Question about Brother XL-5700 Mechanical Sewing Machine
Loose bottom stitch on brother se 350
The bottom stitch is loose when I sew. I already cleaned the bobbin case and rethreaded the bobbin. The tension is set on 4.What do I now?
  • 128 Answers
Hi, general rule of thumb:: loops on the top, problem on the bottom.. Loops on the bottom, problem is on the top.. When threading your machine, stop just before you thread your needle, put the presser foot down. Try pulling the thread. If it pulls easily, the thread is not thru the tension wheel right. If it pulls hard, you got it right.
Posted on May 12, 2009
How do I fix my loose bottom tension?
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread the machine from the beginning. Verify the path is correct. The standard tension setting is the midway point although you will most likely need to tweak this for your particular machine.
If you are still having problems, you may need to readjust the bobbin tension.
Understanding Thread Tension Threads
Feb 21, 2017 | Sewing Machines
I have a "Brother CE5500PRW" machine. I have
1 - Make 100% sure you are threading the top thread correctly.
2 - Make sure your top tension is set at 5.
3 - Look in your book and make sure you have the black plastic bobbin case inserted 100% correctly.
4 - Remove the black plastic bobbin case and inspect it for burrs or needle damage, if so it needs to be replaced.
Oct 02, 2014 | Sewing Machines
How do I adjust the timing on Brother inovis 1500 sewing machine?
Clean the machine, especially the bobbin and bobbin case area and around the feed dogs. Take all the thread off the top of the machine, including thread off the spool pin. Raise the presser foot. Rethread the top with the presser foot UP, which lets the thread get between the two tension disks. Put the foot down to sew, and hold the ends of the bobbin and top threads together behind the presser foot for the first 2-3 stitches in each seam.
See also: http://www.picturetrail.com/sfx/album/view/22521551 I'm betting you're seeing something like the last two pairs of photos.
May 22, 2014 | Brother SE-270D Computerized Sewing...
Bobbin thread shows
have you tried to tighten the bobbin tension spring??
Dec 23, 2012 | Brother PE770 Computerized Sewing Machine
The stitching is not right. It looks fine on the top of the fabric, but bunches up on the bottom
Looping or bunching on on the bottom is a result of problems with the TOP TENSION.
Rethread the upper thread and adjust tension. Try again.
Jul 05, 2012 | Brother CS6000i Computerized Sewing...
Hi, My sewing mechine is brother lx-3125 and my problem is getting loose stitch on both sides of fabric when i set stitch is 10 and tension 4-6..and also i am getting loose stitch on other no also like 9...
Most likely your machine is not threaded right, read your manual closely and double check yourself. Rethread your machine, no mixed thread use same weight, color does not matter but weight does. With your presser foot down, your top thread should be had to pull, with it up it should pull freely. Make sure your bobbin is wound evenly, and on a fresh bobbin. Then put in a new needle. Now, if the machine is still acting up, it may be your timing. You can call Brother at 1-877-276-8437 customer support. if you need a manual, go to www.brother-usa.com. I am answering this for free just to try to help you. Good luck
Oct 07, 2010 | Brother XL-5500 Mechanical Sewing Machine
Stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Dec 10, 2009 | Brother SE-270D Computerized Sewing...
Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Sep 05, 2009 | Sewing Machines
Bottom stitches loose
You don't want to adjust the bobbin tension, you'll want to try adjusting your stitch length, as well as the regulator tension.
Jan 03, 2009 | Brother LS2020 Sewing Machine
Upper Thread Error
I just posted this under another Brother machine...mine is a se 350 but, might be the same problem!! Hi....I also kept getting the check and rethread upper thread message, I'd sew about 15 stitches and it'd stop. Here's what I did. On the left of the machine, in the back there is a screw....loosen that screw, take cover off, then lift straigt up and out on the cover that has the 3 on it in your threading seqence. Next, I started inspecting and cleaning the thread route from top to bottom. Lo and behold....I get to the place where you come down the front of the machine and turn to go back up and I spot a little slice/cut in the plastic piece so, when I was threading the machine I guess I was pulling it to far to the left causing it to wear a little slice/cut in that piece....so, I finished cutting it off with a utility knife, used an emery board to smooth it down, put the covers back on and it works GREAT!!!! Who would've ever thought that it'd be so easy and save me a bunch of money!!! I sure hope this helps someone.
Oct 22, 2007 | Sewing Machines
Brother XL-5700 Mechanical Sewing Machine Logo
733 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
