Question about Canon PIXMA iP4000 InkJet Photo Printer
Can't get ink from new tank into the head area without forcing w/airpressure (blowing into it). Printer prints after this until the ink runs out. This started after using the cleaning setup many times after an ink spill earlier.
  • 433 Answers
File:///C:/Documents%20and%20Settings/GX-620/Desktop/PIXMA_MP780_750_UG_Win_EN/Output/Chap11_US.htm
copy and paste
From what I am seeing it is very easy to mix up the two black tanks which causes it to keep cycling and using the ink supply.
MPORTANT
• Make sure that the ink tank is inserted in the slot that corresponds to the ink tank’s color. • If you insert it in the wrong slot, perform head refreshing two or three times.
I read this chapter about four times, it is difficult to say the least. I hope this helps, but the only thing I could find on ink being wasted is in the maintenance section.
Posted on May 15, 2009
  • John Viguers
    John Viguers May 15, 2009
    Solution: Snap in ink tanks properly iP4000 /
    iP5000
    Refer to the following steps to verify the ink tanks are seated
    correctly:
    1. After confirming that the printer is powered on, open the paper output
      tray.
    2. Open the top cover and wait until the print head moves to the
      center.
    3. Open the inner cover and check that ink tanks are properly
      seated.
      Properly seated
    4. Press down on each ink tank until a click is heard.
    5. Close the inner cover and top cover.
I have tried replacing all ink cartridges with brand new ones but it keeps saying Error U052 ? I am not really sure why it won't recognize the ink cartridges especially because they are from Canon
The error code indicated, the print head is defective, so it will not get solve by replacing any number of cartridges. Just follow the steps below to reseat the print head, if that does not help, then replace the print head.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
    *MP800R shown
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark <PUSH> on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Aug 28, 2012 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP600 printer, error msg. U052 Cleaning the printer head doesn't help. Replacing with new (full) cartridges doesn't help. The only one thing, that helps now, is to disconnect the printer from power...
Description
Reseat the Print Head to resolve the U051 / U052 error.
Solution
Errors displayed on the printer's LCD screen:
  • U051 Print head is not installed. Install the print head.
  • U052 The type of print head is incorrect. Install the correct print head.
Reseat the Print Head:
  1. Make sure that the power is turned on, and open the Paper Output Tray gently
  2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support (A). (The print head will move to the replacement position.)
  3. Remove all the Ink Tanks in the following manner.
    1. Push the tab (B) and lift the ink tank to remove.
    2. Do not touch the Print Head Lock Lever (C) while removing the ink tanks.
  4. Once the ink tanks have been removed, raise the print head lock lever.
  5. Tilt the print head slightly towards the front of the machine and lift out gently.
    *Before proceeding to next step, check the carriage area for packing material, torn paper, etc. and remove if found
  6. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
  7. Insert ink tanks into the print head.
    1. Insert the front end of ink tank into the Print Head at a slant. Make sure that the position of the ink tank matches the label.
    2. Press the mark (Push) on the ink tank until the ink tank snaps firmly into place.
      Make sure that the ink lamp lights up red.
  8. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
    Note: When the next printing begins, the print head cleaning will begin automatically.
If you have reseated the ink tanks and print head and the error still appears, our industry-leading support team is available to help you Monday through Friday from 10 AM to 10PM EST. You can contact our technical support experts by phone or email:
Call 1-800-OK-CANON (1-800-652-2666)
May 06, 2017 | Canon PIXMA MP600 all-In-One InkJet...
Printer does not print and 2 messages appear: 1)
Enabling bidirectional support Windows 7 / 2000 / XP / Vista:
Access the Printer Properties:
For Windows 7
  • Click the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
  • Click your right mouse button on the listing for your printer, and then select 'Printer properties' from the menu that appears.
For Windows Vista
  • Click / Select the 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
For Windows XP Home Edition
  • Click / Select the 'Start' button from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
  • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
For Windows XP Professional Edition
  • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000
  • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
In the printer's Properties window, select 'Ports', then 'Enable bidirectional support'
SECOND QUESTION:
ERROR LCD: The type of print head is incorrect. Insert the correct print head
Solution: Reseating the MP500 / MP800 print head
Reseating the Print Head Reseat the print head to correct print issues or clear an error. Reseat the Print Head:
  1. Confirm that the printer is powered on and press the button. (The paper output tray will open.).
    Caution: Do not touch the print head nozzles , electrical contacts , or ink supply ports . Doing so may cause printing problems.
