable input is now heard on the right channel. This will tell you if the input signal on the right cable is missing or if the internal handling of the right signal is bad.
Dec 14, 2013 | Pinnacle Video Transfer
When my computer says check signal cable what does it mean?
Your monitor is telling you that it thinks it is not receiving a video signal from the computer. You need to verify which of three components is not working, the computer, the cable, or the monitor.
The first thing to do, obviously, is to check that the cable connecting the computer to monitor is good. You will need some extra components to do the checking. I'm going to assume that the cable is detachable at both ends.
First you can try replacing the cable with different one. If the replacement cable works, then it's the cable.
Secondly, you can try different monitor. If you connect this in place of the first monitor, and it works, it's a faulty monitor (needs repairing or replacing).
Third try a different computer with the original cable and monitor, if it all works it looks like the video on your PC has malfunctioned. (This might also be your conclusion if a system comprising a different cable and monitor fails to work with the original PC)
You might just be able to verify the cable by testing the connectivity of all the wires in the cable with a meter, if you knew the pin out of the cable at both ends.
If you find out the computer is getting a signal out, there could be many causes for that, each having its own solution (or not as the case may be)
12.April.2014
Aug 08, 2012 | HP Computers & Internet
I could not connect to internet with my sony bravia kdl 32ex520 I am using the ethernet cable( no modem) when i check the status it is showing as cable is connected and internet is failed error 1106 i...
Ethernet connections between the tv and the computer into one signal frequencies are not compatible signals.Ur main home computer have internet service connection go through a wire or wire less Router for a internet signal through out the house.Connect the tv internet signal through the Router.Internet signal will work fine.
Aug 18, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
When I turn on the computer, the monitor massage states there is no communication signal with the computer
Warning: Before Doing the Below Steps don't forget to Unplug the Power cable, monitor cable, keyboard and mouse and any other device connected to your computer.
Do the following Steps.
Step 1: Open the PC case(not your monitir)
Step 2: Locate the CMOS battery on the mother board.
Step3: Remove the Battery and leave it for 4-5min, now put the battery back in its proper place.
After doing above steps now you can connect the power cable, VGA cable, keyboard,mouse etc... and switch on the computer and see if you are able to get display. If still you find the same problem you can try removing RAM from RAM bank and clean it with a brush or a cloth ,both RAM and RAM Bank. Now Put back the RAM and switch on the computer.
All the Best and Hope it will work for you.
Jul 11, 2011 | HP Compaq Presario SR1720NX (EL435AA) PC...
I have a synaps monitor model mt9bbk. The screan will go black and power led will flash.
Display Power management is being triggered because no input signal was detected. Verify that the video source is connected and on. (Computer, notebook, etc).
- Try another computer or laptop that you know is working properly.
- Do you see any change on the screen if the display cord is completely disconnected (often a "Test" or "Check Cable" message appears). - Inspect the signal cable from the monitor - worn? Any places where the cable was bent to an extremely small (acute) angle? (less than 75 degrees?) Try gently moving the cable around at either end and see if you get a partial signal on the screen (while connected to the computer). If you do, the signal cable is damaged, if possible replace it. try: www.monoprice.com
Apr 14, 2011 | Computers & Internet
Problem just started. Getting na signal on TV.
1. Remove the video/display cable from both TV & Laptop.
2. Again Connect the two devices properly.
3. Press "Function Key+F5" to connect to the TV (External Display)
4. Also put your TV in "TV/AV" mode.
tell me if it don't helps...tc! :)
Jan 05, 2010 | Toshiba Laptop Computer Battery PA2510,...
Connect Cinego to MacBookPro
The projector has a computer video cable input on the side of the unit. If yor MacBook has a female VGA output, simply purchase a VGA cable (double male) at a Radio Shack or WalMart, or other comparable retailer, and connect the two. The Cinego will find the input signal from the Mac, and you have to press the right keys on the Mac keyboard to tell it to put the screen signal through the VGA output on the side of the MacBook.
Apr 19, 2009 | Radio Shack Cinego D-1000 Multimedia...
Connecting the WAG160N to a Cable broadband supply
Yes, it will work. Hook it up like this:
Ethernet cable from the back of your cable modem to the internet port of the 160n. Any computer that will be wired to the internet will then run from the ethernet port in the back of the computer to one of the four ports on the 160 otherwise, using your wireless internet, the computer will be able to see the signal put out by the 160 and connect to it. Oh and please take a moment to rate this solution with a fixya rating. Thanks!
Jan 02, 2009 | Linksys Computers & Internet
Installation
Check the pins of the cable to make sure there are no bent pins. Move the cable at both ends to see if the cable is split.
Leave only the monitor connected to the video card, nothing else like svideo.
Open the PC get the video card out and the put it back into place properly, if it's not fixed with screws it could get out of the slot due to vibration or shock.
Aug 03, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Computers & Internet Logo
71 people viewed this question
Alun Cox
