Question about Epson Stylus Pro 9600 InkJet Printer
Epson stylus CX3800 series
I just recently had to restore my computer with the original recovery disk for windows 98, I know it is old, but anyway when I origianlly installed the new printer I had no problems.  I did everything right:
1- restored the printer as the default printer
2- reloaded with the cd followed instructions carefully
3- And it always say at the end can not find drive or printer is not plugged in
PLEASE HELP
Thank You
  • Anonymous Jun 09, 2008
    I have problem finding the model number CX Stylus CX 3800 Series to connect the printer to the computer. Please help.
I can not setup my epson stylus cx3800 because i lose my disc
Posted on Nov 02, 2008
  • Epson Master
  • 691 Answers
First thing I would recommend is download the driver from Epson so you know you have the latest version for your operating system. Second thing is to make sure you have the Windows 98 service pack installed that has USB support. The first version of Win 98 had NO USB support (if my failing memory serves me right)
Install the service pack and reboot a couple of times making sure you have removed any previous installations of your printer and it's associated files. Leave the printer off and no USB cable attached to the PC
Start the installation of the Epson driver with the printer OFF and no USB cable connected. When you get to the point that the install wizard tells you to ensure your printer is connected and powered on - connect the USB and switch on the printer.
If it still can't find the machine, complete the driver install with the option that you can specify the port at a later time. When done, right click the printer from the control panel/printers area and select Properties. Under Ports select USB01 or similar and apply the setting. Now under the General tab, try and print a test page. It may fail to do so. If it fails, reboot and try again.
This should see you on your way.
Posted on Oct 14, 2007
376 Aol Files. I do not know what I can safely remove.What files are unneeded ?
First try CCLEANER freeware at : http://www.filehippo.com/download_ccleaner/ Install, run, this will clean the junk from your system, uninstall all unwanted programs. Open Windows Disk Cleanup,Open More Options tab, Systen Restore and Shadow Copies, delete all but recent restore.
Dec 23, 2012 | E-Machines eMachines Desktop PC
Mi notebook acer aspire 3000LCi the only do is a an upper and i dont have a recovery disk
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
If you do NOT have a copy of this disc, skip to step 3 for further instructions.
Once you restart your computer, a screen will appear with the words.
Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings.
Follow the on-screen prompts to finish the installation.
Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again.
Restart your computer to complete the restore.
3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk.
Unplug all external devices and restart your computer.
When the loading screen comes on with the Windows logo, press Alt+F10 together five times.
This will bring up the system restore menu.
Follow the on-screen prompts to restore your computer back to the factory settings
hope this helps
Oct 17, 2012 | Acer Aspire 5610-4648 Notebook
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
How do i reboot my laptop fujitsu siemans alimo pro without disks? does this restore all hardwear & softwear?
First a rebot is just shuting down all running programs the starting them back up, Reboot is the same as Restart. You perform this by clicking Start then Restart. The second part of your question about Restoring is called System Restore And that is done differently depending on your Operating System. In Windows 7 just click Start then type System Restore then hit enter and System Restore will start and you can follow the steps from there.
In Windows XP click Start then click Run then in the Run Box type msconfig and hit Enter yoir System Configuration Utility should then popup and you just click on LAUNCH SYSTEM RESTORE near the bottom of the window. You should then be able to follow the directions.
System Recovery is sometime another option, Which you may or may not be able to do.You can perform a System Recovery on many computers. This will return your hard drive to the ORIGINAL factory configuration, with everything it originally had. First, find out if your computer supports this option
NOTE: SKIP THIS STEP IF YOU CANNOT LOAD WINDOWS.
Go to My Computer, and look under Hard Disk Drives. A lot of PC's today will include two hard disk partitions. There is always a C:\ drive (normally the Windows drive) and often a D:\ drive. The D:\ drive may be called "Recovery" or something like it.
If there is no D:\ drive, you may have to do System Recovery from a disk. Contact your PC manufacturer to order the disks. It's easier than buying a new PC.
WARNING! SYSTEM RECOVERY DELETES ALL FILES YOU HAVE CREATED AND PROGRAMS YOU HAVE INSTALLED. It restores the hard drive to its original state, This means that all files you have created are DELETED! Including Installed Programs! You MUST backup anything you want to keep! Backup utilities are installed with every version of windows.
