Question about Fellowes Powershred 220CC Shredder
Power shredder jam light is constantly on
    Problem Solver:
  • 15 Answers
There is a sensor inside the gears turn it upside down and shake it. Clean out all paper fragments. and oil it well. Good luck they like to fight back. Also make sure you unplug it first!
Posted on Oct 13, 2007
2 Suggested Answers
  • 541 Answers
SOURCE: SHREDDER WILL NOT POWER UP. NO LIGHTS, NO POWER
you will need to open it and test the on/off switch, door switch, fuse all for continuity. turn the machine off and unplug it . unscrew it from the base. flip it over, unscrew the bottom. now test with a dm. if you are needing a tech i michigan please call 248-677-8112
Posted on Oct 23, 2009
Rexel 100X. Why does it work for 2 seconds in reverse only, then jams?
From your description, experience tells me there is something jamming the mechanism. If plastic or clay coated material has been shredded, there will be residue between the grinding wheels that will require use of a utility knife and a pick to remove bit by bit. You will have to apply power periodically to rotate the mechanism and give access to new areas to be cleaned.
Dec 26, 2015 | Shredder Office Equipment & Supplies
Shredder stopped working lights come on shredder doersn't not jammed
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Apr 21, 2014 | Fellowes Powershred PS-60 Shredder
Staples Shredder SPL-TXC22A always has the jam light lit and will not work even though there is nothing jammed. It works if I press and hold the down button twice. It also works continuously if I turn off...
Home office shredders get jammed because the mechanism is not self cleaning. If you remove power and expose the mechanism you may find that, indeed, a shard of paper is triggering the jam sensor. These shredders require periodic removal of the bits of paper from the mechanism, an exercise that can consume hours of picking with tweezers while thinking there must be a better way.
Dec 10, 2013 | Office Equipment & Supplies
Anti jam light is on unit will not run
The "anti-jam" light actually is a jam light and it is notifying you that the shredder is jammed. If you turn off the power and examine the shredding unit you will find shreds of paper stuck in the mechanism. Removing all of the shreds will get your shredder back in operation and the anti-jam/jam indicator will be off
Apr 15, 2013 | Office Equipment & Supplies
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
The paper is constantly getting jammed up in the rollers
these shredders only can handle 2 or 3 sheets max. also using WD-40 or any light machine oil will help the process
Dec 16, 2010 | Fellowes PS60-2 Shredder
Oct 23, 2009 | Royal 150MX Cross-Cut Shredder
Office Max Shredder #OM96146
Don't open it, check on product warranty policy and take it back or send it in.
Jun 03, 2008 | OfficeMax 0M96431 Shredder
Fellowes Powershred 220CC Shredder Logo
139 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
