Question about Tecumseh Garden
Engine started but stopped within 1 minute - Tecumseh Garden
  • 86 Answers
Its most likely a dirty carburetor,from leaving old gas in it which gums up carburetor
Posted on May 12, 2009
02 mercury sables starts but within 6 minutes shuts completely down. Won't start for bout 15 minutes later then shuts down again.
Something electronic is overheating , transistor , . the engine computer , ignition module . crankshaft position sensor. Also check PCM power relay . losing power . Check for spark , fuel pressure when it stops running , see what is missing .
Jun 21, 2016 | Mercury Cars & Trucks
Whenever I start my BMW 745li & move out & stop somewhere. Then off the engine within 1minute to 5 minute, when I turn on the engine again the transmission light on the dashboard will start to blink & when...
Check your transmission fluid while it's in park and running to see if it's low,add when engine is off,goes in where the dipstick is,use a funnel.
Jul 31, 2017 | Cars & Trucks
Jaguar s type 2000 over heats when stop in traffic,
Here a two of the most common causes for overheating;
1. Low coolant.
2. Faulty thermostat.
Make sure your coolant level is up to the FULL line on the coolant reservior, ( do not fill completely up or you cauld cause the check engine light to come.)
Check to see if the thermostat is working.
How to test the thermostat in most vehicles;
Make sure the heater is off, start the engine and let it run for 6 to 8 minutes, ( this will allow the
engine to reach, " normal operating temperature "), from the inside of the vehicle turn the heater
temperature on high and turn the fan speed on high.
1. Listen very closely for a click sound from the engine, ( most thermostats make a click when
they open )
2. Watch your temperature guage, it should begin to lower as the coolant starts to circulate.
3. Usually within a few minutes the radiator fan will kick.
I hope this helps you.
Donnie
Feb 20, 2011 | Jaguar S-Type Cars & Trucks
My 1998 taurus makes a tapping noise when i first start it but within 1 to 5 minutes it stops. I don't need oil.
could be a lifter / hla that is leaking down over night and must wait for oil to get back up to top of engine before it quiets. Could also be the oil filter that is allowing the same to happen , could also be piston slap - suggest you consult a trained ear to hear the engine on 1st start
Oct 27, 2009 | 1998 Ford Taurus
YKEHSO2RWHO starts o.k. but stop within a few minutes
that dryer has a moisture sensor probably is not sensing moisture
Jun 23, 2009 | KitchenAid KEHS02RMT Electric Dryer
Starter will not engage anti theft light is on it is a 2005 cobalt
I found this on a website try this
1. Put the newly cut Master key into the keyway and turn it to the ON (RUN) position. A "security" indicator
light on the dashboard will stay on for 10 minutes.
2. Within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON (RUN)
position. The indicator light again will stay on for 10 minutes (Do not remove the key.)
3. Again, within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON
(RUN) position. The indicator light again will stay on for 10 minutes. (Do not remove the key.)
4. When the light goes off the third time, the new key is programmed into the computer and will start
the car. Remove the key and then re-insert it into the ignition lock and start the car.
All previously stored codes will be erased. To stop the process at any time, simply remove the key and use
an existing key to start the car.
Mar 25, 2009 | 2007 Chevrolet Cobalt Coupe
Garden Logo
103 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
