I don't know how to wire 15 kw heatstrips in a goodman package heatpump . I've got two height voltage wires ran to it now
  • 407 Answers
There will be a plug that will connect with another plug inside the heating compartment, and then your high voltage wires connect to the breakers.
Posted on Dec 08, 2013
SOURCE:
Therinnaiguy
  • 1420 Answers
SOURCE: My goodman seer 13 package
Is the outside unit starting and fan blade spinning? Have you inspected you air filter recently?
Posted on Sep 15, 2008
  • 121 Answers
SOURCE: Wiring diagam for goodman heatpump
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Posted on Oct 09, 2008
rockitman187
  • 2559 Answers
SOURCE: Heatpump A/C not working
First,Turn on the heat cycle (Not Emergency)and see if the outside unit come on,If not,and you don't have low voltage outside,Go to the inside unit and test the transformer,If you have low voltage from the transformer but not outside,It is the low voltage wires,If you don't have low voltage from the transformer,It's the transformer.If you have low voltage outside when in heat mode,but the unit won't come on,It's the contactor.Let me know if you need more help.
Please take time to rate this fixya
Posted on May 13, 2009
SOURCE: I need wiring diagram for goodman AC unit heatpump/electric
The wiring diagram is on the inside of the door on the blower/air handler unit.
Posted on Mar 19, 2010
  • 51 Answers
SOURCE: wiring diagram for Rheem rpka-31 jaz heatpump
TURN THE POWER OFF TO THE UNIT. TAKE THE BACK PANEL OF OF THE HEAT PUMP AND LOOK FOR A SQUARE PLASTIC BAG FASTENED TO THE INSIDE OF THE UNIT, IT MAY BE LOCATED BY THE CONTACTS AND SYSTEM WIRING OR ON THE PANEL ITSELF. REMOVE THE PAPER FROM THE PLASTIC AND THIS SHOULD CONTAIN YOUR WIRING DIAGRAM. ALSO LOOK ON THE BACK OF THE PANEL ITSELF FOR THE DIAGRAM. SOMETIMES THE DIGRAM IS PRINTED THERE.
Posted on Apr 13, 2010
I am trying wo wire the t-stat on a package heatpump. the wiring inside the unit does not have a yellow wire but does have a purple wire. What does it hook to and why no yellow wire?
With a heat pump the indoor fan coil does not have a yellow wire that is true your yellow wiring comes from the thermostat which is a 6 wire or 8 which is also true coming from the outdoor condenser you must connect the yellow coming from the condenser and the yellow coming from the thermostat inside the fan coil cabinet the purple is for heating
Oct 11, 2018 | Goodman Heating & Cooling
Goodman package heatpump blower motor contant running
check your themostat fan mode switch to see if it in on or auto. It should be in auto. If this does not stop indoor fan motor, (it may take up to 2 minutes for the fan to stop, preprogrammed shutoff in the thermostat and fan control cards may make you think the fan has not stopped ) If this does not stop the fan the fan control board in your air handler has a green wire shorting to 24 volt signal in the theromostat wire or the contact on the blower control card is stuck and will need replaced.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
LOOKING FOR SCKEMATIC WIRING DIAGRAM FOR GOODMAN GAS PACK #PCB120245-3
type in your browser Goodman GPG152407041 15 SEER / wiring diagram
Jan 18, 2011 | Goodman GPG152407041 15 SEER Packaged...
How does a 95% goodman gas furnace wire up with all fuel board & goodman heatpump 13.0 seer low voltage wiring
A picture is worth a thousand words. Check out this link for the best explanation.
http://www.alpinehomeair.com/related/diagrams_10.pdf
Sep 26, 2009 | Goodman GMS90703BXA Heater
May 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
