Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Cd crashes After the cd plays, the arm picks it up and slams the cd into the carasel. Its supposed to pick up the cd, come up, pivot, then set the cd back in it's place.What could cause this? Thanks for any help!!! Tony
    Champion:
  • Wurlitzer Expert
  • 211 Answers
The arm is sprung. It is catching on something so the motor is driving , tightening the spring, then it lets go and slams the arm over.
Posted on Jan 09, 2011
CD player plays some CD but some of the others it spins them and tosses them off the cone
The center cone on the hub could be a problem if the player was not for the right juke. Each brand has their own style. (If you still have the old player, check and make sure the the hubs are the same.) The center cone on the hubs are glued in place so if they are different you might be able to pop the old one off and replace it to the new player. One other problem could also be the magnetic pressure disk that is supposed to hold the disk on the hub. Is it centered in the hold down arm or does it rub the sides? Does the disk wobble as it spins? The magnetic disk is supposed to hold it down on the hub to prevent it from wobbling and coming off the turntable.
Oct 20, 2014 | Wurlitzer Jukebox 1015 One More Time...
Sony CDP -CX200 Arm comes forward to pick up cd but goes back empty. It will not load the disc to play.
Is the second part of the arm clamping the cd? If not then the arm is probably broken and needs to be replaced.
Dec 28, 2012 | Sony CDP-CX70ES CD Player
How to remove the wiper arm from the shaft so I can remove the cslotted cowl to replace the wiper bushings.
REMOVAL & INSTALLATION
(see Figures 1 and 2)
To remove the arm from the pivot, lift the arm to permit the latch to be pulled out to the holding position and remove the arm from the pivot with a rocking motion.
Fig. 1: Mount the wiper blade/arm as shown-Dakota models
Fig. 2: Mount the wiper blade/arm as shown-1994-96 Pick-ups
When installing the arms, the at-rest position of the blades should be determined before pushing the arm onto the pivot. For Dakota trucks, the tip of the driver's side blade should be 0.51-2.63 in. (13-67mm) above the cowl panel and the passenger's side blade should be 0.94-3.06 in. (24-78mm) above the cowl panel. For 1989-93 Pick-ups and Ramchargers, the driver's side blade should be 1.84 in. (47mm) above the windshield weatherstripping at the heel of the blade; the passenger's side blade should be 2.24 in. (57mm) above the weatherstripping. For 1994-96 Pick-ups, the wiper motor must be in the PARK position and the wiper blade should be about 0.85 in. (22mm) from the upper edge of the black-out areas at the base of the windshield.
Hope this helps to solve it.
Nov 26, 2010 | 1992 Dodge Ram 250
Dodge pick up wiper repair
Check wiper arm where it fits to the shaft the nut may have come loose! if so reset the arm to its normal resting place & retighten!
if its ok then its more likely that it has come off its pivot under the csuttle panel
it may need a new pivot
Jul 20, 2009 | 1986 Dodge Pickup 4WD
Playing to the end of the record
I LOVED the 40bs, and if you look at the size selector, which is located at an angle to the right side at the front along with the manual or auto setting in the front. There are 4 settings, 78-10, 45-7, 33-12, and 33-7 for the speeds and sizes of the recordings.
Apr 14, 2009 | Teac AG-V1050 Receiver
Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
Cd not playing
If you look at the far side of the gripper arm towards the back of the machine, at the base, you will see a white bracket like a duck's bill. This has come loose or broken. You can prove this is the problem by pressing down on it and clicking the microswitch as the gripper reaches back over the carousel.
Jun 29, 2008 | Wurlitzer Jukebox 1015 One More Time...
Problem playing 45 Records to their entirety.
There is an adjustment on the tone arm that you use to set where the tone arm picks up at the end of the record. This adjustment is normaly at the back (pivot point) of the tone arm and will be on the side probably. By the way, the tone arm is the part that the stylus is mounted to that swings back and forth to reach all the surface of the record. Make your adjustment and then test and continue doing this until you get it just where you want it. It is a process of trial and error. Good luck.
May 20, 2007 | Emerson NR303TT CD Shelf System
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
60 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
