Question about Whirlwind FH-778 Air Conditioner
My home A/C is not blowing cold air...Is this acostly repair?
Have you replaced your filter lately? If not a dirty filter will cause your unit to not cool properly. Is the outdoor unit operating? If not then check your breaker. If it is but it's still not cooling then it could be low on refrigerant.
Posted on May 12, 2009
  • 62 Answers
It depends on what you think is costly. It could be anything from a capacitor to needing more refrigerant to your overload/relay on the compressor to needing a new compressor. These possobilities are writting in order off less expensive to more. It would be wise to rule out the things you can check yourself and then have a professional come and check it out.
Home A/C is not blowing Cool air ice on hose
Not blowing at all or not blowing cold? Big difference.
Aug 31, 2013 | Goodman Heating & Cooling
No Cold Air Blowing out of vents Air conditioner just blows out warm/hot air only what would cause this it just happened very quickly went to to store Approx. 14 miles away from home went to leave to get...
There are a few possibilities. Blown fuse to the compressor clutch, bad clutch, seized compressor, broken belt, low system pressure, or a rock through the coils in front of the radiator causing a leak. Take it to a reputable mechanic for repairs.
Jun 27, 2010 | 1998 Ford Escort
My a/c is not blowing cold air and heater is not
I know this problem well, it is caused by a failed air temperature control blend door actuator motor or a stuck bleed door in the heating and ac duct, to replace this part requires you remove the dash assembly, there is no other access provided, this not for the home mechanic, it is very time consuming nd requires a good knowledge of repair work to complete the job, a factory repair manual is a must, not Haynes or Chilton, they will not do the job, not detailed enough.
Oct 22, 2009 | 2000 Chevrolet Blazer
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
Heat blows out driver vent when ac on
this problem is caused by a defective air temperature control blend door actuator motor, it is about center of dadsh in air ducting, it moves the door that diverts air for cold from ac or hot from heater, you must remove the dash to repace it, about a 15 hour job fotr a home mechanic with a factory repair manual, nearly imposs without one.
Sep 04, 2009 | Lincoln LS Cars & Trucks
Air conditioner doesn't blow cold air. Continues
If the a/c fails to continue to blow cold there could be a few problems you can look for. First once you activate the system check to see if the compressor kicks in. You will hear the compressor humming . Once the a/c quits cooling go and see if the compressor is still running. If its not running its probibly gone into thermal overload (compressor overheated). If that is the case then you need to check to see if the coils are icing up if they are icing up then the problem is with 1) air flow restriction filter dirty, coils dirty simple repairs there replace filter, clean evaporator coil with a coil cleaner that can be purchased at a home repair store cleaning the condensor coil the same. 2) system is low on freon in which case the system will need to be recharged. Also, If you have a digital thermostat replace the batteries that may also be of some help. Good Luck on repairs
Dave
Aug 31, 2009 | Heating & Cooling
Air conditoner quit blowing cold air while driving home
you can try recharging the system...it's a fairly simple process and freon can be purchased at any parts store. here is an overview:
http://www.aa1car.com/library/ac_recharging.htm
Jun 24, 2009 | 2004 Ford F150
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Heating & Cooling Logo
804 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
