Question about Dell 430-0008 Network Adapter
Display Receive error that the display adapter is not configured correctly and click ok to go to add hardware wizard. The problem is the monitor keeps blinking on and off intermitently for various lengths of time. What can I do to fix this problem?
    Novelist:
  • 183 Answers
Please update the BIOS for the computer & Choose correct Display Driver to Install.
Posted on May 12, 2009
My monitor flashes on and off while I am working.
There are lots of reasons why it can shutdown, but happerlly none should be serious. It may be that the B+ or Power supply is too high, look for a pot near the power supply and try turning it down a bit. Also the x-ray protection may be too high, look for the X-Ray pot, found near the FBT, turn that down too. I assume your a tech and know how and where to be carefull.
card settings are too high and your monitor cannot handle the settings. One way to confirm this is to boot into SAFE MODE and see if it still happpens. If it does not, then its the video card settings. If it does, then it indicates that the monitor is in need of service or replacement.Turn down the resolution and color depth settings all the way, and then increase them incrementally until it is as high as it can go until this problem starts happening again. To adjust video settings, right click anywhere on the desktop and select Properties. Then go to the settings page.If the display does not stay active long enough to make these changes, then boot into SAFE MODE and delete the video adapter from the device manager. Upon rebooting the computer, the video adapter will re-install itself with low default settings.Is the correct monitor selected in your display settings?Make sure that the correct monitor appears in Display properties. If the wrong monitor is selected, Windows might not use the full capabilities of your monitor, and you might be restricted in your choice of screen resolutions.To check your monitor selectionOpen Display Properties in Control Panel. Click the Settings tab, click Advanced, and then click the Monitor tab. The monitor that is selected for your computer is displayed under Monitor Type.If correct monitor isn't listed, click Properties. Click the Driver tab, and then click Update driver. After the Hardware Update Wizard starts, click Install from a list or specific location, and then click Next. Click Don't search. I will choose the driver to install, and then click Next. This provides a list of monitor manufacturers and models.In Manufacturers, click the manufacturer of your monitor, and then in Models, click the model name.
If your monitor isn't listed, click (Standard monitor type) in Manufacturers, and then choose the most compatible setting for your monitor in Models. Click Next, and then click Next again. NoteTo open Display Properties, click Start, click Control Panel, click Appearance and Themes, and then click Display.Are you using the wrong driver for your display adapter? ImportantThe following procedure might require you to restart your computer, which will close this troubleshooter. If possible, view this troubleshooter on another computer while you perform the steps on the computer you are troubleshooting.To continue troubleshooting if no other computer is availableRight-click the page displayed on your screen, and then click Print.
    1. Follow the steps in the printed copy of the procedure.
    2. After your computer restarts, reopen this troubleshooter and answer each question as you answered it initially.When you reach this page again, answer the question at the bottom, and then click Next.If the wrong driver is specified for your display adapter (video card), you might have problems installing your monitor or increasing the video resolution above 640 × 480 with 16 colors.To find out whether a better driver is availableOpen Display Properties in Control Panel. Click the Settings tab, click Advanced, and then click the Adapter tab. Click Properties, click the Driver tab, and then click Update Driver.Click Install the software automatically (Recommended). Follow the instructions in the Hardware Update Wizard to search for a better display adapter driver. Restart your computer if you are prompted to do so. NoteTo open Display Properties, click Start, click Control Panel, click Appearance and Themes, and then click Display.You might be able to download an updated driver from Windows Update. To go to the Window Update Web site, click Start, point to All Programs, and then click Windows Update. If an updated driver is available, follow the instructions for downloading the software to your computer and installing it. If the driver is not installed automatically, use the procedure above to locate and install the driver on your computer.
Does installing the correct driver for your display adapter solve the problem?Does Windows support your display adapter?To determine whether your display adapter (video card) is supportedCheck the Windows Hardware Compatibility List (HCL) in Help & Support.If your display adapter is supported, the HCL might include notes about it or links to updated drivers. Download any new drivers that are available. NotesIf you follow this link, when you return to this troubleshooter you will have to start over from the beginning and answer each question as you answered it initially. You must be connected to the Internet to view the HCL. If you do not have Web access, contact the manufacturer of your display adapter to find out if it is compatible with Windows XP. If your display adapter is not on the HCL, or is listed but is not shown as being compatible with Windows XP, Microsoft does not provide support or drivers for it. Contact the adapter manufacturer, or visit the manufacturer's Web site, to obtain a driver that is compatible with Windows XP.
Does Windows support your display adapter?If it is supportedDecrease the hardware acceleration setting. ImportantThe following procedure might require you to restart your computer, which will close this troubleshooter. If possible, view this troubleshooter on another computer while you perform the steps on the computer you are troubleshooting.
  • To continue troubleshooting if no other computer is available
    1. Right-click the page displayed on your screen, and then click Print.
    2. Follow the steps in the printed copy of the procedure.
    3. After your computer restarts, reopen this troubleshooter and answer each question as you answered it initially.When you reach this page again, answer the question at the bottom, and then click Next.To decrease hardware accelerationOpen Display Properties in Control Panel. Click the Settings tab, click Advanced, and then click the Troubleshooting tab. Drag the Hardware acceleration slider to the left.
