Question about GE 31GT659 31" TV
Dark t.v. screen
I accidentially turned the brightness on my t.v. down and now I can't see the menu on the screen to turn it back up. What do I do?
Press the menu button 3 times then the chanel down 2 times then hold the volume up button
Posted on Mar 17, 2008
I have plasma tv thats has been getting the pink bands across the screen when the image on screen is bright. It gets worse when cell light is turned up in addition to brightness.
You need to check all voltages there is a sticker on the back of the screen with various voltages these need checking with a digital meter.
Jan 06, 2016 | Samsung Series 5 51-inch PN51E530A3FXZA...
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Itouchs brightness is really low but the brightness level high
You tried setting the Brightness to maximum, but the screen remained dark? Could be a problem with the LEDs that light up the screen. Also try turning it off and back on.
Aug 08, 2009 | Apple iPod touch
Camera shows white screen when used outdoors
You are having the following problems:
White balance setting incorrect.
images are too bright
ㆍExposure is excessive
→ Reset exposure compensation
● Adjusting LCD Brightness
1. In any mode with the exception of Voice Recording mode,
press the MENU button.
2. Press the LEFT/ RIGHT button and select the [Setup]
menu tab.
3. Select the [LCD] menu by pressing the UP/ DOWN button
and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN
button and press the OK button.
[LCD] sub menu : Dark, Normal, Bright
5. Press the menu button twice and the menu will disappear.
Turn camera off. Try removing the fully charged batteries for 30 seconds, reinsert batteries and turn camera on. Hope this helps.
Dec 10, 2008 | Samsung Digimax i5 Digital Camera
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Samsung u340's front screen is very dark
Probably need your brightness turned up. Go to menu, then settings, then display settings, then backlight, then brightness.
Apr 11, 2008 | Samsung SCH-u340 Cellular Phone
Dark screen/picture.
This 30" flat screen TV set may have a problem in the high voltage circuit of the TV set. You may be able to adjust this by taking off the back of the TV set. Look for the block where the large red wire runs up to the top of the picture tube. On this block will be two controls. one will say screen and one will say focus. Try and slowly turn the control that says screen or S on it clockwise and see if you can make the picture brighter. Turn up the control till you just start to see faint lines in the picture, then back the control down till the lines go away. If the picture does not come up when you turn this up, and all you get is a blank screen, you will need to have this set repaired by a qualified repair person. Good Luck
Jul 14, 2007 | Sanyo HT30744 TV
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
The LCD screen is hard to see. What should I do?
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Televison & Video Logo
56 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
