Question about Whirlpool Refrigerators
Light clicking sound from outside whirlpool french
Light clicking sound from new whirlpool french door bottom freezer
  • 22 Answers
Check the fan blade on the fan in the freezer. It could be an object or ice, frost, anything. If this is an Amana Whirlpool, definitely check to see if the fan blade is no longer tight on the motor shaft and has moved forward and hitting the guard in front of it. ( yes, amana whirlpool )
Posted on May 12, 2009
Whirlpool gold French doors freezer in the bottom it's making a knocking or rattling sound like it's coming from the back panel in freezer open freezer it stops close it starts
SOUNDS LIKE YOUR FAN MOTOR IS EITHER LOOSE OR THE MOTOR IS ABOUT TO GO OUT(NOISE INSIDE COULD BE GEAR IN MOTOR GRINDING WHILE WORKING) it stops when you open the door which shuts off he fan motor to help prevent loos of refrigerated air.
Dec 04, 2016 | Whirlpool Refrigerators
The freezer on my French door fridge is forming frostl. Why is this happening.
Is it frost on the freezer inside back wall or inside freezer towards the freezer door on the top of inside freezer box. If back wall then you have a defrosting problem. If it is towards freezer door then you have door seal problem and moist room air is getting inside your freezer.
Oct 13, 2014 | Whirlpool GX5FHTXT Bottom Freezer French...
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
My bottom mount french door refrigerator, the upper part does not cold, it's warm
Sorry your having trouble so soon!
First thing you need to check is inside the freezer section.
The freezer fan, the fan is W10128551 and should be running
along with the main compressor. Since the freezer is working,
I would check the food on the top drawer or on the freezer door shelf.
They too might be soft..without the fan.
I would You tube 'evaporator fan motor replacement Amana bottom freezer model' Yes I know it say's Whirlpool, but your unit is really
a Amana designed unit. I would give this a difficulty of 3 out 5 wrenches.. Take your time..
John Wright
Jul 27, 2014 | Whirlpool GX5FHTXT Bottom Freezer French...
WHIRL POOL STAINLESS STEEL FRENCH DOOR- BOTTOM FREEZER MODEL NUMBER GI5FSAXVY
You should be able to buy replacement stripping at any local hardware and furniture store.
Sep 16, 2013 | Whirlpool GI5FSAXVY Stainless Steel ...
My whirlpool French door fridge is leaking all over the floor. The drip pan underneath is bone dry. I can't find the drain hole inside the fridge to see if it is clogged. Is letting it thaw for tw
there is a water tube connection at the bottom of door on hinge side that has a spring and allows it to swing with door. it also has a fitting there so the door can be removed.it is the tube running inside the door to the ice water dispenser. if it has one, it can leak at the fiting
Jul 07, 2012 | Whirlpool GX5FHDXVY Stainless Steel (248...
WHIRLPOOL REFRIGERATOR FRENCH DOOR ENERGYSTAR 5 MO OLD SAYS COOLING SYSYEM OFF ?
STOP! Don't worry about the other responses- it is SO simple to fix. You just press the two right two buttons (lock and measured fill) at the same time and hold for 3 seconds. That's it!!
May 23, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
I want to adjust the upper doors on a viking french door model vcff036ff. The left door is higher than the right door. It appears that I have to remove the door to adjust it. Dan
USE A SPIRIT LEVEL ON THE OUTSIDE OF THE UNIT FIRST,IT IS POSSIBLY THE FLOOR THAT IS NOT LEVEL.........USE SPACERS UNDER THE FEET......factory build them square.....
Jun 07, 2010 | Viking VCFF036 Bottom Freezer French Door...
Refrigerators Logo
195 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
