Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
Pink and green lines running through my hitachi tv?
I have a hitachi TV that has pink and green lines all in the right corner, so its all distorted and has almost a 3-d effect to it. Its only in the right corner though. The rest of the TV's picture is great. What could the problem be? And is it an easy repair that I could do myself? Also, about how much would it cost? Thanks!
I have a hitachi projection tv and im getting blue lines behind the lettering and on different spots of the screen can anyone help
Posted on Aug 17, 2009
Separated picture, one bright pink, the other bright lime green. The top and bottom of picture is distorted. The center of the picture is the best in all respects.
Please replace convergence output chips in tv to solve this issue, tv has two big black ICs at right side and number is STK392-110, replace both ICs to fix picture problem
Thanks.
Jan 25, 2011 | Hitachi 65SWX20B 65" Rear Projection...
There is a green bowing line in the upper right hand corner of my TV
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2010 | Hitachi 46F500 46" Rear Projection...
Has pink/green horizontal line across top l corner
Hi,if your tv is dlp or lcd you will need to replace the light engine that's in charge of creating the image and colors, and when bad you 'll get discoloration or lines across image.
Oct 01, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Coulor distortion at the top left of the screen
Hello jordan ashe,
This is an indication that the green CRT is having a convergence problem. This might be caused by the convergence amplifier or by the CRT. Does the rest of the picture look OK? and in addition can you supply a picture of your TV so as I can see what you are seeing and develop a proper diagnosis?
Thank you,
Shuttle83
Sep 28, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi HDTV Model 46F500
You have two bad convergence integrated circuits and possibly an open resistor or two in the supply.
Mar 04, 2008 | Hitachi 53SDX01B 53" Rear Projection...
replace convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Hitachi 46F500 46" Rear Projection...
PT-65wx51e 65in
suddenly breaks pink & green colors in bottom left & top right corners with distortion in picture
Dec 09, 2007 | Panasonic PT-65WX51 65" Rear Projection...
PINK/GREEN SHADOWS, LINES
Here is what I was able to find out about your problem from sony: This issue is usually caused by some type of nearby magnetic interference, such as unshielded stereo speakers placed too close to the TV. These spots can be small or large and will normally be red, green or blue, but sometimes appear purple or pink. They normally occur on the sides or corners of the screen, but can also appear in the middle. To resolve this issue, move any stereo speakers or other electronic devices away from the TV; a minimum of 2-3 feet is recommended. If the situation is not remedied immediately, unplug the power cord of the TV from the electrical outlet for 20-30 minutes; repeat this process one more time if the issue is not resolved the first time. If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer in your area. Hope this is helpful:)
Sep 04, 2007 | Sony KP-57HW40 57" Rear Projection...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
574 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