  1. Click OK, and then click OK again.
  2. Restart the computer when you are prompted to do so.
Note
  • To open Display Properties, click Start, click Control Panel, click Appearance and Themes, and then click Display.
Does decreasing hardware acceleration solve the problem?
If not resolveIs the BIOS for your display adapter out of date?
The BIOS for your display adapter might not allow a resolution higher than 640 × 480 with 16 colors.
Contact the display adapter manufacturer to find out whether there is an updated video BIOS for your display adapter that supports higher resolution.Does upgrading the video BIOS solve the problem?
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 24, 2010 | Computers & Internet
OS won't start on Sony VGC-RB60G
To resolve this problem, start your computer in Safe mode, remove the display adapter, rename the .inf files that are associated with the display adapter drivers, restart your computer in Normal mode, and then update your display adapter drivers. The following steps describe this procedure in more detail:
  1. Start Windows in Safe mode. To do so:
    1. Restart the computer, and then press F8 while the computer starts.
    2. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER.
    3. Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode.
  2. In the message that states that Windows is running in Safe mode, click Yes.
  3. Click Start, click Run, type msinfo32 in the Open box, and then click OK.
  4. Under System Summary, expand Components, and then click Display.
  5. In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf.
  6. Quit the System Information utility.
  7. Click Start, right-click My Computer, and then click Properties.
  8. Click the Hardware tab, and then click Device Manager.
  9. Expand Display adapters, right-click the display adapter, and then click Uninstall.
  10. Click OK.
  11. Click Start, click Run, type cmd, and then click OK.
  12. In the Command Prompt window, type the following commands, and then press ENTER after each line: ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
    ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old
  13. Close all open windows, and then restart the computer in the typical manner.
  14. Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware.
  15. When the Found New Hardware Wizard starts, click Cancel.
    If you receive a stop error after you remove the updated display drivers, restart the computer and use the Last Known Good Configuration option. To do this, restart the computer, and then press the F8 key while the computer starts. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Last Known Good Configuration, and then press ENTER.
    If you receive a "System Has Recovered from a Serious Error" message when Windows starts, restart the computer again. This error message does not recur.
Oct 06, 2009 | Sony VAIO RB60G (VGCRB60G) PC Desktop
I have purchased a Asus en6200le card for dual monitors at work. I have also purchased the correct DVI-I to VGA adapter so i can run 2 vga monitors, but i still cannot get the second monitor to show how...
Right-click the desktop, and then click Properties.
In the DisplayProperties dialog box, click the Settings tab.
Click the Display list and select your external monitor. If you do not see multiple monitors listed, your computer hardware may not support Dualview. You can still use MaxiVista to configure a second computer as an additional display, however.
Select the Extend my Windows desktop onto this monitor option. Click Apply or OK
Jul 17, 2009 | ASUS EN6200LE/TC256/TD GeForce® 6200LE,...
Windows xp will not load
Ah, the "Blue Screen Of Death".
Solution as follows:
  10. Click OK.
  16. Obtain and install the latest drivers for your display adapter.For information about how to contact your computer manufacturer, visit the following Microsoft Web site:
Mar 11, 2009 | Lenovo 3000 N200 Notebook
Blue colour background saying it is the stop error screen.
The fix from Microsoft's website:
  10. Click OK.
  16. Obtain and install the latest drivers for your display adapter.For information about how to contact your computer manufacturer, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | Sony VAIO Digital Studio PCV-RX550 PC...
UNABLE TO REACH DESKTOP
loadTOCNode(1, 'symptoms');-------------------------------------SYMPTOMS:------------------------------------
When you restart your computer after you install Windows XP Service Pack 1 (SP1), your computer may generate the following Stop error message:
STOP: 0x00000050 (0x8872A990, 0x00000001, 0x804F35D7, 0x00000000)
PAGE_FAULT_IN_NON-PAGED_AREA
----------------------------------------CAUSE:-----------------------------------------
loadTOCNode(1, 'cause'); This problem may occur if there is a conflict between Windows XP SP1 and the display adapter drivers that are currently installed.
------------------------------------SOLUTION :---------------------------------------
loadTOCNode(1, 'resolution'); To resolve this problem, start your computer in Safe mode, remove the display adapter, rename the .inf files that are associated with the display adapter drivers, restart your computer in Normal mode, and then update your display adapter drivers. The following steps describe this procedure in more detail: 1. Start Windows in Safe mode. To do so: a. Restart the computer, and then press F8 while the computer starts. b. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER. c. Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode. 2. In the message that states that Windows is running in Safe mode, click Yes. 3. Click Start, click Run, type msinfo32 in the Open box, and then click OK. 4. Under System Summary, expand Components, and then click Display. 5. In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf. 6. Quit the System Information utility. 7. Click Start, right-click My Computer, and then click Properties. 8. Click the Hardware tab, and then click Device Manager. 9. Expand Display adapters, right-click the display adapter, and then click Uninstall. 10. Click OK. 11. Click Start, click Run, type cmd, and then click OK. 12. In the Command Prompt window, type the following commands, and then press ENTER after each line: ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old 13. Close all open windows, and then restart the computer in the typical manner. 14. Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware. 15. When the Found New Hardware Wizard starts, click Cancel.
