Question about Toshiba Satellite Pro L300D-EZ1001V Notebook
Keyboard is not set to the default setting
My computer was rebooted, the settings for the keyboard is not correct. it is set to canadain french, how do i reset it to the standard settings( so i can use my question mark)(É)
  • rainey_45 May 21, 2009
    Hello..I also have same problem as gimpy75ws ^( é ) with my keyboard.I have an Hp compaq flatscreen desktop---thanks for any help & advise....L:)
  • Jorge Hernandez
    Jorge Hernandez May 11, 2010
    Do you mean the typing mode?
Help with setting up Kindle Oasis received as gift.
Just tell it to:
Hit the small microphone and say: change tabblet setting to English language please. Let me know
Dec 22, 2016 | Tablets & eReaders
Get rid of the french sign and use the question mark and slash sign instead.
Check your regional setting in your control panel. Under default Language Check your Keyboard and make sure US is set as default.
Sep 24, 2014 | Dell Inspiron Computers & Internet
Asus laptop keyboard not tying correct characters?
check your language settings for the keyboard. For example if you use a setting for Canada, the keyboard will often default to French Canadian, and will have different settings than US English. Without more information about the issue you are having it is kind of hard to know how to help.
Apr 21, 2014 | Uniden GPS
I cannot access the @ sign on my french keyboard
Have you set the keyboard to the correct language within your operating systems regional and language options in the control panel as sometimes the keys are transposed e.g. shift+2 can produce the @ sign if the language is set to the default American keyboard layout.
Oct 08, 2010 | Computers & Internet
Logitch quickcam works on yahoo IM. Can't get microphone to work on Skype
Check webcam mic is set as default
Vista - If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to Skype
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Jun 10, 2010 | Computers & Internet
I cannot get a question mark, the upper case E with a grave (green) on keyboard appears
When you get that it usually means the language setting for the keyboard has changed.
The standard key markings are valid for most english language settings. US is the default. To change this go to start - settings - control panel. Then look for Regional and language settings. Click on that and then in the window that open there are three tabs along the top. The middle one should say language, click on that one. In the Text Languages and input options area click on the Detail button. A new window opens. At the top it shows your language. And in the box under it will show your lnaguage and installed keyboard layout. So if I were using Canadian English and the US keyboard then the keys will function as marked. To change the keyboard language click the add button, then select your language and then the keyboard layout. When you click ok it goes back to the previous window but now will show the original setup and the new one you just made. Just remove the original and apply and close everything and your keyboard will now produce the correct characters.
Apr 23, 2010 | Acer NSK8458AN Keyboard
Hi ihave an acer aspire 5600 .My webcam works with other aplications but not on skype and msn.Could you please help me?
Before you can use your webcam in any chat program you have to configure it to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
WINDOWS LIVE MESSENGER ( MSN)
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Feb 09, 2010 | Logitech Quickcam Chat Webcam
I installed Skype and my webcam has audio but no video
Hello...
All you need is to install the driver on windows.
Once installed correctly on windows, now you can configure it in skpye.
Tips to configure it in skype:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Start Skype.
Click 'Save'
Click Save
ok
try this...
Jan 22, 2010 | Logitech Webcam
I cannot turn off the frech keyboard keys
please check language settings in control panel as there may be some default option set...
Nov 09, 2009 | Toshiba Satelite A135-S2286 Notebook
How to change the language setting to English?
Computers running Windows®, you have the option of typing alternative character sets. This can be selected by clicking on START>SETTINGS> CONTROL PANEL. Then click on the picture of the world globe. This enables users to toggle between Arabic or Hebrew and English. This requires you to learn the keyboard layout for these languages
First, select the desired language.(the default in the U.S. is U.S. English If your computer was sold in a French spealing country, the keyboard might be different. If this is the case, the only solution could be a new keyboard
Oct 06, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Toshiba Satellite Pro L300D-EZ1001V Notebook Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
