Question about Motorola Mobility L6 Cellular Phone
L6 won't charge
I just got my phone and it won't charge. I have taken out the Sim card and even switched the battery with my husband's phone that is just like it.
  • 1 more comment
  • truthseeker Nov 11, 2007
    i can't charge my phone. I've tried to recharge the battery but nothing happens but before that, a message with a black background "boot loader... low battery cannot program" prompted so I thought it needs a recharge but it just went off and I'm not able to switch on my mobile phone again.
    What could be the possibe solutions for this? or what's the problem
  • Anonymous Dec 02, 2007
    Have the same problem, When I put the phone on the charger the back of the phone gets really hott.
  • khandhie Aug 28, 2008
    my l6 is not charging..ive tried it several times to charge it on usb and in my charger but nothing happens...what is the problem on this phone??can anybody help me??
My L6 went through the wash, and now it won't charge.
If I charge the battery in my Krzr, and pop it back in the L6, it work fine. Something has blown inside the L6, preventing power from getting from the mini-usb port to the phone/battery.
Pitty, the phone works perfectly otherwise, and is only 2 months old :(
Power adapter/usb cord/etc are all fine.
Posted on Feb 22, 2008
  • 490 Answers
If u r not able charge u r battery , than change the charger , contact motorola care center.my be u r not getting power supply in mobile
Posted on Oct 16, 2007
SOURCE:
My battery completely ran out and when I charged it & turned it on, it said sim sard locked enter PUK code. The phone acct., is under my husband who I am separated from, so he won,t help & at&t...
Hi,Thanks for posting you Question.You don't need to buy a new Sim card,
To get the Puk code to unlock your phone,you will have to contact service provider which is specific for each mobile number.
Puk code does not affect the phone your using,but it affects the Sim card and it unable you to make out going calls. And you will not have access to thing on your Sim card.
To get your Puk code for you Sim card,you can contact service provider located in your area for help.
You can go to any of your service provider outlet stores around your area.Or you can contact them through customer care line..Am sure you know their phone number to contact them.
You can not get a Puk code to unlock your phone from another source except through your service provider service..
Take care
Sep 19, 2011 | Apple iPhone 3G
My nokia 6300 phone won't turn on
it is not a issue with battery or sim card. It can be issue with display or software. Go to nokia showroom and check with them once.
May 10, 2010 | Nokia 6700 Classic Cell Phone
Hi, I just purchased my phone last November and the sim card is already bad, so it says. When I power up the phone now it says insert sim card. I have never removed it before and am not abusive with the...
you might try switching the sim cards between the phones, see if that helps at all. you can also do a hard reset, remove the battery, then press the reset button for about 5 sec. turn it back on and see if that is the problem. they should not be charging you for replacement sim cards that have gone bad. insurance covers the phone, the card belongs to sprint and if bad, they replace it.
Feb 03, 2010 | Motorola Mobility Clutch i465 Cell Phone
My name is samuel adjei boadi from ghana. the fault of my phone is that the z310i happens to be a new phone.whenever i charge the phone with a charger, the phone stops charging or switches off.when you...
there was a connector problems with your sim card and the battery connectors please try to stretch it to up and try again.........if you dint get what i said call me on my mobile +91 9704788855
Dec 05, 2009 | Sony Ericsson Z310i Cellular Phone
Unblock sim card on Motorola L6
the pin 1 number will be with ur sim network provider note down the number behind the sim card and ask your customer care
they will give you
May 27, 2009 | Motorola Mobility L6 Cellular Phone
Phone sporadiacally displays "insert sim card" even though it has a sim card inside (never been taken out). Switching off the phone and switching it on again was what i did. However recently my...
it could be that the contacts between the phone and the sim card are dirty and therefore you will get the error code. take the battery out and remove the sim card take a q-tip with some rubbing alchohol and clean the contact on sim card and the phone itself make sure not to use alot of alchohol. let them air dry then re-insert the sim and battery this should do the trick. the error warning should go away and the phone will be abale to receive the contact info from gthe sim card.. please rate this
Sep 20, 2008 | Cell Phones
My N70 Won't Turn On At All
petrosp your n70 needs to be flashed with new firmware. In the worst case some hardware got damaged
Aug 11, 2008 | Nokia N70 Cellular Phone
Motorola l6
hai friend it is a simple problem to solve
just do unlock u r phone with help of unlock saftwere......
Dec 02, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
539 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
