Question about Dometic RM2852 Refrigerator
Will light on propanr,but if blows out,will not
Will light on propane,but if blows out,will not relite,but gas valve seems to stay open,causing motorhome to fill with propane,the check light then comes on and stays on...someone suggested thermo couple,but i thought propane should still turn off .
  • Dometic Master
  • 4,654 Answers
Here is a link to parts service and PDF of this model. If yours is a propane model then you may need to contact the numbers on the PDF If you need to download Adobe go to adobe.com and dowload the free adobe 10
http://www.gas-refrigerators.com/pdf/RM2852-parts.pdf
Posted on May 14, 2009
  • John Tripp
    John Tripp May 16, 2009
    Doug, Were you able to find answers on the propane powered refrigerator. Sounds like something dangerous happening there if the gas valve remains open and there is no flame. Let me know and I will contact the makes of your Domestic Refrigerator.
Pilot will not light, seems to not be getting any propane to it. The regulator on my propane tank works fine. What could be the cause?
I would trace gas line out and determine were you are getting gas and where it is not. With the gas on I would carefully loosen union or flex fitting going to gas valve.If you have gas there then retighten union and go to fitting on pilot line and check it.You should be able to get gas there by depressing pilot light button.If you have gas there then go to pilot assembly and remove it from gas valve and burner. Remove pilot orifice and carefully clean and blow thru pilot line to make sure it is not obstructed.
If you cannot get any gas thru gas valve then shut off gas before valve and remove inlet line. There should be a fine mesh steel screen there. Make sure it is clean.If you are getting gas to gas valve but not thru it then you probably need to replace gas valve. Thank you
May 17, 2011 | Procom ML060HPA Heater
A friend gave me one kitchenaid dryer , i don't understand. canI use eletric power and propane, or only propane. I don't have the propane pipes conections, can you please help me understand it?
Your propane dryer only dries with propanr. The electrical cord is for the motor that turns the dryer and for the controls. If you don't have gas piped into your house then your gas dryer is useless. Either get an electric dryer or pipe gas into the house. If you have Natural gas in your home, then you need to get a conversion kit to make your dryer run on Natural gas.
Jun 17, 2010 | KitchenAid KHEV01RSS Dryer
I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
Oct 24, 2009 | Desa International CCL3924PTA 24" LP Gas...
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
On demand water heater won't stay lit
It's the gas valve. This pretty common. The thermocouple produces a small amount of current from the heat and this current holds the safety valve open inside the gas valve. Sometimes the safety valve gets sticky and your symptoms describe it exactly. People are always frustrated by the time it is certain to be the valve. You need to replace the valve. No one is allowed to fix a gas valve - liability - gas etc. Replace the gas valve and your problem will be solved. I am a master plumber/gasfitter and I am confident that this will solve the problem. Been there - done that.
Jun 16, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Furnace runs about 1 minute, then total shutdown
that sensor as you call it is a thermacouple it produces a small current which lets the gas valve know it is ok to open . if the pilot is not clean and correct it will not let main valve open. if your pilot is good then you have bad gas valve. you may have low gas pressure this can also do what you are describing
Apr 05, 2009 | Coleman Propane Forced Air Heater...
Wall mount propane heater ignites, but won't stay lit
I have a Reddyheat IWH16NLTD with this problem. When the heater fan turns on it blows the pilot light slightly up and away from the thermocouple causing the safety valve to close after the ceramic cools down. The manual says that low gas line pressure can cause the flame to rise too far from the thermocouple causing this problem, so either it is a problem with gas pressure, or it is an assembly plant problem.
Jan 10, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Timing off?
it sounds like you are not getting gas out the of the pilot assembly.If you take the 1/4 gas line off of the gas valve and try to blow through it. If you can't then the orifice is plugged. If you can blow throw it then i would say that the gas valve is bad.do you have propane or natural gas. If propane then i would say pilot orifice is plugged.
Apr 04, 2008 | Goodman GMS80904BNA Open Flame Mid-Size...
Dometic RM2852 Refrigerator Logo
195 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