  9. Press the mark on the ink tank firmly until you hear a click.
    N
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
I trust this is helpful. Please express appreciation.
Dec 10, 2010 | Canon Pixma MP800 All-In-One InkJet...
My canon pixma ip1300 is showing service error 5100, not printing and yellow light blinks five times thanks in advance..........
Solution: Install the print head and ink tanks correctly iP3000 / i560
Seat the print head Below is the procedure for seating the print head and ink tanks:
  1. Power on the printer.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove the orange tape securing the print head lock lever, and raise the print head lock lever.
    Note: If the top cover is left open for more than 10 minutes, the print head holder will move to the right. If this occurs, close the top cover once and then re-open it.
  5. Remove the print head from its package and remove the orange protective cap.
    <1> Electrical Contacts and Print Head Face's Nozzle Area
    <2> Ink Supply Filters
    Note: To avoid any damage, do not touch the print head face's nozzle area, electrical contacts, and ink supply filters. After removing the protective cap, set the print head into the print head holder immediately. Do not re-attach the protective cap after it has been removed.
  6. Set the print head into the print head holder, and lower the print head lock lever until a click sound is made.
    Next, install the ink tanks.
  7. Remove the cyan ink tank (BCI-6C) from its package. Pull the orange tape in the direction of the arrow to remove the wrap film completely.
    Note: Remove the orange tape completely. If the orange tape is not completely removed, it may interfere with printing.
    <1> Removed correctly
    <2> Removed incorrectly
  8. Hold the ink tank as shown in the image below. Twist the orange protective cap in the direction of the arrow, and remove it.
    Note: Remove the protective cap while holding it, so that fingers will not be stained by the ink.
  9. Insert the ink tank into the slot at the right end, and push down on the PUSH mark on top of the ink tank until a click sound is made. Install the other ink tanks in the same manner.
  10. Close the inner cover and top cover.
    Note: Check that each ink tank is installed in the correct position:
    Properly installed:
    Improperly installed:
    <Left Image> The M ink tank is not fully seated.
    <Right Image> All ink tanks are not fully seated.
Dec 03, 2010 | Canon PIXMA iP1300 Printer
A big PGBK ink cartridge problem
Call - 1-800-828-4040
Verify they are installed correctly.
Remove the print head or ink tanks properly following the procedure below.
1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
2. Open the paper output tray and pull down the inner cover.
3. Remove the ink tanks by pressing the tab of each tank.
Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
raisephlocklever.gif To reinstall the Print Head and Ink Tanks
1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
putinphnlockit.gif2. Insert ink tanks into the print head.
Press the mark 'PUSH' on the ink tank firmly until you hear a click.
3. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
<1> The ink tanks are installed properly.
<2> The ink tanks are not installed properly.
Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes.
4. Put back the inner cover and close the top cover.
Note: When starting printing next time, the print head cleaning launches automatically.
During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
James Mac
Sep 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
labelsa.jpg Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
May 07, 2008 | Canon i850 InkJet Photo Printer
Canon multifunction printer
I believe that he is reffering to the waste ink tank where the cartriges stop to the right when not being used. There are two small foam pads over there.
I cleaned mine by opening lid and have carriage run to the left, then I reach in with a q-tip and press down repeatly until q-tips are almost clean. You will need a flashlight to see waht you are doing.
Feb 18, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon MP530 U052 Error
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Feb 05, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Change ink cartidges
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
  5. Close the inner cover and the scanning unit (printer cover).
    N
Jan 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Can't print in Black ink
I had the same problem I found this solution to be very effective: * Buy alcohol solution (70% or more). You can find it in any drug store. * Remove both cartridges from the printer head. Unplug the printer head from the printer body. Pour the alcohol into paper towel layer. * put the printer head on the top of wet towel with the face of HEAD touching the towel. * clean the head with the towel and get rid of all the built-up ink on the head. * Pour the alcohol into the printer head container (ink-receptacle area is where the ink cartridge normally sits, notice a small hole where the ink flow into the printer). Do not touch any electronic parts and let it dry over night. * Do step 2-5 again if necessary. * Install the cartridge back to the printer and run several head cleaning maintenance, print nozzle check, make sure to repeat this step until no more dead nozzle shown. It worked for me :0)
Jun 26, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA iP4000 InkJet Photo Printer Logo
106 people viewed this question
old marine
old marine
