Question about Microwave Ovens
Microwave not getting power
We have our microwave plugged in to a surge protector. The surge protector is still showing that it is getting power, but all of a sudden the microwave is no longer working. All the digital numbers, etc on the screen have gone. There is no power at all. Is this fixable? The microwave was built in May 1998. It is a Whirlpool, model # MT1151SG.
  • 10,865 Answers
Unplug the microwave oven from the surge protector and plug it directly into a working outlet. If the microwave now works you will know that it is the surge protector that is not working. If the microwave still doesnt work you may want to trash it and just get a new one as they are now much cheaper, many around 50 dollars, and more efficiently use power.
Posted on May 12, 2009
I had a power surge in my house and my EMERSON 900W MICROWAVE OVEN MW8999RD control pad is not working. The lightbulb works and the tray spins slowly when I open the microwave door. However, nothing
I hope it's still under warranty. Think about getting a replacement, and about next time: Get a surge protection device between the oven and the wall plug! I have suffered from power surges in my house as well, and a surge protector is the only cure.
Dec 07, 2014 | Emerson Microwave Ovens
My Kenmore elite microwave is plugged into a surge protector and keep tripping the surge protector. I cannot use the microwave for more then a minute before it trips. Can you help
Your microwave is pulling more amps than the surge protector can handle. Remove the surge protector from the circuit and plug oven into wall outlet. Preferrably a GFCI circuit. Or you could puchase a surge protector with a higher amp tolerance.
Sep 04, 2011 | Microwave Ovens
My GE Spacemaker 2.0 over the counter microwave just died. No lights or anything.
Hi, It sounds like the internal fuse blew. To get to it, the case has to come off the unit and its located close to where the power cord ties in. With any and all microwaves, It is a good idea to put a surge protector on the plug to plug microwave into. Hope this helps.
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
THERE WAS ALOUD NOISE AND MY MICROWAVE QUIT, NOTHING WORKS LIKE i PULLED THE PLUG. NO LIGHTS OR ANY INDICATIONS THAT IT IS ALIVE.
It sounds like you wer a victime of a power surge from the gride, ther ar protectors in the microwave called MOV's they simply short/explode thus blowing the maine fuse when the voltage goes to high, if your lucky take it to a good tech. the MOV's can be replaced and if they did what they wer desing to do the microwave should start up again...
Good luck
Jan 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Hello. My Panasonic NN-K153W microwave owen keypad does not responding, beside three keys- stop, clock and the one with symbol of microwave in the left upper corner. I can not setup the clock because no...
Other than a complete power off, I know of no reset switch on any microwave ovens. I own a panasonic myself.
I would leave it unplugged for a while, at least 15 minutes or so, and leave the door open, to turn on the inside light (which won't light if unplugged but) so it might discharge any capacitors holding residual power to the circuit.
If it wasn't power protected, it could have taken a hit.
If it is plugged into a surge protector, they wear out. You might be able to make a claim on it through the surge protector manufacturer, if it has a warranty, and you have receipt. Surge protectors do wear out, and most unless they're the cheapest, will have a warranty that covers equipment. The wear out because the varistor which provides the voltage clamping during a surge become conditioned. Initially they clamp around 150V to 180V, but as they age from repeated surges, their clamping voltage rises until it no longer protects the equipment. Often you can tell, if the surge protector LED is blinking or intermittent, the company will replace the surge device if you make a claim on the protector, if it fails while in use, they usually cover the equipment, unless the warranty has run out, but many give lifetime warranties.
The reason some keys may have been working is because after a small surge, the logic states can go indeterminate, which means some work, and some won't. If it's not damaged, a full power off for some time may restore it to initial conditions.
Hope this helps. They should build in surge protection, and I think mind does have some; but, if not, I hope it's in warranty for you.
Jul 04, 2017 | Panasonic NN-T888S Convection/Microwave...
Panasonic 1250 watt microwave approx 5 yr old. the oven is completely dead. checked in other outlets. no power to oven
something burned out, has there been a thunderstorm lately?
if you get a new one, plug it into a surge protector.
Jul 16, 2009 | Panasonic NN-H504WF Microwave Oven
The fuse keep burned every day I do replace the fuse, what is the wrong with my Kenmore micrwave 565.61589011 model. Thank you
Chances are that you have a common connection with another plug. Microwave, Fridge etc.. Even if it's not the same plug it's still "In line" meaning that both outlets are on the same breaker. A: Find another outlet to plug your Microwave into or B: Put a surge protector in between the Microwave and the outlet.
Mar 10, 2009 | Kenmore Microwave Ovens
Microwave hood combo
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would reccomend getting a new microwave and also get a small single plug surge protector for it.
Mar 21, 2008 | Microwave Ovens
Microwave causes all appliances to shut off
A surge protector will not help. The circuit that you have the microwave plugged too is overloaded or the breaker is weak.
You need to find out which breakers in your switch box operate which outlets. Then you may be able to move some of the appliances to different recepticles that are on different circuits.
Turn the lights on in all the rooms.
Got to your switch box and turn off one of the single switches(not the ones that are two switches hooked together).
Then go to each room and check to see which lights have went out. Take a lamp or small appliance to each wall plug-in and see if it has power.
When you find out everything that switch controls, write it on a piece of paper so you will know in the future what that circuit has on it.
Turn that switch back on and repeat the process with the next switch and so on and so forth until you have written down what each breaker controls.
Now you will have some idea which circuits have the most load and which ones you can move something to.
You also need to call your landlord or building super to check to make sure the breakers in the switch box are in good condition.
Hope this helps.
Nov 11, 2007 | GE JES738 Microwave Oven
Microwave Ovens Logo
251 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