Now to perform System Recovery. Restart your PC. As Windows is loading, look for a message that says "Press [KEY] for System Recovery". When you see this message, press the given key and follow the instructions, sometime they flash so quickly you cannot hit the key in time if this happens just restart and since you know which key this time be ready and hit it when it flashes, hopefully you will be able to perform a successful System Recovery.
NOTE:
In Windows 7 you can Start system Recovery the same way you did System Restore just type Recovery instead of Restore
If you do not see this message, but see other messages, try pressing them. Example: "Press [KEY] for Startup Options".
Jun 08, 2011 | Computers & Internet
I am trying to restore my acer 5735z to it's original factory settings using my 2 backup DVD disks. When I push alt + f2 +f10 it gives me a error File: \windows\system32\winload.exe ...
Please make sure you have taken the back up of all your data. If you are able to turn on the computer on normal mode successfully and insert the original Operating System recovery Disk provided by the manufacture, if not get the OS recovery disk or copy of your installed OS disk and restart the computer and press F12 key and that will prompt for resintallation.
Choose clean installation process and continue.
If you need more information, please feel free to enquire
gowtam1402@gmail.com
Gowtam R
Dec 30, 2010 | Acer Aspire 5735 Notebook
Recently crashed. reloaded with original recovery
After you restore your computer, you must also reinstall the drivers for things like your wireless receiver. This is found on the Drivers disk, also gotten with your computer. Follow directions to recover all drivers are found on the disk.
Dec 13, 2009 | Toshiba Satellite A60 Notebook
Need help,, windows 98.how do i restore
boot with the Windows 98 cd in the drive and go to dos, enter chkdsk /r to repair and restore system files.
If you are having a specific problem it might help to know more exactly what you are seeing.
Aug 31, 2009 | Systemax Dual-Core AMD Athlon 64 X2 4400+...
Where I can buy system recovery cd And application recovery cd for Sony VAIO PCV-MXS20 PC Desktop? I don't no computer to much . thank you.
I had a similar issue with a Sony Vaio Laptop recently and through accidental experimentation I found the system Sony system recovery utility. i was shooting for F8 to start Windows in safe mode and I believe I hit F9 by accident. I then discovered this whole menu of Sony recovery options from reinstalling individual software programs that were originally included to restoring the hard disk to the original shipped state. The latter included all original installed software and fresh out of the box Windows. I eventually did this and it did not require any recovery CD, just some time and a few clicks as it worked off of a hidden partition on the disk. I don't know if your desktop has the same stuff, but if it is fairly new, I am sure it does and you may have to scour the Sony support site or e-mail them to find the specifics for your unit.
Good Luck
PS. It did exactly what it claimed, restored to original state completely, but erased anything installed or saved since day 1.
Aug 12, 2009 | Sony VAIO PCV-MXS20 PC Desktop
Installing new Hard Drive Problems
i suspect you need both because the cd is not a bootable one. download a win 98 boot disk from www.bootdisks.com it will allow you to boot to dos.... then you change to the cd rom drive letter.. usually D: ... tho sometimes even X: and then type setup... that should start the restore.
Robert
Sep 11, 2008 | IBM ThinkPad A21m 2628 Notebook
Help!!!
hi
first thing i ld like to tell u is that what we have to check is that the PC shuld have the basic requirements on it as Microsoft The following list describes the minimum hardware requirements for Windows 98: • A personal computer with a 486DX 66 megahertz (MHz) or faster processor (Pentium central processing unit recommended). • 16 megabytes (MB) of memory (24 MB recommended). • A typical upgrade from Windows 95 requires approximately 195 MB of free hard disk space, but the hard disk space may range from between 120 MB and 295 MB, depending on your computer configuration and the options that you choose to install. • A full install of Windows 98 on a FAT16 drive requires 225 MB of free hard disk space, but may range from between 165 MB and 355 MB, depending on your computer configuration and that options that you choose to install. • A full install of Windows 98 on a FAT32 drive requires 175 MB of free hard disk space, but may range from between 140 MB and 255 MB, depending on your computer configuration and the options that you choose to install. • One 3.5-inch high-density floppy disk drive. • VGA or higher resolution (16-bit or 24-bit color SVGA recommended).
Jun 06, 2008 | Microsoft Windows 98 for PC
Epson Stylus Pro 9600 InkJet Printer Logo
109 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
