Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
Bugs in my transformer
I have a low voltage light transformer for my outside lights. I just recently replaced the transformer, and now the lights are not working and there is no power coming out of the transformer, but there is going in. When I opened the top of the box there where hundreds of little white bugs and black ones as well (looked like maggets). How do I prevent the bugs from getting inside the transformer, and is this why it isn't working. Can't find any help anywhere.
    President:
  • 2,559 Answers
That is why it's not working,The bugs have shorted it out.It sounds like termites.you can get some spray and treat the area to keep the bugs away.
Posted on May 12, 2009
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
Humming halogens. I recently installed an electronic low voltage dimmer, 300watt DIVA, to my Kablelight system. I have 4 MR16- 12V- 50 watt bulbs. (200 watts total). When dimmed, the lights hum loudly. I...
Transformer hum with dimmers is a problem. Lutron may offer you an inductor to add to the wire to help. Replacing your 50w bulbs with 12w LED bulbs may help, too. Same light output.
May 06, 2014 | Electrical Supplies
WE have a Lennox furnace that is 3 years old. We also have a Lennox AC that is 14 years old. Recently we had a board go bad on the furnace after a series of power outages and it was replaced. We also...
your furnace uses 115 power & there is a transformer in this unit that powers the low voltage controls. i would say that when they replaced the board they missed some issues with the low voltage control wires. which is likely to be what cause the board to go bad. theses low voltage wires are the only thing that can tell the outside unit to come on. the lights dimming tells me that you have a bad capacitor or need a hard start kit. the lights normally only dim if the compressor doesnt start.
Oct 13, 2013 | Carrier 38CKC036 Air Conditioner
Carrier fernace light on board not comming on
check high voltage going to board and transformer then check low voltage from transformer to board. If you have voltage on these board is bad. Correct voltage that is.high 110v-120v low 24v-28v
Aug 28, 2012 | Carrier Heating & Cooling
I have a self-installed Leviton TTI06-1LM dimmer (600w capacity) that controls a halogen light that uses 12x 12v/20w (140w total) halogen lights. The dimmer works fine, but once a day, or perhaps every...
Your issue is that the dimmer is not rated to handle the type of fixture/lamps its controlling.
From a lighting control standpoint, the 12V-lamps classify as "low-voltage halogen" and, somewhere in that circuit, have a transformer(s) converting the 120V~ down to 12V~. Using incandescent dimmers (like the one you are using) can cause compatibility issues with those transformers. What I suspect is happening is that the incompatibily is either throwing voltage spikes or current spikes on the line which are causing the dimmer to enter some sort of "safety" mode to shut everything down before any problems occur.
My recommendation is to first figure out what type of transformer it is: Either magnetic low-voltage, or electronic low-voltage. Ideally you would contact the transformer manufacturer (or look up their specs online) to figure that out. Other rules of thumb: if the transformer's big & bulky, it's probably magnetic - conversely if its lightweight, it's probably electronic. If its only one transformer controlling all of the lamps together, it's probably magnetic - conversely if its one of those transformers where the transformer and light bulb come togheter as one assembled unit and then snap into the track, it's probably electronic.
Then make sure the dimmer is rated for magnetic low-voltage, or electronic low-voltage (depending upon what the transformer is).
Feb 11, 2011 | Leviton Decora Light Dimmer Switch
Unit wont start, flashing lights on indoor unit, fuse may be gone
How old is it? Can you justify spending lots of money on an older system? Sounds like a transformer issue. Sometimes if the low voltage wiring gets shorted outside via dog or weed eater it will short the transformer. But if transformer is on control. Controls are cheap at supply houses maybe not from technicians
May 28, 2009 | Heating & Cooling
What Kind of Dimmer?
If the low voltage lighting system uses an electronic transformer, then a dimmer designed for this type of transformer should be used. Likewise, if the low voltage lighting system uses a magnetic transformer, then a dimmer designed for this type of transformer should be used.
Aug 27, 2008 | Lutron TT-300NLH-BL Black Manual Lamp...
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
264 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
