Question about Frigidaire FAS296R2A Air Conditioner
Fan speed wont adjust
I have an fas296n2a2 room air conditioner and my variable speed doesnt work, and ideas. it blows out but only at slow speed. thanks in advance
  • 374 Answers
Hi there!
if you can't adjust your blowing fan,replace the selector switch
of your ac,open control panel,pull out knob and loosen set screw
and disconnect line terminal have marked a color coding of lines,besure unplug the power of ac in doing this.you can buy this switch on ref/ac supply center,brough this switch you disconnect in buying as sample.then connect the device.have a nice day.
Posted on May 12, 2009
When I press the button to change the speed of the fan it does nothing, and continues to blow at one speed and it is just about equivalent to the speed of the slow option...any ideas why? Also it will run...
Is it new? There may something wrong with the electronic circuit board not allowing other fan speeds. Try unplugging it for a while and try again. There is a temp sensing bulb somewhere on unit most likely on front where hot/warm air from space enters unit. Make sure you are not recycling cold conditioned air back onto sensing bulb.
Jul 20, 2013 | Heating & Cooling
How to replace coolant in air conditioner...
fan motor is bad stuck or relay or capictor if fan dont pull air thru condensor it does not turn to liquid and then wont evaporate or cool in evaporator
Aug 28, 2012 | Friedrich QuietMaster SM24L30...
Air conditioner not working
have you tried turning off and on power from the plug ?
Aug 17, 2009 | Haier HWR08XC7 Air Conditioner
LG 10,000 btu air conditioner
I just bought the LG 10000 btu window model... I am having the same exact problem.. it feels like the air is not even on.. I am having someone look at it on Mon. I have a feeling the whole unit is defective. But it could be the thermostat needs to be replaced. Sucks 300 dollar brand new AC and it doesnt work!! Good luck. I will never buy LG again.
May 24, 2009 | LG Electronic Window Air Conditioner
My cooler is blowing very slow can hardly feel the air
it could be any of three things.
1. its a variable speed motor and will not blow hard unless you have an extreme cooling need (5 degrees or more away from set point)
2. You have collapsed duct work.
3. Dirty evaporator coil, or filters preventing proper air flow
May 06, 2009 | Heating & Cooling
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Frigidaire FAS296R2A Air Conditioner Logo
244 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
