Question about Pioneer DEH-P700BT Car CD Player
No volume We have installed properly on a 2002 kia optima. All wires connected properly - face shos volume control going up and down but no sound from speakers.
    Champion:
  • 453 Answers
2 thing , 1 bas audio ic , 2 the wire conecction dont macht
Posted on May 12, 2009
The radio will turn on but there is no sound. All the wires are connected and look to be in good condition. Any idea what could be the problem?
How to take apart Kia Optima 2004 to get to radio - YouTube
? 1:45
https://www.youtube.com/watch?v=Bf89qUhlgp4
Jun 18, 2010 - Uploaded by Alex Alberti
How to take apart kia optima to get to radio and wires. ... Noharm to my console and I have done the remove 4 times so far. ...to get to the wires, but i have a jvc kd-s26, and there are way too many wires on the kia radio than my jvc. If I just electrical tape the unused wires, will I be able to still have sound?
Kia Magentis & Optima Forum [Archive] - Kia Forum - Kia-Forums.com
www.kia-forums.com > Kia Forum > KIA Models
[Archive] Discussion area for every generation Kia Magentis and Kia Optima. ... Towing 2015 Optima Behind RV · 2012 Optima turns over but will not start? ... 2006 Optima Passenger window will not go up · Is there an Optima HYBRID ... 2006 Kia Optima LX V6 code meanings? ... 2004 Kia Optima LX--Repair or Replace?
2004 Kia Optima Car Radio Wire Color Codes
www.modifiedlife.com/2004-kia-optima-car-radio-wire-color-codes/
Feb 03, 2016 | Kia 2004 Optima LX V6
Need wireing diagram for 2002 kia optima stock stereo
Contact WWW.crutchfield.com they have wiring diagrams for 99% of vehicles on the road today.
Apr 16, 2013 | 2002 Kia Optima
Push on gas peddle and no engine responce 2007 kai optima
you have a throttle by wire it is the same as a slot car controller you may need to replace it it whirs out from on and off the throttle.
Feb 17, 2013 | 2007 Kia Optima
The sound on my 2003 kia optima doesnt work
I sugest to check speakers wires, if they are ok, then could be a internal amplifier problem.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 26, 2012 | 2003 Kia Optima
My kia optima's speedometer will work sometimes but then quit.
All instruments are controlled by a computer/ If you have only lost speedo, more than likely you have a bad speed sensor located in the top of the transmission. Yes, you can change yourself by unscrewing it from trans. It will have 3 wires going to it and 1 wire is brown.
Mar 06, 2018 | 2002 Kia Optima
Installation kia 2002 optima fan belt
Hello css_trish and thank you for asking your question here on fixya.com.
I have actually written a general information article that will walk you through the general process of changing the fan belt on your
2002 Kia Optima. It will also point you to the resources you need for getting the diagrams of how the belt needs to go back on.
Here is a link to that article:
How to change the fan belt on your
2002 Kia Optima
If this has helped you in any way, then feel free to follow my Twitter account for more great money saving tips and tricks. twitter.com/acoates23234
I follow back, too. :)
Thanks for reading.
Oct 13, 2010 | 2002 Kia Optima
2002 Optima: where is the speed sensor on a 2002 kia opitma...
The speed sensor is located on top of the transmission Just under the Air Filter. So you will have to remove the Air Filter and you will see your two main sensors (I/O sensors.) . For more detail-----------
If you remove the air filter and look down on top of the transaxel, you'll see a couple of connectors that lead to sensors that are inserted into the transaxel. The Output Speed Sensor is the one towards the rear of the car, towards the driver. The Input Speed Sensor is the one a little hidden under a diagonal cable (with a boot covering the cable) right in front of your face. Thanks. you can rate this solution and show your appreciation.
May 17, 2010 | 2002 Kia Optima
2004 kia optima,break lights stay on,taillights will not come on,bulbs are ok
It sounds as if your brake light switch is bad, or, your brake pedal return spring isn't pulling the pedal back towards the seat.
First, just pull up on the brake pedal, opposite direction of when you are applying them & see if the lights go off. If yes, you'll need a new return spring. If not, then usually the switch mounted up above the pedal is defective & needs to be replaced.
I believe once that is corrected, the lights should work properly if your parking lights are working, as they both use the same circuit. If not, you'll have to do some testing of those wires & backtrack to the light switch.
The Brake light switch also can have the cruise control switch & other controls associated with it but not always, depending on the specific Model & Year & other options so testing it could require a wiring diagram, I've included a link that will give you the wiring colors for the brake light switch itself. Testing the wiring is the only way to determine any other condition that would be causing that to happen.
Here's the link for the wiring:
http://www.commandocaralarms.com/wiring/2003-2005/Kia/Optima/893.html
It shows the brake switch wires as GREEN.
Good Luck.
Feb 08, 2010 | 2004 Kia Optima
Wiring diagram for 2002 kia optima
Not a guarantee but try the kiatechinfo.com in the below information:
Kiatechinfo.com will get you all the information you need when working on a kia 2nd only to a chiltons or haynes manual.
For kiatechinfo.com register (its free) then select the information for your car make model engine. Then either do a search for timing belt or pick from proper items in cloumn to the left.
Aug 15, 2008 | 2002 Kia Optima
Pioneer DEH-P700BT Car CD Player Logo
103 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
