Question about Dryers
Running and blowing air but not heating
The dryer runs and blows air out the vent, but is not heating.
  • km13hogan May 12, 2009
    I gave the model number when I posted the question, so I don't know they didn't print it? It's Amana LE8457W.
  • 460 Answers
I think this will help
http://www.youtube.com/watch?v=HRKIU4LiS20&feature=related
Was this helpful?
Posted on May 12, 2009
  • 62 Answers
It would help to have a model number. But before you send one make sure you turn off the breaker to the dryer all the way off then turn it back on and see if it starts heating. If that does not work write back with your model number.
  • Pataricia Nolte
    Pataricia Nolte May 12, 2009
    If the breaker trick did not work you need to take the front panel off and and the drum out and look at the heater are all the coils intact/not broken. There is a fuse on most Maytag/Amana Dryers that can go out check it out as well. Is there a burnt off wire?
  • Pataricia Nolte
5 Suggested Answers
  • 83 Answers
SOURCE: maytag dryer not blowing hot air (2yrs old)
If the vent is blocked, it will not stop the heat, it will only restrict the air flow.
Generally a couple of things can cause the heat to stop.
Either the thermostat or the element.
I would first suggest the element.
It may be fatigued therefore the internal wire within the element becomes fragile and eventually breaks down. Although it is an electrical item, it is mechanically built and can fail.
In some dryers the element is held in clips.
These clips can cut into the element.
The thermostat maintains temeperature but again, it is mechanically built and can also break down.
If you are not capable of inspecting or troubleshooting the internals of the dryer (i.e remove the cover and look for the failurer), then have it inspected by a repairman. There is not too much that can go wrong with a dryer. The most expensive part wuld be the motor that spins the drum.
Posted on Sep 17, 2008
  • 530 Answers
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Posted on Jun 02, 2009
  • 4 Answers
SOURCE: The dryer is not blowing air. I checked the vent,
If you are not getting heat it could be several things like a bad limit switch or element burned out, the only way to know for sure is with a test meter to track the flow of electricity. If you are not comfortable with electric wiring it is best to call a repairman if you are comfortable useing a volt meter and a ohm meter I can walk you through the steps.
Posted on Apr 17, 2010
  • 4 Answers
SOURCE: Maytag Bravos dryer heats but does not blow air.
Maybe that was in addition..they tell us the air flow is blocked and tell us 2 clean our air duct ..but the dryer was blocked on inside..the repair man claimed the belt was off maybe he was blowing smoke..but these are the kind of people they are sending out..trying to blow off as many appointments so they can get off on time.
Posted on Jul 26, 2011
No heat or air blowing inside unit
Are you sure you dont have a clogged Dryer Vnet?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Feb 09, 2014 | Samsung DV419AEW 7.4 Cu. Ft. Electric...
Dryer wont stay lit
if the flame is liting most likely problem is bad air movement.go outside with thedryer running and check the hood to see how strong the air is blowing out,if there's a cage or anything blocking the hood remove it,if the vent line is a long run remove the vent line from the back of the dryer,stick a leaf blower into it and blow out the lint to the outside.also with the dryer unplugged,remove the bottom panel,remove the lint filter and metal duct the filter slides into,clean that out and blow out the blower wheel with a shop vac,you can blow out the gas tube where the flame ignites to make sure it's clean blow off the motor and the cabinet and vac up all lint that blows forwards.you can try running the dryer with the vent line removed to see if it runs any better.when the dryer first heats up the flame will come on until the temp. is reached and it will shut down,one more thing to check,when gas coils start to fail you'll have heat for like the first 15 to 30 minutes,then when the coils heat up the ignitor will glow but no flame,after the coils cool down they will work again.how are you running it on timed dry or more or less dry,if you run it on auto or more or less dry there's a sensor inside where the lint filter is,try cleaning it up or try running it on timed dry to see if it runs any different,when on auto the heat comes on,when it reaches temp. the heat stops and the timer will advance,when it calls for heat the timer stops and the heat comes back on,it will do this until the clothes are dry.your model has an even heat board in it that can also cause problems but if the flame is liting it sounds like you have a block somewhere.go here this will tell you a little more about your model dryer.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
May 23, 2013 | Dryers
Dryer will not blow hot or cold air
what's the brand name and model number?i don't understand what you mean it won't blow hot or cold air?if you have the vent line off of the back and the dryer is running and you don't feel any air blowing out you could have a bad blower wheel,if you write back let me know if it's running and what it's doing.thanks
Feb 17, 2013 | Dryers
Outdoor dryer vent causing the air condidtioner problem
did he clean out the dryer and clean out the vent line?dryers need to be cleaned out,gas dryer should be done once a year and electric dryers every two years.we come in,take the dryer apart,clean out the duct that the lint filter slides into,blow out and vac out the inside of dryer where the motor is and if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower and blow out the line,if it's clean you won't notice any lint blowing out,alot of the time when the dryer is on and heating up the vent line lint that's built up inside the vent line will blow out if the line hasn't been cleaned out,your dryer will dry the clothes better and you won't burn out any parts if the dryer is clean and not running hotter than normal from a blockage somewhere,and you don't have to worry about a dryer fire,good luck
Jul 02, 2010 | Kenmore Dryers
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
Jun 02, 2009 | Kenmore Dryers
Not geting hot enough
The most common thing to cause this is a blocked vent. Start the dryer and go out to where the vent comes out of the house and see how hard it blows. If you feel little air out the vent, you will need to unhook the dryer from the vent and see how hard it blows there. If it is blowing good there you need to have the vent pipe cleaned. If dryer isn't blowing hard out the back, please reply back with the model number so I can give more detailed directions on checking the blower wheel and ducts.
Oct 11, 2007 | Kenmore 74602 Gas Dryer
Dryers Logo
201 people viewed this question
Top Dryers Experts
