Question about Mitsubishi WS-65809 65" Rear Projection Television
Is mitsu ws-65809 upgradeable to hd? - Mitsubishi WS-65809 65" Rear Projection Television
    Champion:
  • 453 Answers
U have a problem with the digital board ( dm3 board ) may u have bad capacitor on dm board 1000Uf at 25V
Posted on May 12, 2009
My tv always says it is on 480p.
The model indicated here has only one HD input---the DTV input.
May 05, 2012 | Mitsubishi WS-65809 65" Rear Projection...
1998 73" Mitsu diamond the RBG/HV Im trying to
I'm not sure that the set can handle the speed, but make sure that the sync pulse is on the green when you make the connection. Also, you must use the component input not the composite. IF hte picture ends up being purple, you will need ot change the set from YPrPb to RBG as well.
Good luck,
Dan
Apr 05, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have slightly double images on screen on my Mitsu. WS 65809
just go to convergence adjusment , and try to todo that , some times this tv u need todo little tunup
Aug 26, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Mitsu 65" progection timer light on continuos tv won't turn on
u have a bad dmd board , need to contac a tv repair shop for this jod
Apr 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Mits WS-65857 no HD after repair
WELL YOUR LIQUID SPILL MAY HAVE BURNT FOIL PATHS OR EATEN UP SOME OTHER SOLDER JOINTS. A CLOSER INSPECTION ON THE AREA INVOLVED SHOULD SOLVE YOUR PROBLEMS.
Dec 27, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Picture with signal applied is purple and distorted/choppy
The board you seek is the doubler (2HDW) module.. a lot of time reseating the board will solve the issue. If HD still works, this board is likely you problem. This board upconverts all non HD signals to hd to put onto the screen. IF HD doesn't work, you more likely need a signal board. This board has all the settings on it and is much more difficult to replace.
Dec 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
VERTICAL BLUE LINES ON MY MITSU WS-65809
Its either the Blue CRT or the Blue CRT drive Board which is causing the lines, More probalble would be the Resistors on the CRT board. I would recomend unsoldering one side of each resistor on the Blue CRT drive and lifting that end up out of circuit and checking, one may be open which would cause that symptom
Nov 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
