Question about Intel Motherboard
I need the specs for D 33005 motherbord i need to plug in power switch , reset switch and h.d.d led
I need sound drivers for hp ms7336
Posted on May 12, 2009
Mother bord bios motherbord
try to reset the bios by Removing the laptop battery, locate the cmos battery inside the laptop, remove it then wait 5min, plug in the power, switch on the laptop and then the moment it switches on remove the power plug. Then put the cmos battery back, then the laptop battery and turn it on. All should be right. Referring
Oct 24, 2013 | BenQ Joybook 5000 Notebook
I have unplug the power SW, power led , HDD led and speaker cable , now where i would plug it
Plug them back into the pins at the bottom of your motherboard. They are all labelled for you so it shouldn't be any problem
Mar 01, 2011 | Gigabyte GA-5AA Motherboard
Pin placement for ms 6741 mb
the manual for your motherboard can be downloaded here:
http://www.msi.com/index.php?func=downloadfile&dno=3812&type=manual
On page 2-17, the pin-outs for those connectors are specified in detail. They are part of the JFP2 header:
PIN SIGNAL DESCRIPTION
1 HD_LED_P Hard disk LED pull-up
2 FP PWR/SLP MSG LED pull-up
3 HD_LED_N Hard disk active LED
4 FP PWR/SLP MSG LED pull-up
5 RST_SW_N Reset Switch low reference pull-down to GND
6 PWR_SW_P Power Switch high reference pull-up
7 RST_SW_P Reset Switch high reference pull-up
8 PWR_SW_N Power Switch low reference pull-down to GND
9 RSVD_DNU Reserved. Do not use.
-Jon
Sep 01, 2009 | MSI K8MM-ILSR (MS6741030) Motherboard
On and off button will not work. Is this easy to
open cpu cabinet .
check on motherbord corner side cable pin from power on/off switch to motherbord corner pin jumper correctly.
check on motherbord you find power on/off PIN jumper you cna ground it with any metal like screw driver. then if power on then you have to check that cable or still not start then you have to reset factory defaults settings of motherbord.
For thta pull cmos cell from motherbord for 10 minutes .
Then check.
Aug 21, 2009 | Computers & Internet
Y computer will not start. I checked the power
Try booting from a rescue CD to see if the harddik is the culprit.
If you don't have one, try making one using instructions found at
http://www.help2go.com/Tutorials/Windows/Create_a_Windows_Boot_CD___Rescue_CD.html
Be sure to set Boot sequence to CD-rom in Bios.
Jul 30, 2009 | HP Pavilion a785c (82916061390) PC Desktop
START UP PROBLEM
You need to reset bios.
Open cpu cabinet and pull cmos cell from motherbord chipset for 15 minutes then all settings are factory defaults.
Aslo you can reset settings with jumper settings .
Refix your RAM memory. Refix processor.
Reattch ATX power supply to motherbord.
Thanks for using fixya.
Please rate solution if it helps.
Jul 20, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
What pins do you plug the hdd led,power led,reset switch and power switch? on a intel ca810 motherbord any diagrams would be nice thanks
Intel no longer offers interactive support for this board.
However i did find you a schematic of the circuits and product guide. It is in adobe format.
I hope this helps.
May 13, 2009 | Intel Desktop Board CA810 Motherboard
P4mmv2 motherboard
see the diagram below for front panel conections
Sep 02, 2007 | EliteGroup P4VMM2 Motherboard
Intel Motherboard Logo
70 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
