Question about Little Giant 5-ASP, 1/6 HP, 1200 GPH - Submersible Utility Pump w/ Piggybac
Pump turns on and off every couple of minute, need pump to run non-stop
I have a little giant utility/sump pump that I use for my water fountain in my front yard. I had it running last year without any problems. This year I set it up but it only starts up for a couple of minutes and then turns off for a couple of minute, then it turns on again, then off and repeats. Please Help.
  • jdthefixer May 11, 2010
    Check to make sure the "suction" of the pump is always flooded with water. Maybe the inlet is clogged. The motor may be protecting itself from burnout if there is a low water condition. Does it also have a float switch? If so, maybe the float is bobbing up and down too much from turbulence.
  • 332 Answers
Contacts are bad if you can fis it you will have to go to either a granger store or ele motor store to get them,, make sure they are in in the right direction or it might be easier to change the pump to a new one
Posted on Jun 23, 2009
  • gary miller
    gary miller Jun 23, 2009
    contacts are bad if you can fis it you will have to go to either a granger store or ele motor store to get them,, make sure they are in in the right direction or it might be easier to change the pump to a new one
  • gary miller
    gary miller Jun 29, 2009
    it appears you need a new float switch or a new pump wich would be cheaper then replacing the switch, and a warranty with a new pump
My pump is running but not sucking up water
well if possible look into suction screen and see if Impeler is turning , I'll bet not , most of the lil giants come with a easy to remove pump cover (screw) so one can access the pump cavity to remove forign debris , also one can manually rotate impeller with finger (unplugged) to ck for free movement , if its hard to move your pump needs replacement
May 10, 2014 | Little Giant Submersible Fountain Pump
I am looking for an agent for a Franklin submersible sump pump for a borehole in Centurion.
If you visit their water site along the top you will see 'service' and 'sales'. Depending on what you need select one and follow the screen prompts for a local agent. Their site can be found at:
http://www.franklin-electric.com/americas-water-systems.aspx
John
Apr 26, 2011 | Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP...
My little giant just stopped working, impeller turns ok by hand, no blockage, 110v to outlet ok. Always under water, never ran dry... Walter
inside the pump on the motor is a thermal cut out if the motor has over heater from running a long time the cut out pops and it may not pop back in again? its that or there is a motor fault like brushes worn out
Aug 28, 2010 | Little Giant 5-MSP Water Wizard...
Little Giant Pump - dialectic oil to use
ck your local yellow pages for an electric motor repair shop they should be able to get silicone oil to add , but in a pinch ive used full synthhic auto transmission oil that works too
Jul 29, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Sump pump
The big cylindrical thing at the end of the wire hanging is the switch. I believe it is a mercury switch. Try hitting this a little and see if it stops. Sometimes they get stuck. If this doesn't help, then replace that piece. Hope this helps.
Jul 06, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Little Giant stopped working; makes hum noise but wont push wate
Can you take it out of where it is and clean it with vinegar? There may be calcium built up in it. I have one also on my aquarium and when I turn it off sometimes it won't start back up, just humms.. That tells me it's time to clean it.
Jun 07, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Little giant pump stopped working
Hi Tom (and Lindsay?),
Ok lets get a little more info,
  1. Plugged in? (Have to ask)
  2. Does it run and not pump?
  3. Does not run?
  4. Tried moving the float switch?
  5. Pull the pump and see if the intakes are clogged
Please comment back with your findings
Mike
Apr 18, 2009 | Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP...
24HR working pump question
Utility Pumps: Utility pumps draw water through openings that screen out debris. When placing one into a pond, use a pump sock or other enclosure to reduce the amount of cleaning needed. If you use a pump sock, be aware that sock-like screening can cause a dry pump situation. Solids Pumps: These pumps draw water through a large opening and pump small debris through without clogging. For this reason, they can be placed into a pond without prefilters. Note, however, that this type is not safe for ponds with fish, frogs or other aquatic animals
Aug 27, 2008 | Little Giant Submersible Sump Pump, 1/4 Hp
Little Giant 5-ASP, 1/6 HP, 1200 GPH - Submersible Utility Pump w/ Piggybac Logo
136 people viewed this question
Top Little Giant Electrical Supplies Experts
 Kenneth
Kenneth
Mike
ken skalski
Are you a Little Giant Electrical Supply Expert? Answer questions, earn points and help others
