Question about Stairmaster Stepmill 7000 Pt
Oil smell from hyd cyc when in use - Stairmaster Stepmill 7000 Pt
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
The recommended oil for the chain is Motor oil w30 so its normal
Posted on May 17, 2013
    Problem Solver:
  • 19 Answers
The Hydraulic Fluid needs to be Changed, Chances are it has lost its Original Viscosity and is "Used Up" and/or Dirty.
Posted on May 12, 2009
Thomas skidsteer hyd ran low on oil now will not operate filled hyd sounds like a belt slipping
more like pump cavitating and not good for it at all. dont know how but you need to bleed that air out of there before you trash the pump itself.
Aug 02, 2017 | Cars & Trucks
What tipe of oil And how many gals. of oil To service a bobcat 335
6 qts engine oil . 8 qts. 80-90 front diff. 12 gallons hydraulic oil John deere hyguard trans/hyd or Traveller trans/hyd oil at tractor supply
Dec 31, 2016 | Bobcat Garden
4496 CASE TRACTOR .Ran out of hydraulic oil , filled up and bleed lines , still have no steering and the brake is out ,.What valve is locked in ?
by bleeding lines where exactly did u do this ? , the place id try 1st is right off the pump to the dist block (carefully!!!) if no pressure there then a more aggressive repurdge of hyd sys is needed using another machines hyd system connected to remotes inputs off the dist block
reason 4 this is that hyd oil pumps don't just pick up oil again when run dry an have to be helped to pressure up again , Also another possible cause is that pressure relief is stuck open , this doesn't allow any pressure to build up
Nov 13, 2015 | Cars & Trucks
Toro dingo drives forward slowly but rev is ok
have you greased and oiled the machine, changed the oil. it sounds like the oil. the oil pump start to fail, causing metal to metal reaction,
Sep 16, 2015 | Toro 2007 Dingo Tx420 Walk Behind Mini...
EX58Mu hitachi Excavator will not lift main boom arm all other hyd actions work well
Is it leaking any fluid. Spool valve may have a blown seal.
Jan 29, 2013 | Garden
I just put oil on my cherrypickers manual hyd ad dosent pump what can i do?
sounds like it has a gut full of air which can be compressed whereas hyd oil cannot and is not circulating. must be some way of bleeding system
Dec 10, 2012 | Cars & Trucks
Where do you put hydrallic oil in a mtd white lawn tractor ,
First thing hyd. oil should not and can't come out the oil filter. May a hyd. filter. I'll try to find something. Most tranmission are sealed.
May 06, 2012 | Garden
Front brake locked on Kawasaki 300 atv
i would presume you have hyd front brakes? if so your return hole in your master cyc could be pluged.this would not let fluid to return to the resivouir. remove fluid and clean the tiny return hole on bottom of master cyc.Use comp air only
Mar 18, 2009 | 1989 kawasaki ZXR 250
Open Questions:
See all Stairmaster Stepmill 7000 Pt Questions
Stairmaster Stepmill 7000 Pt Logo
208 people viewed this question
Top Stairmaster Exercise & Fitness Experts
fordexpert
Craig Butler
Craig Butler
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
