JVC LT-42X688 42 in. LCD HDTV Logo
Posted on May 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Menu video 1 displayed across screen how do I turn it off
Anonymous
Level 2:
Sniper:
  • Expert 105 Answers
  • Posted on May 21, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
105
Questions
0
Helped
75220
Points
508
Press the "Display" Button. It is the 3rd button up from the bottom on the right.
2answers
Music overpowers voices
Need go to menu screen display and reduce bass to 1/4 level. Do not set more then 40%
Blue and pink dots displayed on screen
Looks like the display has developed some problem. Try changing the input device to some other like a DVD player, VCR etc. If the problem persists, this might require attention by a qualified service technician.
The spynet watch turns on the but the screen is blank I can hear sounds but can not see the menu screen
When exactly you lost the display?
Just right after turning on the computer?While working in Windows? Or every time you open a program or application?
If problem happened just right after turning on the computer, we have 2 point of failures: Monitor or the VGA CARD/MOBO Onboard.
To test your monitor. While computer and monitor is ON. Unplug the VGA cord at the back or the monitor and check if you will see a box moving across the screen says monitor self test.
If no display replace monitor.
It monitor self test passed. Connect computer to a different monitor and if problem persist then update the video card driver or the motherboard chipset. If all fails then you have to replace your video card or motherboard.
Pls do consider replacing the VGA cord as well.
Hope this helps.
I have an old Sharp Model # 27A-S100 I have a Black Line running across the bottom of my screen from left to right 22 1/2" length and 3 1/4" in height
If this line does not go all the way across the screen then I will bet you this is an easy fix. Press the menu button on the remote control. The menu will hopefully show up over-top the black. Search your menu for the closed caption setting (usually under audio settings menu) and turn closed caption OFF. Hopefully this fixes your issue. Cheers.
The screen has a box that says : 1:Analog input Self Test Feature Check Red (line across) Green (line across) Blue (line across) White (line across) if you push the menu botton you get a other screen...
The issue is that the monitor in not getting the signal. This tells me that the video adapter ( or on board video) has went bad. Try another video card if all your doing is social media and surfing you can pick one up for around 20.00
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
How do i change the screen resolution from 480p
go do display settings, custom settings and push right on the d pad to go across to the displays allowed menu, from here you can change them
Pioneer dvd player will turn on but will not function - Pioneer name displays on menu screen but that is all
Will turn on but displays no signal across a blue screen. I did have it working but only in black and white for some reason. I need an owners manuel as well. thanks
Dozens of horizontal lines across display!! HELP!!!
Bring up the menu and if the lines are not on the menu replace the small signal board that is your video prossor. If the lines are still the replace the Y main board that contrl the top half of the screen.
Number display always on
if you can access the menu on your remote or the front of the set you can turn this function off. somewhere in the menu will be something called OSD( on screen display) and you can turn it off. sometimes the menu can be accessed by pushing the channel up and down buttons on the front of the set at the same time.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