If you receive a "System Has Recovered from a Serious Error" message when Windows starts, restart the computer again. This error message does not recur.16.Obtain and install the latest drivers for your display adapter.For information about how to contact computer hardware manufacturers, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base:
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi - (Technical Associate)
May 07, 2008 | Compaq Armada 1700 Notebook
I have 2 monitors a syncmaster 920N and 216bw.Both were working fine until I had a system restore now only one works.What do I have to do?
Configuring your displays
Connect your second monitor, and then restart your computer so that it detects the new monitor. Once you have restarted your computer, you'll need to adjust your display settings by following these steps:
1.
Click the Start menu, and then click Control Panel.
2.
Click Appearance and Themes, and then click Display.
Once you connect your second monitor, you need to adjust your display settings.
3.
In the Display Properties dialog box, click the Settings tab.
4.
Click the monitor icon labeled 2, and then select the Extend my Windows desktop onto this monitor checkbox.
Extend your Windows desktop to your second monitor.
Troubleshooting: If you do not see two monitor icons, your computer might not support multiple displays. First, make sure that you have Windows XP installed. Then, visit Microsoft Update, click Custom Install, and install any available hardware updates. You may also need to visit your computer manufacturer's Web site to install an updated display driver. If you still do not see two monitor icons, you may need to install an additional display adapter, as described earlier in this article.
5.
If necessary, drag the monitor icons so that they are arranged in the same way as the monitors on your desk. Click the Identify button to indicate which monitor is 1 and which monitor is 2.
Drag the monitor icons to match the physical arrangement of your monitors.
6.
Click Apply. Windows XP will activate your new monitor.
7.
Click OK.
A dual monitor setup enables you to view the same image side by side.
Once your monitor is set up, you can use your mouse to grab the title bar of a window and drag it to your new display. If a window does not move when you drag it, double-click the title bar first, and then drag it. Having two monitors will forever change the way you work with your computer. Be creative and experiment with the sizing of application windows and what information you can keep in constant view while doing multiple tasks.
Apr 03, 2008 | Computers & Internet
Keeps losing resolution
Try updating you're display adapter driver. Go to my computer, right click on that icon. Click on properties. Go to hardware tab, click on device manager. A window will open. Open up the display adapter tab, right click on you're display adapter and try to update driver. Then follow the wizard. That worked for me.
Dec 28, 2007 | Princeton Digital VL1918 Monitor
Monitor driver
you can set a resolution of 1440*900..
option 1) open device manager,, update the drivers for standard vga card.. locate ur video drivers folder,,(do it manually even if u have it on cd)...
option 2) this one is bit risky.... open add new hardware wizard and add ur correct video adapter, no matter ur standard display adapter is already installed. after you finish, update ur original standard display adapter and this time, it will pick the correct drivers.. now you can remove your dumb display adapter and restar pc .
risk is- be very careful, u dont want to remove your physical adapter by mistake, resulting no video after a restart.
Oct 17, 2007 | Microsoft ChiMei CMV938D 19" Widescreen...
The monitor turns off and on repeatedly.
It sounds like your video1.gif card settings are too high and your monitor cannot handle the settings. One way to confirm this is to boot into SAFE MODE and see if it still happpens. If it does not, then its the video card settings. If it does, then it indicates that the monitor is in need of service or replacement.Turn down the resolution and color depth settings all the way, and then increase them incrementally until it is as high as it can go until this problem starts happening again. To adjust video settings, right click anywhere on the desktop and select Properties. Then go to the settings page.If the display does not stay active long enough to make these changes, then boot into SAFE MODE and delete the video adapter from the device manager. Upon rebooting the computer, the video adapter will re-install itself with low default settings.Is the correct monitor selected in your display settings?Make sure that the correct monitor appears in Display properties. If the wrong monitor is selected, Windows might not use the full capabilities of your monitor, and you might be restricted in your choice of screen resolutions.To check your monitor selectionOpen Display Properties in Control Panel. Click the Settings tab, click Advanced, and then click the Monitor tab. The monitor that is selected for your computer is displayed under Monitor Type.If correct monitor isn't listed, click Properties. Click the Driver tab, and then click Update driver. After the Hardware Update Wizard starts, click Install from a list or specific location, and then click Next. Click Don't search. I will choose the driver to install, and then click Next. This provides a list of monitor manufacturers and models.In Manufacturers, click the manufacturer of your monitor, and then in Models, click the model name.
Note
Sep 21, 2006 | ViewSonic VE710b 17" Flat Panel LCD...
Dell 430-0008 Network Adapter Logo
63 people viewed this question
Alun Cox
