Question about Refrigerators
Refrig/Freezer not cooling
Kenmore 52552100 Refrig/Freezer not cooling. CLeaned all coils,drainline checked and cleaned. No ice build up. Fans functional, compressor not functioning.
    Problem Solver:
  • 19 Answers
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
Posted on May 12, 2009
I have a kenmore elite 795.77549600 and it's not cooling like it used to the compressor is very hot to the touch and one of the lines is frosted over what could it be? Cleaned fan and coils too help!!
This can happen if the freezer fan is not running or you have excessive ice build up from the unit not defrosting. Check to see if the freezer fan runs by pushing the light switch in the freezer and look for frost build up on the freezer back panel.
Apr 24, 2015 | Kenmore Refrigerators
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Top freezer working fine refrigerator part not cooling we've cleaned the coils
Did you check for an ice build up behind the rear panel in your freezer? It sounds like your defrost system is not working and allowing ice and frost build up that is blocking the cooling tubes to the refrigerator.
But also make sure that the evaporator fan in functional so that it forces the cold air from the freezer to the refrigerator through the cooling tubes.
Sep 04, 2011 | Kenmore Refrigerators
Refrig/bottom freezer not cooling, fan running, lights running, controls working fine, every 5 minutes a humming, then a clicking....cleaned condensor fans and cleaned condensor coils by vacuuming My...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 30, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Have Kenmore 106.8607913, top freezer. Not cold enough. All fans working. Cleaned bottom coils. Not ice bound. Compressor clicks on, then off about 1 or 2 seconds later. Compressor or thermostat,...
If the fans continue to run when the compressor kicks off the thermostat is functioning normal.
The problem could either be the compressor itself or more likely the start device (relay) that controls the compressor, it is an easy component to replace and mounts directly to the compressor.
The part number for the relay is 989662
If the relay is good and compressor is bad, you would be looking at about $500.00 to repair
Apr 18, 2010 | Kenmore 64802 Top Freezer Refrigerator
What is proper operating temp of freezer/refrigerator?
0-5 F in the freezer.36-42F in fresh food.
Check for ice buildup on the back wall of the freezer. Check the freezer fan motor. Check the compressor fan motor.
Sep 06, 2009 | Kenmore Refrigerators
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cleaned coils,lower fan, drain lines. Checked door seals, temperature reset, both fans are runnign but
Need a New Compressor. That is the only way of Cooling. If it was working and not cooling it could be the Condensor or low on Freon.
May 12, 2009 | Refrigerators
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
May 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer not freezing
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
Sep 05, 2007 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
244 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
