Question about Sony KDL-32M3000 32 in. LCD Television
Hi, I have a kdl32-3000. I have message of No signal, however everything checks out with uverse. I tried setting tv to channel 3 to go thru set up again but tv keeps jumping to channel 2 before I can go thru set up and auto program channels. What is the issue?
SOURCE:
waynejamescm
  • 67 Answers
SOURCE: Sony 37" Flat Panel Bravia--cant change from channel 2?
On the original Sony remote control, try typing in a channel manually. Try pressing the numbers "0-4" or "0-5," and waiting for a moment. If the channel changes, then the TV needs to be autoprogrammed. Using the SOny remote control, go into the MENU (or HOME on some Sony remotes), and look for the initial setup screen. It will walk you through the process. The process is also in the original users manual, available on the www.SONY.com website.
Hope this helps you....
Posted on Jan 05, 2009
SOURCE: TV Cable card slot loses signal immediately after channel find
THis is not a solution but a similiar issue. I have had a scientific Atlantia Cable card with comcast for 3 years no problems at all. Spent the entire day trying to switch to Verizon today. The signal comes across for about 10 seconds, pixelates and then fails. This happen after every start. We have checked the lines, tried 2 cards and reduce the signal. We gave up for today- installed the old Scientic Atlantic, reassigned it to comcast and all works fine Any and ALL suggestions are most welcome Thanks
Posted on Jan 15, 2010
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
  • 112 Answers
SOURCE: My tv keeps resetting and
you have memory problem then use the sony memorry update stick witch the new version of software if that do not helps you will need to change the eeprom
Posted on Sep 22, 2010
SOURCE: TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Posted on Jan 09, 2011
2 tv's. recently had uverse removed. neighbor has rabbit ears-gets local channels. I get nothing. Does something with uverse change my tv's?
Your tv my have a setting for type of input. Cable of Air channels. You would need to switch that to AIr. Also, the air channels have gone to a digital signal and I believe they take "digital rabbit ears" I think the old style may not pull in the digital signal, but I'm not entirely certain about that one. Something like this http://www.amazon.com/AmazonBasics-Ultra-Thin-Performance-Indoor-Antenna/dp/B00DIFIO8E/ref=sr_1_1?ie=UTF8&qid=1409885138&sr=8-1&keywords=digital+antenna+for+hdtv+indoor
Sep 05, 2014 | Televison & Video
Can't get TV picture after hooking up PS 2
How many sets RCA ports (for Video 1 / Video 2 so on and on) does your TV have?
Jul 26, 2008 | Panasonic Televison & Video
Trying to set up my new elements tv with a uverse wireless box. Did a channel scan but still can't find any channels. Help please!!
Is this a high def tv? Are you using an hdmi cable, component cable(red green & blue) or a low def coax cable to connect the tv? If coax, the tv needs to be on channel 3 or 4. If hdmi or component cable is used you need to change your input on the tv with your remote to the matching input you wired it to. The uverse stb (set top box) changes the actual channels once you have selected the correct input.
Jun 26, 2014 | Televison & Video
Uverse receiver signal is not 1080i
Hi Drkdani45,
I have this useful link for you where in you can see how to set screen tv settings to 720p to 1080i. Hope it helps.
http://www.att.com/support_media/images/pdf/uverse/Quick_Fix_Guide.pdf ( if you can't go to this manual directly please click on the new link below and click Configure your AT&T U-verse Receiver for High-Definition)
verse TV Support
Jun 21, 2012 | AT&T UVerse
The disc is stuck in the player and the tv screen says it cannot get a signal.
Barbara, your dvd player needs to be either on channel 3 or 4. If you have a local channel 3 or 4 switch it to the one that is not local. Or it could be a video 1,2 or 3. Just keep using the remote in that format and you will find the signal.
Nov 21, 2011 | Cyberhome CH-DVD 300 DVD Player
The words "weak signal" flashes on screen at different places and do not receive a picture.
seems like you are using an "off the air antenna" that receives weak signal, you may be too far from the station, go get a roof top amplifier antenna or subscribe to digital service from cable, satellite or at&t uverse. If you think your antenna is getting good signal, try to rescan your tv for available channel. Make sure your TV set up is correct, if you are using Off the air signal, your setting should be set at "Antenna or off the air", then rescan your TV. Normally on Satellite or cable box, you just watch it on video channel or component input, if you are using HDMI then tune to HDMI channel.
Check your connection to make sure they are making good contact. If you can post your set up, I can better solve your problem.
For a resource on "off the air" antenna, go to www.antennaweb.org for help.
Aug 16, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Insignia TV ... big RED X on Screen!
This just happened to me this evening and I have an Insignia as well.
With your TV on, try unplugging and repluggning in your HDMI cable. Hold your reboot button for at least 15 seconds. Should reboot and work.
Jan 26, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Converter box
You'll need to keep your TV on channel 3 or 4 depending on what channel you set the converter box. All your channel changing will be done through the converter using its remote control after that. If you change channels on the TV itself and go off channel 3 or 4, the TV will not get a signal and will show you that "no signal" message.
Nov 24, 2008 | Sanyo AVM-3259S TV
Stuck on channel 3
Set-up in menu = step thru each page = skip what does not
apply to you = get to auto-program....be sure signal is attached
to set first.........................T.
Dec 11, 2007 | RCA F32650 32" TV
Sony KDL-32M3000 32 in. LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
