Jacuzzi Bath Era BK37 959 White toilet bowl and tank Logo
Posted on May 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a manual. The water keeps running.
Is there a manual? The water keeps running and it isn't the flapper.
Anonymous
Level 2:
  • Expert 62 Answers
  • Posted on Jun 05, 2009
Anonymous
Expert
Level 2:
Answers
62
Questions
0
Helped
61816
Points
140
The fill valve shut off level setting is too high. water in the tank is overflowing in the overflow tube. adjust fill valve to shut off at lower tank level
A toilet that keeps running
without knowing your particular brand The most common problem is flapper. go purchase a fluid mater Model # 400CRP14 about $13.00 . replace fill valve while your at it it. If you only want to change flapper purchase fluid master Model # 504 instructions are included, videos are available on YouTube
Aug 31, 2018 • Home
Water keeps filling in toliet even after full
hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
Nov 27, 2017 • Home
2answers
How do I adjust the flapper on the Fluidmaster 400AK Complete Toilet Tank Repair Kit For 1.6 GPF?
I struggled myself for a while looking at many online videos, replaced the flapper and the toilet still flushed on it's own! I noticed that the flapper chain got often stuck when the flapper lowered down, which caused water still running out and than I came up with my own idea; there is a white plastic fastener inside the water tank for the flush handle outside, that got apparently loose in time and can be even fastened manually, no tool needed! This fixed my problem! I haven't seen this tip anywhere, so I wanted to share it.
Mar 31, 2015 • Home
Runs with out filling tank
Have a really good look at the alignment do they both mate properly/? Also check the seat at the bottom where the flapper closes, if it has any rough/uneven spots on the edge, or nicks etc, it will not seal properly. If you have to push it down to get it to close, is the ball dropping as it should or getting jammed on the rod, etc? Other thing to consider, is your water pressure higher than usual? Higher water pressure will cause back flow at the flapper and keep the flapper from dropping as it should.
Water wont stop running
Water is either running (1) into the overflow tube or (2) out to the toilet under the flapper at the bottom of the tank. If (1) lower the ball or float. Done differently depending on model. If (2) replace the flapper with new flapper designed for your model. (Note: Raise manually the float valve and if water still runs out the little tube that goes into the overflow tube then fill valve is defective. Replace it.)
I have a toto beamis toilet and the water keeps running. It just slowly runs into the toilet all the time.
Be sure and check and verify that the water setting isn't to high and is allowing the water to run into the overflow and thus not letting the valve cutoff... Most all have water height adjustments .....depending on the valve, it could have a screw you can adjust or pinch clamp you would squeeze together and slide up or down to adjust....... other problem could be flapper not sealing off and allowing water to empty from tank to the bowl would not hurt to take a look at it also......hope this helps.....
Sep 05, 2011 • Home
Toilet keeps running even when manually lifting floater to max
check handle to ensure no tension is on the flapper chain when not being flushed. check flapper to ensure positive seal to flush valve. check water level to ensure not overflowing into flow valve. if that's the case, lower water height.
then if still doesn't work, change flapper,
all else fails, change flush valve.
good luck,
steve
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
