Question about Logitech Cordless Mouse
Need to change the battery
No obvious way to get the cased opened.
  • Jeff May 11, 2010
    The battery door for most of these is on the bottom.
    You will need to provide the model number for more specifics.
  • 91 Answers
Sorry, The lithium-ion battery is designed to last the lifetime of the mouse, but even so, there is no way for the end user to remove or replace the battery if it does start malfunctioning. Your only hope is to purchase another. I recommend purchasing one made by Microsft!!! :)
Posted on May 12, 2009
  • AJ Jones
    AJ Jones May 14, 2009
    Glad this answered your question :)
I have a do it best garage door opener,but the outside pad quit working.We put in a new battery.Got a new car and set it in the car to work,did this foul it up?
Hi Janice:
I have to ask the obvious question.
Is there any chance that the code got changed?
I'd try resetting the keypad code just in case.
Dec 08, 2015 | 2015 Ford Edge
Battery replacement
Remove back. Remove battery. Replace with new one. Replace back.
Obviously, Murphy's law states that your watch has a back which requires a key to open it! In which case you should probably take it to a watch repair shop. NOTE If the watch is rated waterproof to a certain depth AND you wear it when swimming then you need to ensure that the battery is replaced under pressure. Otherwise you'll find that you've lost that depth resistance. Have a look at. http://watchbattery.co.uk/
Aug 08, 2015 | Watches
How do I change the batteries. There doesn't seem to be away to remove he old ones. Thanks.
Look for screws, { obviously } to open the case up. Sometimes there hidden under a decal. Some of these units don't have replaceable batteries.
May 23, 2015 | Health & Beauty
Changed battery and radio wont work in1997 opel corsa. obviously I need the correct code but dont have the original manual
Remove the radio from the car then post the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on any labels , barcodes and stamped in the metal casing.
Dec 18, 2010 | Car Audio & Video
Phone is dead, battery fully charged. Need instructions on how to disassemble the phone to look for obvious problems.
From the back of the phone, remove 1 screw @ the top/center. Take the battery cover off, remove the battery. Remove 4 screws. With a medium size blade
screwdriver, gently pry the case apart at the battery charger hole. Just pry the plastic, not the connector case. Then with a very thin precision blade screwdriver, work your way around both sides of the case. Note: there is a connector that goes to the display portion of the phone. Once the case is open, gently pry the connector of the main circuit board. There will be a keyboard cover, 2 side button plastic pieces, 2 side button circuit boards, the top plastic cover, and the bottom main circuit board.
Good Luck
Russ
Jul 13, 2009 | LG VX5400 Cellular Phone
I dropped TI84 silver and now it won't work at all.
If you open the battery case and then open the lithium battery case (with a screw driver), there is a "reset" hole inside the lithium battery case area. Use a small screwdriver or something that will reach inside the reset hole and press. Good luck!
May 27, 2009 | Texas Instruments TI-84 Plus Silver...
Cant find where to change the batteries in the remote... There is no obvious place to put them unless we try to bust it open. Help!
Heya Harvey,
On the panasonic remotes the batteries are under the slide down part of your remote. Where you slide the face down to expose more buttons keep sliding it down abit more and you should find two aa batts.
If this dosent make sense or you would like me to send a link for the remote let me know.
If you have any other problems please feel free to contact me
Thankyou for using fixya
Apr 21, 2009 | Heating & Cooling
How to Remove Watch Case to Replace Battery
the anser to the question is you need a special tool to open the watch as this is a screw back and you can buy this from Watch repair dealer from about £10
Jan 31, 2009 | Bulova Watch
2008 renault scenic cd code
when the battery is changed the cd loses its code. to retreve it get the chasiss number. its located on a plate inside the drivers door. its starts with VF!. ring your renault dealer with this number and they will give you the 4 digit code and instructions on inputing it. obviously write it down in case you need it again
Sep 09, 2008 | 2000 Renault 181
Battery needs replacement
Hi alvaring
Use a med/thin guitar pick and slip it under the edge of the casings and run it around the perimeter to snap open the casing locks. This method works for all snap together devices, and I have not found a better way yet!! Good luck. A FixYa rating would be great for this bit of knowhow..
regards
Graeme
Mar 08, 2008 | Motorola Mobility H700 Wireless Headset
Logitech Cordless Mouse Logo
194 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
