Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
TV has dark black shadows to middle of screen.
    New Friend:
Yyomarley, I read your answer to black shadow in tv screen, but wasn't sure of what you meant by get it back and do anti clockwise should fix problem. Your answer was a bit confusing to me. I have a black shadow down my tv and I am not sure how to get rid of it. Could you please help???
Posted on Jul 02, 2010
  • 24 Answers
I done something like that but i plugged mine out for like a day still had it so i left it for like 2 weeks and couple days then it went away then on that same day i noticed it started coming back and second time so i locked of the tv and went 2 sleep.Next day its back 2 dark shadowy middle and i was told by a friends dad sometimes if u have the brightness of the tv up over 50 or 60 % that can damage or have a magnet round the tv and if u did have 1 round it get it back and in a circle shape move it round anti clockwise and that should fix it . Hope i helped.
Posted on Aug 19, 2009
    Problem Solver:
  • 8 Answers
Let it on for a whole day with a stedy pic..
Posted on May 12, 2009
4 Suggested Answers
SOURCE:
SOURCE: dark shadow on lcd tv
u need to replace the tv backlight. it can be done by urself but its kinda complicated its better to just tak eit in to a repair man. shouldnt be that costly.
Posted on Jun 13, 2009
techman
  • 3130 Answers
SOURCE: Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Posted on Aug 06, 2006
  • 76 Answers
SOURCE: when the tv has been on awhile
Do the smudges move around or are they in the same position all the time??If they appear in the same position it sounds like you are having a problem with the invertor panel or the back light circuitry.If you could post photo of fault would be helpfull
Posted on May 12, 2007
Black screen
Check its back-light inverter and back-light CCFL lamps.
Jul 12, 2013 | Sceptre X32BV-Naga 32 in. LCD TV
A few days ago noticed my C7 was dark at top of the screen like a shadow. Touch screen works fine. Several days later the shadow has slowly spread down the display leaving the top third of the screen...
Sometimes when we are wearing tight clothes and put mobile phones in the pocket, the screen gets pressed against coins or keys in the pocket. This damages the screen. I think this is the case with you. Now, the only solution remaining is replacing the LCD.
Sep 11, 2011 | Nokia C7 (8 GB) Smartphone
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
Dark shadow in middle of TV when turned on . Last...
the cold cathode lamp of your tv is nearly to be busted and needs replacement..tnx
May 20, 2010 | ViewSonic N4785p 47 in. LCD TV
Dark shadow on lcd tv We have a Samsung LCD and it has a dark shadow near the top of the screen. It looks like a storm cloud on the TV. It looks like it may be starting to do the same thing at the...
Apr 08, 2009 | Samsung LNT3242H Television
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Dark shadow like mark on screen
The drak Shadow mark I see on my Screen looks like the black soot like marks you see at the end of a flourescent tube. I think it is the back light.
Dec 18, 2008 | Philips 32PF5531D 32 in. LCD Television
Philips 55 inch hdtv rear projector
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
2,670 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
