Question about GE Energy Star WCVH6260F Front Load Washer
Won't drain My washer worked fine until today when it would unlock and not spin the water out. I cleaned out the filter underneath and got alot of stuff out of there but it did not fix the problem. Also, when I start the washer it seems to hum. Would love to hear of any other ideas to remedy this problem.
    Scholar:
  • 146 Answers
The humming could be coming from the drain pump which may be jammed. The machine will not spin unless all the water has been drained out. If there is still water in the drum, remove the drain hose from where it attatches under the sink or tub and lie it down. Let water drain into a bucket untill the machine is empty. Switch off the machine and unplug it from the wall. Remove the hose that connects the tub to the drain pump from the drain pump and see if there is any obvious obstruction. If you can see the pump impellar, try turning it with your finger. If impellar does not turn freely, replace drain pump.
Posted on Oct 31, 2007
SOURCE:
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a WM2277HS TROMM Washing Machine and at the end of the cycle the water does not drain nor does it spin. Therefore, the rinse & spin cycle only rinses but does not drain the water nor spins. ...
Sounds like a bad lid switch. Check to see if you hear a "click" from the switch when you open and close the lid. If you do not, then you should replace the lid switch.
Nov 26, 2010 | LG WM2277HSW XL Front Load Stackable...
Washer runs fine until spin cycle--will not drain, though the drain pump motor hums. Also will not spin, which I assume is related to the fact that the tub is still full of water. If we manually empty the...
Hello, This is going to be one of 2 problems...either your drain filter is clogged or your pump is bad. Take off the lower panel on front, Behind this panel you will find what looks like a gas cap to a car. Unscrew this gas cap(have some towels handy to mop up water) remove the drain trap (filter) you should see alot of debris,coins maybe a sock blocking it...clean out the trap and replace. If this does not fix the problem replace the pump, although it sounds like it's humming it may be siezed or impellers might be broken. The pump should be located right next to the drain filter at the front of the machine. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Mike
Sep 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Not draining and washer arm not spinning
Have you cleaned the drain filter? The symptoms you describe indicate that the filter are totally clogged.
Cleaning filters should be done every other week to maintain good function in dishwashers, it is not uncommon people forget that.
You access the filter by removing the perforated stainless steel plate at the floor of the washer tub, usually there is a round plastic knob in the middle that you turn counter-clockwise then lift it up. Underneath this plate you will find the main filter, take it out and clean with a soft brush under running water.
May 24, 2009 | Hotpoint 24 in. HDA2130Z Built-in...
Kenmore front load won't drain spins then blinks no spin
Yes this is the place, but you have to mop up the water or it would flood the place; clean out the muck from the filter and refit carefully. You have to clean your filter according to usage, the filter does not self clean, no way.
Feb 25, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Won't spin out on normal wash cycle
I think I figured this one out. I think it means that the washer is not able to drain, therefore it won't spin either. Underneath the washer is a series of outlet hoses and within one of them is a filter. When I finally found the filter it was clogged up with lint, fibers from a pillow and coins. You have to dig the filter out and then clean the filter and rehook up the hoses, this was relatively simple even for me. The washer works perfectly now.
Mar 25, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Front Load Washer Model#GCVH6260F-Problem with no washing, spin or aggitate function but motor works fine...
try cleaning out the filter - it's behind the bottom panel (three screws to remove) you will see a round disk - unscrew it and pull out the filter. I have to clean ours every six months - it's too bad GE didn't put it in their manual, that this needs to be cleaned periodically.
Dec 11, 2007 | GE Energy Star WCVH6260F Front Load Washer
LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
Aug 30, 2007 | LG WM-2277HW Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
144 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
