Question about Kenmore 98702 Stacked Washer/Dryer
Washer will not stop!
We have a stacked kenmore washer/dryer, 110.1850292 from 2002. Actually we inherited it when we recently moved in.
It was fine for the first few loads, now all of a sudden it will not stop washing, it continues through all cycles (perm. press, knit, soak, etc). At the end of each cycle it fills up and then tries to spin full of water. It never fully drains, and continues this cycle as well, through the "off" section.
What can we do?
    Top Expert:
  • Kenmore Master
  • 50,567 Answers
Call a service technician to get a proper diagnosis and quote then decide to fix or junk
Posted on Jun 11, 2017
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Kenmore 4314220
It sounds like you could have a couple of issues going on here. First of all, to answer the question about stacking the units; there is a mounting kit that you are supposed to use to place the dryer on top of the washer. The top is supposed to come off the washer to accomplish this. There are a couple of brackets to install and the dryer is supposed to mount to the washer with a couple of screws. Your local appliance store should be able to provide this for you. All you need is the model number of the washer and dryer. If the timer is only working on one cycle then you may have a bad timer. But...before we go jumping on that bandwagon...you mentioned that the washer is not filling and the water just keeps running out. This sounds like a problem known as "siphoning". If you have placed your drain hose in the standpipe in a manner that does not provide an air gap for drainage, the washer will not fill and will continue to "siphon" water from the machine as it tries to fill. If the washer cannot fill, the pressure switch will not shut off, and the timer will not advance any further. Double check your drain line to make sure you do not have it shoved too far down in the standpipe (3" to 4" should be sufficient). If the drain hose is sitting in the drain trap where the water sits, there's no air gap. Also, make sure you do not have the top of the standpipe sealed for any reason. Once again, you need an air gap in order for the water to drain properly. Let me know if this helps you.
Posted on Sep 08, 2007
  • 1028 Answers
SOURCE: kenmore 110 washer
if screens on both ends of cold fill hose are clean replaced valve have seen restricted flow even with good flow to valve but be sure screen in valve is pulled and cleaned be sure to reinstall it
Posted on Aug 01, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 58 Answers
SOURCE: kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Posted on Jul 01, 2009
Can you separate a stacked kenmore washer/dryer for moving?
they are not one unit so talk wit a service agent as to how to separate them
Nov 05, 2017 | Kenmore Dryers
Can stacked washer dryer be separated?
no that's a one peace stacked washer,dryer
Nov 27, 2017 | Kenmore Dryers
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
We moved our Kenmore stacked washer/dryer from downstairs to upstairs - now it will not work. any ideas?
If the dryer didn't get banged around or damaged when you moved it, it sounds like it might be a power issue. Is the outlet where the dryer plugged into controlled by a switch? If so, make sure the switch is on. Is it on an electrical circuit with any other large devices (air conditioning unit, refrigerator, etc.)? If so, the dryer probably isn't getting enough power. Try plugging it in somewhere else, on a different circuit (using an extension cord to test it, if you don't want to move it until you're sure) to see if that makes a difference.
Jan 15, 2011 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
Dryer door
I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
Aug 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Clothes getting caught on inside of dryer
There are a couple of guide wheels in the back of the dryer. when they get worn out the tub will have excessive play and will trap clothes inside. Just remove the front cover loosen the belt and remove the drum. the worn wheels will be easy to spot. It is an easy and cheap fix.
Nov 02, 2007 | Kenmore 98702 Stacked Washer/Dryer
No rinse
Make sure that you have both, hot and cold water connected and turned on. Some models will not advance through rinse if one of the hot or cold is off. See if this solves the problem, Catriver.
Jul 21, 2006 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore 98702 Stacked Washer/Dryer Logo
139 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
