Question about Sears Drills
I have an older 15,5 sears cordless trying to change chuck What direction does the screw holding the chuck turn left or right thanx gevinsky
  • 2,176 Answers
Most everything I work on is left hand thread. let me know if you have any more questions
Posted on May 25, 2009
How to remove keyless chuck
open the chuck jaws right up
down the center of the chuck you will see either a philips screw head or a hex head for allen key
hold the shaft at the base of the chuck to stop it from turning and undo the screw in the chuck in a right hand direction ( it is a left hand thread) when you have that out , still holding the shaft turn the chuck in the left hand direction ( normal thread ) and screw the chuck off
to assist in undoing the chuck do it up so that the jaws come out a bit
place something between the 3 jaws to act as a lever or use an allen key in the chuck done it tight and use that as a lever to undo the chuck
the secret is the lh thread screw in side the chuck which stops it from undoing when the drill is in reverse
Nov 17, 2015 | Bosch 18V Brute Tough Drill with Blue Core...
3/8" cordless driver can't change the
If debris enters the chuck it may no longer turn for adjustment. Spray plenty of wd40 into chuck and allow plenty of time for oil to do its magic. Hold chuck/drill pointing down and turn drill in both directions to clean out debris. If chuck is too far gone, remove the center screw (backwards thread) and remove the chuck(threaded on). Replace the chuck with new generic part from Lowes (about $25.).
Sep 20, 2011 | Dewalt Drills
How do i replace the jacob chuck on a hilti hammer drill?
Open the jaws of the chuck all the way open. Inside the chuck you will see a slotted screw. Use a large flat head screw driver and remove screw. It will have left handed threads.
After you remove the screw put the end of the chuck in a vise where the 6 flats sides are. Put the drill in low gear and reverse. Hold tight and turn on the drill. This should run the chuck right off the spindle.
Jun 28, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
I have a 12v makita drill and cannot remove the chuck i have removed the screw inside the chuck. lease help
The chucks on most drills are left hand thread. To be sure which way to turn the chuck check the screw the chuck will turn in the opposite direction.
Mar 29, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How do i remove the chuck from an dv 18 dl cordless drill
Most drills have the chuck secured with a screw. Twist the chuck to open jaws fully. Look into the chuck to find a screw head - it may be a straight, phillips, allen or other type blade to engage so that it may be loosened and removed.
If unable to remove the screw - it may have left-handed threads, so try turning the screw in the opposite direction.
I hope this helps!
Oct 26, 2009 | Drills
How to change the chuck on a draper red line 18v cordless drill
The screw you are trying to remove is left hand thread. You must turn is clockwise to remove it.
Hope this helps
Apr 15, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Drill chuck removal
The screw should be left hand thread and the chuck is normal thread. The 'workshop' way to remove the chuck is to remove the screw (done). If the jaws are still working then clamp a sturdy allen key in it and whack it against a workbench to unscrew the chuck. If holding the drill in the normal position you would stand with the workbench to your left and whack it down on that. If the jaws aren't working then you can grip the body in a vice and use large pipe grips or stiltsons on the chuck. Also check to see if the chuck spindle will accept a thin spanner to hold it, as this is a slightly more caring way to brace the spindle. Then you can can hold the spanner in the vice and use the allen key in the chuck and unscrew it that way.
Oct 22, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Chuck Replacement
Hello Mike-To remove the old chuck, you'
ll need to open the jaws all the way and l;ook inside the chuck for a screw that holds the chuck onto the motor shaft. That screw has a reverse thread which means that you'll need to hold the chuck tight while using a screwdriver to turn the screw in the forward direction. After the screw is removed, p[lace a large allen wrench into the chuck and tighten it. Then using a hammer handle, rap the allen wrench in the reverse direction for removal. Then call Alltrade Tools @ 1-800-423-3598, give them your model number so they can provide you with a replacement chuck.
Jul 31, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
How do you change a chuck on a DW995. I took the center screwn left handed screw out. How do you back the old chuck out?
u need allen key that fit to the chuck. insert the short end to the chuck. tighten the chuck if u can. hold the drill at the edge of the table & smack the allen key counter clockwise. do it again if needed. but before u do it set the speed to #1 position & drill mode.thanx good luck
Jul 17, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
Top Sears Drills Experts
AZBen
AZBen
Andrew Taylor
Andrew Taylor
Are you a Sears Drill Expert? Answer questions, earn points and help others
