Question about Refrigerators
GE model bsy25gfmd ww has power,lights and ice make have power and fan runs, however compressor will not "kick on"
  • 62 Answers
You can try changing your relay/overload, it is on the side of the compressor. If that does'nt work you probable need a new compressor.
Posted on May 12, 2009
Ge Side by Side Refrigerator model GSS22JFMC ww Is not cooling not frezzing properly and not making ice. The motor is still running ok
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
rggasd
Jul 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS201EPH WW Refrigerator does not run.
These symptoms indicate that the main control board is bad . The compressor relay ( one of the black boxes ) is bad . Have to replace the complete board . Without the model number , can't give you the part number . Take the model number with you when you go to get the part ( or order the part ).
Sep 08, 2009 | GE GSS20IEP Side by Side Refrigerator
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
GE refrig Model # GSS25WGMD WW freezer is cool, compressor is running, but food is thawing out, ice has melted...not sure if I left door open ovenight, should I call repair..show long does it take to...
I pulled the refrig out from the wall, turned it off, took off the back panel (that covers the compressor fan and motor) and used the attachment on my vacuum to remove the dust from the area. Then I closed the flapper that allows the ice to release from the ice maker compartment to the dispenser, so no warm air would get into the freezer area. I plugged the refrigerator back in and within an hour it was freezing again! So far this week, I have had to repair the garbage disposal and the refrigerator.....I saved some nice $$$ by figuring this out by myself!
Jun 25, 2009 | GE Refrigerators
Freezer not freezing, refrigerator side not cold enough
sounds like compressor might not be running. pull unit out and remove bottom panel to access compressor area. beware of electrical wiring!!!! touch compressor to see if it warm. make sure fan motor by compressor is running.
May 07, 2017 | GE Refrigerators
Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Jan 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Refrigerators Logo
237 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
