Question about Car Audio & Video
How do I take off the backseat trim and the cover to get to the rear speakers of my 1999 Chrysler 300M?
  • 165 Answers
You need to take off the whole back seat first
Posted on May 13, 2009
Remove steering column cover 300m chrysler 1999
Hi Trevor, I'm glad to help!
The Steering Column Cover is held by 3 screws mounted upward and you reach them through the access holes from under the column. Some are Phillip's head screws and some are torx screws. Once the screws are out remove the top cover first, then the under cover next. Hope this helps and have an awesome day Trevor.
Mar 02, 2013 | 1999 Chrysler 300M
Where are the door panel contacts to remove the inside panel to replace the rear passenger accuator/latch?
take the screws out ( in the interor door handle / arm rest and the door latch release) then just tug on the trim panel straight out to release the trim panel from the door structure.
When reassembling , be sure the clips are all alligned with the holes and press back into the door structure.
Oct 05, 2011 | 1999 Chrysler 300M
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
Radio system not working, where is fuse 1999 Chrysler 300M
open driver door at end of dash ther is a removeable cover fuses are in it radio fuse should be marked in cover its placement
Mar 23, 2010 | 1999 Chrysler 300M
How do you remove the rear seat in a chrysler 300M
Grab the bottom seat cushion at the front of one side and pull it straight up then do the same on the other side. (you will have to pull up very hard) The bottom of the seat clips in. once you have the bottom out take the 2 bolts out of the seat belt fasteners that holds the bottom of the top seat cushion. Then pull straight up on the seat cushion to slide it off two tabs that hold the top.
Jan 31, 2010 | 1999 Chrysler 300M
Need help installing 6x9s into a chrysler 300m can't get to the rear trunk speakers to install the need one
if you have 60/40 rear seats, fold them down, if not remove the seat back(a firm tug at the corners should do it) the rear deck(where the speakers are) should lift up. this may take a little gentle persuasion.(the trim on the sides of the rear window may have to be removed as well) this should expose the factory 6x9's and they're mounting screws
Oct 02, 2009 | Pioneer tsa6970s 6 x 9 3W Speaker Car...
1999 Chrysler 300M door post speaker
www.Crutchfield.com
They have a web page to outfit your particular model
click on main store, then click on outfit your car.
hope this helps
Sep 16, 2009 | Infinity Reference 6820cs Car Tweeter
Location of the oilpan and filter of my 1999 Chrysler 300M
there is a large plastic cover/shield under the car, remove it and the filter and oil pan are right there, the filter is in the front.
Dec 04, 2008 | 1999 Chrysler 300M
Installing rear speakers for 300m chrysler
You have to remove the backseat, the back upper sidepillar trim and then the cover over the speakers.
Aug 01, 2008 | 1999 Chrysler 300M
Car Audio & Video Logo
103 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
